Question about Apex Digital GT2015DV 20 in. TV/DVD Combo
Child lock on and do not know how to disengage
My kids were using the remote and now I only have a blank screen with a red key on it. I have the remote but do not know what buttons to push to turn off the child lock. I saw a mention of an "F" key but do not have such a key. Help
  • Anonymous May 26, 2008
    My son played with the remote and now I cannot even get the menu up. all I can get is the red key. What to do.
    President:
  • 3,130 Answers
Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
  1. To use the override code:
  2. Hit the MENU key to get to the menus.
  3. Go down to the SYSTEM menu and hit the right arrow on the remote control.
  4. Once in the SYSTEM menu, go to PARENTAL GUIDE. It will ask for your code.
  5. Enter the override code listed above. From here, you can turn on and off different rating restrictions, as well as set a new code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the function or F button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired
Posted on Apr 09, 2008
    New Friend:
I have an Apex TV. It has a blank screen with a red lock, I do not have original remote. How can I remove lock?
Posted on Nov 30, 2009
Thank you. skimming through the solutions for various problems I was able to figure out a solution for my tv remote control. It is ok now. Thanks.
Posted on Dec 17, 2008
SOURCE:
The Rear Door Drivers side will not open with the remote or when I try with the door lever on the inside
Child locks are on.
There is a slot in the rear door lock for the ignition key that engages/disengages the child lock there is a diagram sticker next to it. Check your user manual under child locks.
Jan 17, 2014 | Citroen C5 Cars & Trucks
Television "locked"
Hello can you please post the brand and model of the television so we can find unlocking instructions.
Jun 18, 2008 | Televison & Video
Want to reset the v-chip on my 2001orion tv model # 1933
Omni TVs have a child lock that allows parents to prevent children from watching specific channels or television shows with certain ratings. To activate or deactivate the controls, you need the four digit pass code. If you forget the pass code or if the lock gets set accidentally, you can still unlock the TV.
• Use the original Omni remote control to turn on the TV. You need the original remote to bypass the child lock. A universal remote won't work.
Check the screen. If you see a blank screen with a red key on it, press the "Function" and "Mute" buttons at the same time. This unlocks only the channel that is on the TV. All the other channels will remain locked and the TV will lock again when it is turned off.
• Unlock all of the channels on the TV by entering "6688," which is the factory reset code. This code resets the TV to original factory settings. Once this is done, you will have to go through the initial setup.
• Call Omni technical support at (416) 260-0047. A technician can help you troubleshoot the television as the problem may not be the child lock. You'll need to know the model number and serial number of the TV.
•Take your television to a TV repair shop if you are still unable to unlock the TV. The problem may be with the wiring, so the repairman may have to rewire the TV
Aug 12, 2012 | Televison & Video
I have a red key on bottom left side of screen. Have volume but no picture. None of the controls work on tv or remote.
Hello
Your TV is locked.
The Child Lock feature prevents unauthorized viewing of the
television. To activate, press and hold the Function key, and then
press MUTE. you should see a key symbol appear on the screen.
This will lock out all remote functions (except for Standby). To unlock
the TV, press and hold the Function key and press MUTE. This will
unlock the TV. Please note that the only way to activate or deactivate
the Child lock feature is via remote control - please insure that it is
stored securely.
Jul 11, 2011 | Apex Digital AT1314DV 13 in. TV/DVD Combo
How to open child lock on cineplus LG TV manually as remote is not working
Try entering code 0000 or 1234 for the child lock.
Otherwise try holding down the DISPLAY key on the remote or on the front of the tv for 10 seconds to disengage the child lock.
Jan 28, 2011 | LG 42LC2D 42 in. LCD HDTV
Child Lock - without remote....
press and fold the F key then press mute via the remote is the only way stated in the manual. try the remote you have make sure there is fresh batteries in it and the switch on the side is set to TV
Feb 21, 2008 | Apex Digital PF2020 20" TV
Child lock
my AKAI tv is locked. All i see is a blus screen with a little red lock on the bottom left corner! the only button that works on the tv OR remote is the power button on the remote. PLEASE HELP i have tried pushing every button but nothing happens
Feb 15, 2008 | Akai CTS2550 25" TV
Apex tv pf2030 child lock
I'm afraid you will need the original remote control hand unit folks. Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired
Jan 19, 2008 | Apex Digital PF2025 20" TV
Apex GT2015 DV Problem
If your set has a blue screen with a small red lock on it, yes you are in the child lock mode, if there is no red lock on the blue screen then no you have another problem. The trouble is, if you are in the child lock mode, you cannot get out of it with out the proper remote hand unit. you will need to get an original replacement remote from Here:http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=GT2015DV&brand_pn=APEX_GT2015DV&mode=large&uid=11834488446870 There is no other way I'm afraid. Good luck
Jul 03, 2007 | Apex Digital GT2015DV 20 in. TV/DVD Combo
Blue screen and red padlock
It sounds to me like a child lock function, which is usually what the screen + padlock is on TVs. Usually your original remote would have a button / sequence to unlock the mode. If you still have your original remote, look for a child lock button or refer to your remote manual (and/or TV manual for the child lock feature) to unlock the mode.
Jan 24, 2007 | Haier HTF27R11 27" TV
Apex Digital GT2015DV 20 in. TV/DVD Combo Logo
401 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Ekse
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
