Question about Nortel T7316E 2-Line Corded Phone
How to adjust time and date on nortel t7316e - Nortel T7316E 2-Line Corded Phone
    President:
  • Nortel Master
  • 860 Answers
Changing the time on a Norstar system must be done using a display phone. Using a M7310, M7324, or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press softkey "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press softkey "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___"
12.- Press softkey "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press softkey "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___"
18.- Press softkey "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
Posted on Jun 01, 2010
  • 1 more comment
  • george  peters
    george peters Jun 01, 2010
    What didn't work in the instructions?
  • george  peters
    george peters Jun 02, 2010
    Was the solution inaccurate?
  • george  peters
    george peters Jun 03, 2010
    When you enter in feature **266344 does the screen say log: or pswd: or nothing at all?
How do I program time?
Go into the programming mode and scroll down to Time and date. You can change it at that point .
Feb 23, 2015 | Nortel T7316E 2-Line Corded Phone
Changing the date and time
feature,*,*,23646 (or admin) from the main unit should get you into the settings, the password is the same unless your installer changed it. Time and date should be among the first settings you can scroll through.
Feb 17, 2013 | Nortel Commander T7316e Business Handset...
Need to change the time on my Nortel T7316E
Leave the handset in the cradle and press:
Feature (star) (star) T I M E
Follow the prompts to change the time & date.
Mar 13, 2010 | NorStar T7316E Corded Phone
Need Help! I have a nortel T7316E, for some
go to tek-tips.com they have a Nortel Norstar and BCM section in there that will get you the help.
Feb 09, 2010 | NorStar T7316E Phone
How to change the time and date on nortel phone
Programming2.gif is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say A. Configuration. The 4 top line/feature keys are now used for programming.
display should read B.General Administration.
Press the show key (top right arrow)
display should read 1.speed dial
Press the next key 2 times(bottom right arrow) .
display should say 3.time and date
display should show current programmed time
Press the Change key
Enter in time in 12 hour format
press ok
press either Am or PM when prompted
press ok
press the Rls key when finished
Nov 04, 2009 | NorStar T7316E Corded Phone
The time is off one hour how do I fix it...Nortel
Programming should be done from the M7310, M7324 or the T7316E set. Administration access code: Feature * * 2 3 6 4 6 which also is Feature * * A D M I N.
If asked for a password enter the same 2 3 6 4 6.
If that doesn't work you may have the newer Compact ICS or the Modular 0x32 control unit which will be Feature * * 8 4 6 3 which is T I M E. Password is 2 2 7 4 2 which is B A S I C or A D M I N which is 2 3 6 4 6.
When in programming just press the next button(lower right arrow) until you see what you want to change. Then press show ( top right arrow) ,then change if you want to change it. If you pass it, press back (lower left arrow)
Example: To change the Time & Date Press next until you see Time & Date. Then show Then Chng Then change again, change it if you need to, Then next again until you see what you need to change. For example; only the hour needs to be changed for day light savings time. Just press next until you come to the Hour. Then Change it. Then press release RLs when your done.
Oct 28, 2009 | Nortel T7316E 2-Line Corded Phone
Can't Change Time
Do Feature **ADMIN, Then go to Time And Date, and enter the time, here is a video on how to do this
Jul 08, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Nortel t316e phone only rings 2 times
You could have a CICS, and MICS or a Nortel BCM. Which do you have?
You will need to access admin programming, do you know how?
Jun 26, 2009 | Nortel T7316E 2-Line Corded Phone
How to change time on my T7316E Nortel phone
Step 1
Press the FEATURE key followed by **8463
Password Retry Step 2
Press 266344 on the dial pad buttons to enter the DEFAULT password. Your password MAY BE DIFFERENT! The display will show the following options:
Hour: 01 Next Change Step 3
Select CHANGE - the display will show the following options:
Hour: __ Cancl Step 4
Use the dial pad buttons to enter the hour. You must use two digits for all hours (i.e. "08" for 8 o'clock). You will be prompted to enter AM or PM. Select CHANGE and OK to choose PM. AM OK Change Step 5
After you have entered the hours, select NEXT. The display will show minutes as 00. Use the dial pad buttons to enter the minutes. If you are just changing the time, press the RELEASE (RLS) button to end your session. The time will be changed and the date will remain the same.
If you want to change the date, select NEXT.
Minutes: 00 Next Change Step 6
The display will show 99 as the year. Using two digits, enter the year using the dial pad buttons (i.e. "05" for 2005).
Select NEXT, and repeat to change the month and the day.
Year: 99 Next Change Step 7
Once you have entered the day, press the RELEASE (RLS) key to end your session. This will save the changed time and date.
Mar 11, 2009 | Lands Phones
Nortel T7316E 2-Line Corded Phone Logo
3,069 people viewed this question
Top Nortel Lands Phones Experts
David Burbee
David Burbee
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
