Question about Mirra M-160 (M020160) Server
Does not fire up. connected two new plug and outlet still will not turn on.
  • 128 Answers
Y dont u try with a different SMPS
good day
Posted on Jun 01, 2010
Wall outlet is getting hot along with the units plug,and its setting breakers off
Replace the outlet. It has a bad internal connection that is causing resistance and is heating up like an electric fire element. Don't use that socket until you replace it due to the very grave risk of fire.
Apr 18, 2017 | Heating & Cooling
Old home, a electrical outlet actually has a fuse connected right to it. How to replace/install a regular outlet plug? I have a pic, but site doesn't appear to have a place to attach it.
electrical work is not for DIY
some one has messed with the electrical wiring of the house so get in an accredited electrician and consider having the house rewired using the correct ELB devices in the power box
Jan 11, 2017 | Microwave Ovens
Will not connect to tv do you have to disconnect cable to get menu screen on fire stick
plug stick into hdmi on tv,tune tv to hdmi 1 or 2,plug power cord into stick and outlet,push center button for 5 seconds
Mar 08, 2015 | Amazon Fire TV Stick
How to test for a shorted generator stator
Sounds like you have a dead short. Check the outlets for any debris, metal or copper. Check the backside if the outlet for anything grounding onto the unit. The breaker is tripping to protect the outlet and anything plugged into it. The fire shooting out of the outlet is an arc flash caused by the dead short. You can also try disconnecting and replacing the outlet . If the problem persists, disconnect the starter and try to bench test it with a multimeter. I hope this helps. Good luck.
Oct 02, 2014 | Briggs & Stratton Electrical Supplies
The outlet plug gets very, very hot
STOP using the unit immediately. Your plug getting very hot indicates a very poor connection somewhere between your outlet and the oven switch. This is definately a fire hazard so do not use the unit until you have found and fixed the problem. It could also be the outlet itself not making a good connection with the plug. Look at that first. If the plug doesn't fit tight in the outlet, the outlet must be replaced. If the plug is tight, you may have a switch in the oven itself with a poor connection. The oven must be taken apart to find out where the problem lies if your outlet is good. You may find parts that are melted in the oven which would indicate a problem. It's hard to say exactly what the problem is without actually looking inside the oven to see whats going on. Whatever you do, DO NOT use the oven until the problem is fixed or the oven may end up being the least of your problems...
Mar 14, 2014 | Euro-Pro TO160L 1380 Watts Toaster Oven...
I have a problem when I connect my vacuum cleaner to the outlet the breaker turns off . The breaker is ARCF
Your vacuum is shorted, please take it to a vacuum repair center for further diagnose. don't keep plugging it in or a fire may result.
Jun 05, 2012 | Vacuums
Grill wont fire up
From Traeger:
Why won't my Grill Ignite?
  1. If your grill is plugged into an electrical outlet with a GFI (ground fault interrupter) plug, chances are the hot rod has absorbed or been exposed to too much moisture and is leaking to ground causing the plug to trip.
  2. Open your cooking chamber lid, remove cooking grill, angled drip pan and U-shaped firepot cover. Is there ash build up in the firepot and/or around the firepot? If so, this needs to be cleaned out. The ash is choking out the fire.
  3. Check the fuse on the back of the control board. To do this, first UNPLUG the grill from the electrical outlet. Then, unscrew the control board and look at the fuse-is it blown or not?
  4. If the fuse is good, check for power by switching the colored plugs first. Unplug the purple plug and the orange plug. Plug the purple plug into the orange plug. Now plug the power cord back into the electrical outlet and turn the grill on. Does the induction fan operate? If so, you will need a new hot rod and fuse. If not, you will need a new control board. Unplug the purple from the orange and reconnect the plugs together to their correct color plug.
  5. Always start your grill on the SMOKE setting.
Jun 13, 2011 | Traeger Industries BBQ100 All-in-One Grill...
I need the diagram to put the spark plug cables
2003 Chevrolet Malibu 3.1L SFI OHV 6cyl
Spark Plug Wires - Removal & Installation
3.5L Engine
  1. Before servicing the vehicle, refer to the Precautions Section.
    NOTE Twist the spark plug boot one-half turn in order to release the boot. Pull on the spark plug boot only. Do not pull on the spark plug wire or the wire could be damaged.
