Question about Sony KV-36FS16 36" TV
Won't turn on. Standby lightblinks 5 times.
I saw another one of your post about this model tv. I have no picture on the screen and the standby light blinks in increments of 5? Does that mean I need a new tube?
    Genius:
  • 1,694 Answers
Possible,but first try turning up the screen voltage slightly...
located on flyback transformer or crt socket module......T.
Posted on Apr 10, 2008
I have a LG LED TV 55LS4500UD that no longer works after a storm. It won't turn on and no standby light. I have pics of the circuit boards. I would like to know which board to replace?
Power Issues Troubleshooting
*NOTE* LG & Vizio TVs must be plugged in for 5 minutes before it will turn on*
1. Inspect ALL Ribbons and connectors. Any tears or bad connections between boards must be replaced FIRST
2. If you have any of these boards, it should be the first board to be replaced
A) T-Con Board - Video Problems (No Video with standby light on, audio but no video, grainy, distorted, or color problems in screen)
B) X or Y Buffer Board (Plasma TVs only) - Standby light is on but no power
C) Backlight Inverter / LED Driver - No Video with standby light on
3. Main Video Board
- Either video or audio does not work (if no T-Con in TV. If audio but no video it is T-Con)
4. Power Board - No power AND standby light does NOT turn on. If standby light is on try other boards above
5. Panel - No power, distorted picture, lines, slow motion, half screen, faded in / out. Panel problems are usually not worth replacing the panel.
Apr 11, 2016 | LG Televison & Video
Tip
Tv problems lg and vizeo
3. Main Video Board
on May 22, 2015 | LG Televison & Video
My 15 month Celcus LCD423D913FHD tv will not turn on. The standby light is lit and will flicker but will not power up the tv. What is the likely problem?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 20, 2014 | Televison & Video
Sony kv-27v40 standby/timer blinks 5 times
Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Apr 23, 2012 | Sony KV-27V40 27" TV
Standby light stays on and the tv will not go on
Please check batteries in remote that seems not working. Sony TV would either turns On or standby light will blinks if TV gets any internal problem.
You question shows standby light stays On that means TV does not receive power on command from remote.
If standby light is blinking in sequence, let me know how many times it is blinking and also intimate exact model number of TV to find out possible solution.
Thanks.
Sep 21, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Red standby light light blinking
The 5 blinks can indicate a picture tube starting to fail. Carefully open up the back and look for the flyback transformer. It will be the part with the large red wire coming out the top that goes to the side of the picture tube. There should be 2 controls on the flyback, screen and focus. Turn the screen control slightly clockwise. If the set stays on, the picture tube is starting to fail and you have bought yourself time to find a replacement. If that fails, then you will need to investigate other possibilities that will involve soldering. Let me know if you need to do that.
The 6 blinks indicate no horiszontal. This can be as simple as a couple of bad capacitors or the "jungle" IC. If you can solder, please post another question with the model and a brief description indicating that you can work in the set and we'll continue to track this down.
Thanks,
Dan
Dec 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Standby light flashes 2 or 5 times; lilac picture with horizontal lines; and instant offs
There is some electronic circuit problem with your TV. Best if you want to repair it you find a reputable TV repair shop. Sorry.
Sep 18, 2008 | Sony KV-24FV12 24" TV
TV will not come on.
The 7 blinks indicate a high voltage shutdown (high voltage exceeded 33,000V). This is usually caused by a defective regulator. Could you please post the exact model number (KVxxx) and I'll look up the part you will likely need?
Thanks,
Dan
Jul 28, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
On picture
Hiii...
Try to check the M board,IC001,G2 ( Screen ) Voltage....
Thank's
[vrya]
Mar 13, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-36FS16 36" TV Logo
98 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
