Question about Mitsubishi WS-55511 55" Rear Projection Television
When I turn my ws-55511 on, the green indicator light comes on for about 5 seconds, then switches off and the set never turns on.
    Sergeant:
    Champion:
  • 431 Answers
Voltage regulator ic str6511
Posted on Jun 09, 2010
This situation has occured to me now three times. Each time I've had the unit repaired because the power transfer switch? has burned out due to excessive heat. $400/ea for the repair. The upside is that I've had the same repair guy do the work, so I trust him. When I told him that I was considering upgrading to a flat panel, he stated that the WS-55511 has as good a picture if not better than LCD's or Plasmas. FYI.
Posted on Jun 07, 2010
I have this same problem. :(
Posted on Jun 02, 2010
I have a mitsubishi model WS-55511. The green light keeps blinking. Have reset by unpluging and then pluging back in and holding the reset but for 5 seconds and press the power button. worked once, but...
TWO possible reasons for the blinking light:
1. The DM unit (caps and or fuses) are bad---no longer made and only (to my knowledge) PTS electronics repairs/rebuilds them.
2. Less likely but Possible: remove front speaker grill and inspection plate behind it----locate the two bundles of wires from front keyboard on set and follow them down and to the right---unplug both plugs and plug set in and wait 70 plus seconds and try to turn set on with Mitsubishi remote.
The blinking light is the DM trying to boot up--if set works with front keyboard unplugged---the tiny reset switch on it is bad.
If set does NOT work that way DM UNIT IS BAD.
SD TECH
May 03, 2011 | Mitsubishi WS-55511 55" Rear Projection...
WS-55511 shut itself down while watching TV and won't come back on again. I tried unplugging and reconnecting, it goes through the reset (green light blinking). The convergence went bad and the chip was...
After you turn on and green power light comes on and then goes out:
Press and hold both the menu and input buttons on the front of the set for at least 5 seconds and release both buttons.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it 4 more times.
Let me know what error code and I will tell you what it means. If this information told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Aug 23, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Will not turn on
ONE OF TWO THINGS HERE:
set turns on and green power light goes off in a few seconds, if this is the case on the front of set push and hold both menu and input buttons at same time for at least 5 seconds and release both buttons.
Green power light will blink two digit error code like: 2 blinks, 2 blinks----a pause and it will repeat error code for a total of 5 times.
If this is case let me know error code.
If green power light does not come on let me know.
You answer will dictate a response if you let me know here.
I am expert on Mitsubishi sets and know them well.
SD TECH
Aug 17, 2010 | Mitsubishi WS-55511 55" Rear Projection...
When you turn the tv on it go right back off Mitsubishi WS-55511 55 in. It about (5)yrs old I have try unplugging the tv for about 3 to 5 minute
Do this: When you turn it on and the green power light comes on and goes off:
On the front of the set press and hold BOTH the Menu and Input buttons at the same time for at least 5 seconds and then release both.
This model has a self check: The green power light will then blink a two digit error code: most common is 2 blinks, 2 blinks and a pause and repeat the error code at least 5 times.
Let me know what you find and I will tell you what it means.
I hope you get 2,2 as it is the most easy to resolve.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
REGARDS, SD TECH
Aug 12, 2010 | Mitsubishi WS-55511 55" Rear Projection...
My mitsubishi hdtv1080 is stuck on camcorde, how can I get it off?
When I turn the Mit. 1080 on, the green indicator light comes on for about 3-5 seconds then it goes off. TV never comes on (no picture or soun, nothing). What is the problem. thanks
Feb 06, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi ws-55511 does not turn on
Listen: you need to wait for the set to first shut off! then push on the TV(not the remote) Input and Menu both at the same time for 5 seconds and then release---the power light will then blink---this model has this feature--
Sep 13, 2009 | Mitsubishi WS-55511 55" Rear Projection...
My model is a WS-55511. I turn on the TV, the
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
Aug 08, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mits Ws 5551 won't turn on
http://www.techlore.com/forum/thread/19174/Green-Blinking-Light-on-Mitsubishi-HDTV/?page=26#43124
Go to this post. I had the same problem and it was easy to fix...it cost about 26 bucks total and took about 20 minutes start to finish!
Bruce
Jul 20, 2009 | Mitsubishi WS-55511 55" Rear Projection...
WS-55511
Press in together the menu button and the Device/input button on the set and hold them both in together for 5 seconds and see if the led will blink a two digit error code, then respond to this same post and let me know if it gave a error code and what the two digits were.
Aug 02, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
279 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
