Question about Bose Lifestyle 20 System
My CD changer cartridge is jammed in the unit
The six pack cartridge is lodged in the unit
Peel the top off the unit using a small flat head screw driver. You may break the glue or the tabs are like the one's you'd see on a cars door panel. (xmas tree shaped spears). Once this is removed you can see the CD and the top of the changer. Under the unit there is a molded message that says Manual magazine release. Go into the thin slot with an ice pick and push to the back of the "U" shape. You can feel that it is spring loaded. This will release the cartridge.
Posted on Aug 13, 2010
Jaguar cd changer showing code cdc
check the cartridge has not jammed or disc has not got jammed if i remember correctly you can cycle through the faults using the head unit to help have you got your audio hanbook suppliment? if the cd or cartidge has not jammed eject the cartridge and try a battery reset, i.e. disconnect the vehicale battery for a few mins., i seem to remember they did this when the head needed cleaning what it means is the head unit as lost contact with the auto changer. also check the power lead e.t.c and the data connector
Apr 02, 2013 | Jaguar X-Type Cars & Trucks
How do you remove cd's from a six in dash changer...it will not play or eject the cd's
hi,
It sounds like the CD rack or cartridge inside the head unit has jammed. The only way of getting them out is to remove the 2 Din head unit from the dash/console,due to each CD being lifted up into the eject position and ejected separately.
If you got the tools you can dismantle and remove them from the head unit yourself. Hope this helps, let me know ow you get on.
Apr 04, 2010 | 2004 Honda Accord
Appear to have cd jammed in cartridge,mislaid
Owners manual here
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Mar 17, 2010 | Alpine CHAS-634 6-Disc CD Changer
My BMW X5 6 CD Alpine changer is jammed and will not work. How do I fix it and remove the disk?
If the issue is you cannot eject the cartridge this would be simple.
Slide the changer door open as if ejecting the cartridge. Take a credit card/driver license and insert about 2 to 3 inches between cartridge and chassis. You should hear a click and the cartridge should eject.
Once the cartridge is out check to make sure there isnt a stuck CD in the changer. If there is remove the loose CD. If the CD is stuck in the player itself insert the empty cartridge the changer will cycle through the process. Once it stops you can press eject button and the CD should be in the cartridge.
Feb 25, 2010 | Alpine Car Audio & Video
I have a Sony 6 CD in a SMAX. A CD is blocked inside. I suppose 2 CDs are on the same position. (the first).Ejecting CD is impossible. Other CD positions (2 to 6) work properly
You need to pull the unit and disassemble the unit. Pop the top with 4 or 6 phillips head screws, pull off the top and you will see the problem immediately. Gently slide the jammed disc out of the cartridge and pull out of the unit if possible. If not slide it back to the tray. Plug the unit back in with the top still off and eject the cartridge. Inspect the cartridge for warps or bends, if there are any, replace the cartridge. Hope this helps
Jan 02, 2010 | Sony CDX-602 10-Disc CD Changer
The 6 disc magazine will not eject -
Ok..just happened to me. I'm a tinkerer so it's assumed that everything is out of warranty. The low down and skinny is this. The last disc holder is stuck on the metal changer tab, preventing the magazine to eject. 1. Remove the six screws on the left and right sides. 2. Use a small flathead screwdriver to GENTLY pry off the front Alpine CHM-S620 plastic facia.\ 3. On both left and right sides, collapse and push in the rubber suspension mounts. 4. Carefully remove the vertical/horizontal mount springs. 5. Gently pull off the data cable ribbon. 6. Flip over the changer unit. Use a coathanger to gently push the cartridge back into magazine. **You may damage the cd and last holder. Small price to pay to get things back to working order though. You may also have to wiggle the last cd holder to get it over the metal lip. 7. Reassemble in reverse order. 8. Change out that last cd cartridge so it doesn't jam again. Good luck.
Sep 27, 2009 | Alpine CHM-S620 6-Disc CD Changer
HI, Is there anyway to get my CDs out of my Sony CDX-52 (not listed in dropdown below) once it has been disconnected from power. My 10 disc cartrage is stuck and won't release from the unit. Thanks. Bart
The safest way to get the cartridge out is to pop the top on the unit. Once this is done, chances are good that you will find a cd that's jammed between the player and the cartridge. It tried to put the disc into the wrong slot.
Gently push the cd onto the player, then plug it back in, it should reset as normal then allow you to eject the cartridge. If you still have an issue post a comment and I can help you some more. Hope this helps
Jul 01, 2009 | Sony CDX-757MX 10-Disc CD Changer
Where is the changer fuze located on an autdiovox
It's not a fuse. More than likely it tried to load 2 discs into the same slot and jammed. That's one of the most common problems with shangers. If you pull the unit out of the vehicle and open the top you will see how it's jammed. Lightly move the CD towards the tray side, not into the cartridge, then plug the unit back in. It will reset itself and then you can eject the cartridge. Then inspect the cartridge for warps or cracks. You may want to replace the cartridge, they do wear out. Also, a good habit is to run a Laser lens cleaner thru the unit itself 3 or 4 times a year to keep the lens clean. It's really the only maintanance you can do. Hope this helps
Jun 26, 2009 | Audiovox SP11CDP 10-Disc CD Changer
No CD changer
I wonder if the person you got the vehicle from knew there was no CD changer, but never look a gift horse in the mouth. Any brand CD changer should be able to work with your in-dash controller unit. You do not need to pay an arm and a leg to the dealer for a new unit, or risk purchasing a questionable used unit. I highly recommend Crutchfield.com for selection, price, and support.
Mar 05, 2009 | 2001 Lexus RX 300
Bose Lifestyle 20 System Logo
342 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