  2. Remove the intake manifold cover, if required.
  3. Disconnect the left side spark plug wires from the spark plugs.
  4. Disconnect the left side spark plug wires from the ignition coil.
  5. Remove the spark plug wire clips from the Manifold Absolute Pressure (MAP) sensor bracket and the heater inlet and outlet pipe tab.
  6. Remove the spark plug wire assembly.
  7. If replacing only one plug wire, open the retaining clips and remove the appropriate spark plug wire.
  8. Disconnect the right side spark plug wires from the spark plugs.
  9. Disconnect the right side spark plugs from the ignition coils.
  10. Remove the spark plug wire assembly.
  11. If replacing only one plug wire, open the retaining clip and remove the appropriate spark plug wire.
To install:
  1. Install the spark plug wire assembly.
  2. Connect the right side spark plugs to the ignition coils.
  3. Connect the right side spark plug wires to the spark plugs.
  4. If replacing only one plug wire, open the retaining clip and install the appropriate spark plug wire.
  5. Install the spark plug wire assembly.
  6. Connect the left side spark plug wires to the spark plugs.
  7. Connect the left side spark plug wires to the ignition coil.
  8. Install the spark plug wire clips to the MAP sensor bracket and the heater inlet and outlet pipe tab.
  9. If replacing only one plug wire, open the retaining clips and install the appropriate spark plug wire.
  10. Install the intake manifold cover, if required.
Fig. 2.2L Engine Firing Order: 1-3-4-2 Distributorless ignition system
Fig. 3.1L Engine Firing order: 1-2-3-4-5-6 Distributorless ignition system
Fig. 3.5L Engine Firing order: 1-2-3-4-5-6 Distributorless ignition system
Fig. 2.4L Engine Firing order: 1-3-4-2 Distributorless ignition system
Fig. 3.5L & 3.9L Engines Firing order: 1-2-3-4-5-6 Distributorless ignition system
I really hope help you with this (remember rated this help) Good luck.
Sep 23, 2009 | 2003 Chevrolet Malibu
The microwave runs for 3 to 4 seconds and then shuts down. I have to re enter the time, date and press start. It runs for 3 to 4 seconds and I repeat. Other times, it works just fine. But needs restarts...
If it is resetting, there is a chance that the problem is not with the microwave but the AC supply. These units draw a bunch of current and if there are any sloppy connections or a bad outlet (if plugged in), the connection can fail long enough to drop the AC input far enough to turn the unit off.
A circuit breaker (in your main power panel) can cause this too; I've replaced bad breakers in our new home already that were doing the same kind of thing your microwave is doing.
A bad AC connection can also be a fire hazard since they are also capable of getting hot enough to start a fire.
If the source of AC is via an outlet, check around it to ensure that there is no discoloration of the outlet's exposed plastic. If ther is, that is a sure sign of poor contact between the unit's plug and the outlet's contacts.
There is a remote chance that the magnetron is developing an internal problem; these are vacuum tubes of a sort and have a fast-heat heater element in a cathode that spits out electrons. One type of failure is when the cathode and heater come in contact because of the expansion of the heater element (happens each time it is turned on) then a very high voltage is brought into contact with the heater and causes a momentary short and high currents.
Aug 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a Dell Latitude D630, and I have had it for less than a year, and my charger is broken. I have it plugged in and everything, and it is not working. I plug the adapter into the outlet, and the...
sorry, i have to say this-- make sure the outlet works-- or try out a different outlet. :-)
ok, then make sure the connection is tight between the 2 parts of your adapter, it may have come loose.
other than that, you have a dead adapter. laptop companies are very good about replacing them for free under warrantee. they dont want fires starting at someones home because of a 30 dollar part.
i just called my laptop company, hp, 1 week before my 1 year warrantee ran out, and they shipped me a new power adapter, free, overnight.
call dell, tell them, they'll ship you a new one with usually free shipping, and usually in a day or two tops to your door.
Jan 31, 2009 | Dell Latitude D600 Notebook
Mirra M-160 (M020160) Server Logo
Top Mirra Computers & Internet Experts
David Payne
David Payne
Are you a Mirra Computer and Internet Expert? Answer questions, earn points and help others
