Question about Intermatic & Indoor/Outdoor Rain Tight Timer
I use the timer T104P3 to switch the pool pump
I use the timer T104P3 to switch the swimming pool pump. The installation worked very good without problems. But now the timer is not turning anymore. I can switch the pump on and off by the the manual switch, but I want to use the timer to control the pump time. What can I do?
  • 1,340 Answers
LOOK HERE ON EBAY.. ITS CALLED A TIMER MOTOR.. REMEMBER TO VOTE..THANKS...... JAYhttp://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=170493987778&ssPageName=STRK:MESELX:IT#ht_2761wt_1227
Posted on Jun 02, 2010
Is timer the problem
I would think whatever is hooked up to the timer is bad. Not the timer itself. Disconnect/unplug the pool pump from the timer and see if the timer trips the breaker.
Dec 04, 2013 | Intermatic 220v T104p Swimming Pool Pump...
Intermatic t104p3 pool timer will turn pump ""ON" with Manual Switch but will not shut "OFF" using Manual Toggle. Pool store showed me how to remove and look at the contacts on...
Thank you for including model number so answer can be accurate as possible.
T104P3 timer works with manual override so timer is basically sound.
Clock dial rotates and keeps good time, so WG1573 240Volt clock motor is good.
Trippers do not click on-off lever, so trippers are suspect.
Trippers are made to wear down so that timer mechanism lasts years longer.
Order extra clock motor and trippers at Grainger
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
See wiring diagram:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 18, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
How to set Intermatic T104P3 - Pool-Spa Mechanical Time Switch... I believe this is the correct model. There are no instructions or data left on the gray metal box to verify what it is.. I got the model...
The T-104 is a 240Volt timer that will not work for 120V circuits
The above link gives you information about the T104 T103 T101 in case you need to buy another timer
The difference is the voltages on the lines and voltage of the clock
1) How to sort out what you have:
-Which circuit breaker operates the timer and pump? If your circuit breaker is 240, then the pump is 240 and the timer is 240 so you most likely have the T-104
-To double-check: turn off the power and look at the name plate on the pump >>> the name plate will show voltage of the pump
-If breaker is 120, then you have T-101 that has three terminal screws inside the timer, or you have T-103 with 5 terminal screws inside the timer.
OK that's the basic information:
You say your trippers don't work.
Does the manual override work?
2) If the manual override does NOT work when you click it back and forth, and the unit has electricity, then the timer is probably bad. You can buy a new timer, and swap out the insides with old timer without replacing box.
3) If the manual override DOES work, then best news of all ... you may need new tripper pins
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
Oct 19, 2010 | Intermatic T104 24h 208-277v Mechanical...
Clock for pool pump intermatic timer Model T104P3 stopped ticking
TO INSTALL THIS MOTOR REMOVE SCREW ON LEFT AND JUST BACK SCREW ON RIGHT A FEW TURNS, TIMER WILL ROCK UP OUT OF BASE THIS WAY . UN-HOOK WIRES ONE AT A TIME AND INSTALL WIRES FROM NEW MOTOR ONE AT A TIME.. THESE TWO WHITE WIRES GO TO LINE 1 AND 2 THESE ARE THE WIRES THAT GO TO THE 220 VOLT BREAKER ... NEED MORE HELP JUST GIVE ME A BUZZ.. JAY ..LOOK EBAY FOR .. Intermatic Timer Motor WG1573 / WG1573-5 clock POOL FIX
May 15, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
LOOK HERE ON EBAY .. Intermatic Timer Motor WG1573 / WG1573-5 clock POOL FIXTO INSTALL THIS MOTOR REMOVE SCREW ON LEFT AND JUST BACK SCREW ON RIGHT A FEW TURNS, TIMER WILL ROCK UP OUT OF BASE THIS WAY . UN-HOOK WIRES ONE AT A TIME AND INSTALL WIRES FROM NEW MOTOR ONE AT A TIME.. THESE TWO WHITE WIRES GO TO LINE 1 AND 2 THESE ARE THE WIRES THAT GO TO THE 220 VOLT BREAKER ... NEED MORE HELP JUST GIVE ME A BUZZ.. JAY
Mar 28, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
T104-50 clock not working
YOU CAN LOOK THREW THE LITTLE WINDOW TO SEE THE GEARS TURNING ON THE CLOCK .. IF NOT .. Intermatic Timer Motor WG1573 / WG1573-5 clock POOL FIX ON EBAY
TO INSTALL THIS MOTOR REMOVE SCREW ON LEFT AND JUST BACK SCREW ON RIGHT A FEW TURNS, TIMER WILL ROCK UP OUT OF BASE THIS WAY . UN-HOOK WIRES ONE AT A TIME AND INSTALL WIRES FROM NEW MOTOR ONE AT A TIME.. THESE TWO WHITE WIRES GO TO LINE 1 AND 2 THESE ARE THE WIRES THAT GO TO THE 220 VOLT BREAKER ... NEED MORE HELP JUST GIVE ME A BUZZ. .. VOTE PLEASE THANKS... JAY
Oct 07, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
I moved the time pinter by accident. now the timer
Did you mix up the pointers? One of them is for off and one for on. Dont know any other reason. If the timer is working all the pointers do is manually trip the lever as it comes past. On and Off should be stamped on the pointer.
Sep 28, 2009 | Intermatic Mechanical Timer Switch - Pool...
Turned the timer switch on, the pump starts and one second later
reset breaker overide timer by tuning on if this works it is a timer issue
Jun 07, 2009 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
666 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
