Question about Sony Playstation 3 (PS3) Console
Usb receiver for wireless buzz controller
Can I get a replacement usb receiver for wireless buzz controllers?
  • 3 Answers
SOURCE: PS3 controller Problem
I just fixed mine. The controller itself needs to be reset. There is a reset button on the back of the controller, above the top right hand corner of the square with all on the information and barcode. Press it with a sharp tipped object while still connected to the PS3 via USB cable. Then press the PS button and you should be back on wirelessly.
Posted on Jul 09, 2008
SOURCE: how to connect wireless battery powered controller without usb cable
The question isn't very clear.
Do you mean how to pair it with the PS3?
Or to charge it?
Cuz if its any of those, you need a USB cable.
Posted on Oct 26, 2008
  • 15 Answers
SOURCE: How do I activate Sony PS2 wireless Buzz Controllers.
there should be a switch on hte back with off 1 2 3 select which one u have the adptor to then plug it in (th controller take two double a's that go on the handle
Posted on Jan 17, 2009
  • 10 Answers
SOURCE: i cant sync my madcatz ps3 wireless controller
try to plug it in and then press the ps button or let it sit for a little bit while plugged in and then try it
Posted on May 27, 2009
  • 273 Answers
SOURCE: PS3 Controller will only work when plugged into the USB
i had same problem turn off your system with controller plugged in to usb unplug controller remove the power cable for a couple of mins reconnect and use controller PS button to turn system on and it should be back to normal. it worked for me
Posted on May 31, 2009
Lost usb receiver
The wireless demonstration device and USB receiver has an exclusive code. You should replacement codes. If it doesn't work, you only rebuy it.
Aug 23, 2011 | Kensington Wireless Presenter with Laser...
I have a logitech ps3 controller that is wireless. i plug in the usb into a usb port on the playstation and it still does not work. how do i fix this?
A couple possible issues here.
The first is that the batteries on your controller are dead. You may want to try changing them to see if that fixes your problem.
The second is that your USB receiver may not be seated properly or the port on your PS3 may not be working with the USB receiver. Try a few different ports to see if that changes anything.
The third is that you have a hardware failure in either your controller or USB receiver. If that's the case then you'll need to get a replacement from Logitech.
Mar 25, 2011 | Logitech Cordless Precision Controller for...
We have a big ben ps3 controller wiv the usb receiver but my son has snapped the usb thing...what can we do???buy a new controller??
Contact the manufacturer by email and ask them if they will sell you a reciever seperately. If not, you will have to buy a new whole new controller.
Mar 03, 2011 | Video Game Consoles & Games
Can't get it to connect to ps3
i don't know where you bought it but you should have gotten a usb receiver with your controller. you need that to be plugged into your ps3 and synch with your controller. here is the step by step from the beginning
http://www.dreamgear.net/lava-glow-wireless-controller-without-rumble.html
go down to the bottom of the page and look at the manual. and as you can see the controller comes with a matching usb receiver
Apr 28, 2010 | DreamGear Lava Glow Wireless Controller...
Its a big ben wireless controller with no usb how do i connect it to my ps3
plug the usb thingy in the pc then connect the bigben controller then take out usb thing plug it into ps3 conct the controller and itz done
Jan 18, 2010 | Sony Wireless Controller for PS3
My Intec controller will not connect to my ps3 don't no what to do.
Remove the USB receiver from the ps3 console usb port. Turn OFF the ps3 console and the controller. Turn on the ps3. trun the controller to on. press the sync button on the controller. Insert the usb receiver to the usb port. Press Home button. Now I had two controllers one I had to return because no matter what i did it did not link but the 2nd one did this way
Dec 29, 2009 | Intec PlayStation 3 Turbo Shock III...
Joystick is not finding the wireless receiver
On the front of the usb reciever you will see a green flashing LED. This is actually a button which when pressed will then start to blink more rapidly as it is now searching for the controller. If you then immediately press a button on the controller whilst these rapid flashes persist it will find the controller. Both reciever and controller will now show solid LED lights. Voila job done .....happy gaming:P
Dec 06, 2009 | Logitech Cordless USB Freedom 2.4GHz...
Ps3 will not reconize intec in any way wireed or wireless. just invisible
CONNECTION A:
DO NOT INSERT BATTERIES INTO THE CONTROLLER; THE USB CABLE USED WILL SUPPLY THE POWER TO THE CONTROLLER.
STEPS # 1 – TURN THE POWER ON TO THE PS3 CONSOLE.
STEP # 2 – CONNECT THE USB CABLE TO YOUR PS3 CONSOLE AND CONTROLLER.
STEP # 3 – NEXT PRESSE THE SYNC BUTTON ON THE CONTROLLER, THE CONTROLLERS LED INDICATOR’S LOCATED ON THE FRONT OF THE CONTROLLER WILL START TO FLASH RAPIDLY.
STEP # 4 – CONNECT THE USB RECEIVER TO THE USB PORT ON THE PS3 CONSOLE.
STEP # 5 – WHEN THW CONTROLLERS LED INDICATOR’S LOACTED ON THE FRONT OF THE CONTROLLER START FLASHING SLOW PRESS THE HOME BUTTON.
WHEN THE CONTROLLER HAS ESTABLISHED A CONNECTION BETWEEN THE CONTROLLER AND THE USB RECEIVER ONE OF THE CONTROLLER’S LED INDICATOR’S WILL BECOME SOLID RED.
Jul 12, 2009 | Intec PlayStation 3 Turbo Shock III...
How do I sync Big ben wireless controller to ps3?
hi, i had this problem also. u have to plug in the usb receiver (looks like a usb storage that you would use for pc) into the front of pc. make sure you have batteries in controller turn it on and press home. red light will flash on usb receiver until controller is paired with it. hope this helps
Jan 04, 2009 | Sony Wireless Controller for PlayStation 3
XBOX 360 Wireless Controller PC Connection Problem
WARNING: try at your own risk!
I kind of fixed it. The problem appears to be with the USB controller - specifically, my mouse (a Razer Copperhead) and the XBOX 360 wireless receiver. A lot of work went into the solution, but I essentially ended up uninstalling and unplugging all of my USB devices (you can uninstall them using device manager in System Properties>>Hardware within Control Panel. Look for Universal Serial Bus and uninstall everything in that category). Reboot. Then, I first plugged in the device in question (my 360 receiver). Afterwards, I one by one plugged in each item until I found the one conflicting with the receiver (my mouse). After that, I uninstalled all devices again and next uninstalled the drivers for the conflicting device (my mouse in this case) and rebooted again. After this, I tried several times to uninstall and reinstall the mouse and various USB devices until finally it worked (sort of).
I call this a partial solution because now I appear to have the opposite problem. My mouse seems to be conflicting with another device (probably the 360 receiver). My mouse refresh rate is very choppy. The good news (for me) is that I can uninstall the USB controller for the mouse, reboot, and both the 360 controller and the mouse will work fine... that is until shut down. Then I have to uninstall the mouse controller and reboot again. Needless to say, I keep my computer on more than usual now.
Nov 25, 2008 | Microsoft MS Xbox 360 Common Controller...
Sony Playstation 3 (PS3) Console Logo
1,967 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
