Question about Troy-Bilt Pony Garden Tiller
The large lever in the middle is very difficult to push up in order to stop the tiller. it wants to just spring back. It is my dad's tiller and I am not very familiar with part names. Forgive me. Thanks, Linda
" How to put belt on Bolens self propeled/ self muliching 21' push mower
should be some sort of tensioner device or spring that would need to be slacked off in order to facilitate removal try that
Jul 24, 2014 | Troy Bilt Tiller Bolens Swivel Post Pn...
Broken Tiller
A8 and A9 are the parts you need to get this fixed.
CRM3400 Legend 4 Wheel Replacement Parts . This is not a very difficult repair for an experienced mechanic but may be tricky for a novice. The tiller needs to be held in place while you work on it. I usually tie a rope to it and throw it over a garage roof rafter to tie it off. A second set of hands works also. Getting the covers off is straightforward. The screws are well hidden so check out the blow up diagram first. The cable end with the stop on it is attached to the slot on the mech lock and the cable release lever is run out to the shroud cover. The adjusting lever assembly is pushed into the tiller housing first from the outside and then the cable is attached with a spring clip ( if memory serves me right). You might get lucky and the only thing you may need to do is reattach the cable with the clip and lubricate the mech lock with WD40.
Feb 28, 2014 | Pride New Mobility Legend 4 Wheel Scooter
I have a craftman 4 cycle mini tiller, running to slow. need to run at a faster speed. do not where to adjust.
If the carb has the "fixed" throttle control. Find the governor control lever with the small, long coiled spring attatched to it in the middle. It may be hooked to a metal tab that is on the back carburetor bolt. Bend the tab to your left to increase set speed or to the right (towards governor lever) to decrease.
Sep 05, 2011 | Craftsman Gas Mini - Tiller/Edger
2 stroke Mantis Tiller 1) Very difficult starting, when started, high rev works, but 2) Engine dies on deceleration. Carburetor is signed C1U K4589A. The priming pump does not suction, gasoline...
Hi there is a small stone fuel filter in the tank. this filter stops fuel from running back into the tank from the carb check to insure it still on and make sure there are no cracks or hole in fuel line that should fix your problem
Aug 31, 2011 | Mantis 2-Cycle Tiller
Found large spring at end of cable unattached lying on top of deck cover. Where does the spring attach in order to engage the blades on the riding mower? The lever is very loose and when checking, I found...
There are 4 pulleys on your deck. Two for the blades, these are the big ones on the outsides. To the insides there are two, one on left side is an idler and the one on the right is a tenioning pulley that hooks to the blade engage lever throught the cable you found. Look on top of this pulley and see if it has a piece sticking up. If so the spring at the end of the cable attaches here. Slide it over. You also need to find the clip that goes through the little hole in the end that keeps it from sliding off. Make sure that the cable is properly routed and attached near the back of the deck. If it is still attached, good, if not you will have to find that pin also.
If this is helpful, please rate.
Jul 10, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do you replace a drive cable on a toro recycler 6.5 hp.
Its a bit of a pain - but with ordinary tools, it can be done. Get the replacement cable first. You can see how the bottom spring wraps around the cable with a universal joint sort of arrangement. Remove the belt protector (three screws from the top deck; if you have a battery compartment, that will temporarily need to go. Release the old cable from the top and middle attachment points, then unhook the spring from the traction lever. You might need to destroy the old cable lock to the mower deck to remove the old cable. Remove the plastic cup next to the cable where it exits the mower deck. Replace parts in this order: New spring/cable to the traction lever, snap in plastic interface to mower deck, small plastic cup top cable attachment, then middle attachment. You might need to move the middle attachment after you give it a test run. Replace belt cover and battery compartment if necessary. A lot of steps but, except for a difficult fit to get the spring hooked up, nothing is really difficult. I paid about $30 for the replacement cable from a local dealer; Overpriced, but I wanted to get the job done today.
Oct 15, 2010 | Toro Lawn Mower With Toro Power Tools
Roto Hoe levers
If you have a model 990 rear tine then I could send photos of mine, I have two and they are bulletproof.
This may be all you need: http://www.youtube.com/watch?v=RvuCXCT5Blk
This shows same model in action, let me know if you want photo's.
Mar 25, 2009 | Garden
Kick starter
new spring and little ball. My question is were does the little ball and spring go? I tried to get it down where the bolt threads in but no dice. Any help would be great.That's the detent for a fully closed (folded) kick start lever. Look in the splined base which you ordered (female) which fits on the kick lever shaft (which is also splinedbut male) there is the hole where the actual kick start lever fits. This in the same plane as the little indent in the lever it self. Put in the spring, Then the ball on top, press the ball down with a small screwdriver or whatever from one end as sliding the lever in from the other. Once the lever end has started over the ball just push in all the way and turn to engage the lever a couple of times to make sure the detent works. Then slide the unit on as you would any kick start lever. I did this in the field yesterday, so its not difficult. I used an allen wrench to push the ball down. Took maybe a minute. Hope I did not over explain, its pretty obvious if you look at it enough. Good luck.,,,
Nov 10, 2008 | 2006 Gas Gas EC 250
Problem with a WindTunnel 2 Extra Reach Bagless Upright (U8351900)
My dad fixed it by putting the spring under the arm lever and the roller on the outside part of the belt than in the inside as I have been trying to do.. I did however put one part of the spring in the right area of the vacuum. In a hole on the bottom area of the inside. The spring that is bent in a 90 degree angle doesn't go on top of the extend part of the arm lever but underneath. My dad did wounded the spring a bit tighter than it original is. That fixed what many days and hours of my frustration in less than 5 minutes (That's how long it approximately took my dad to fix it and in one try)
Jul 12, 2008 | Hoover U6660-900 WindTunnel Bagless...
Troy-Bilt Pony Garden Tiller Logo
16 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
