Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Cub Cadet 2165 battery light comes on when I engage the mower
Tractor still runs okay but battery light comes on and off when the mower deck is engaged. I would appreciate any help on this issue.
Thanks,
  • 109 Answers
SOURCE: Cub Cadet tractor failure to move
Check the bypass for the transmission, make sure it is in all the way, if it is, check the belt from the engine to the transmission, make sure the belt tension spring is riding on the belt and that the belt is tight.
Posted on Apr 16, 2009
panilling9
  • 284 Answers
SOURCE: cub cadet mower pto will not stay engaged while
be sure your battery is good and your system is chargingning the battery while run
Posted on May 26, 2009
panilling9
  • 284 Answers
SOURCE: engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
SOURCE: My cub cadet zero turn mower won't engage the
My cub cadet ZTR M60, under the mower in the rear is 2 wires going to the electric clutch my wire fell and the belt cut one of them. I spliced it and it was good to go. Signed:Acorn tractor
Posted on Jun 05, 2009
  • 146 Answers
SOURCE: cub cadet pto won,t stay engaged
Sounds more like a PTO clutch failure, rather than the switch. The clutch is mounted on the engine shaft, between the hydrostatic drive pulley (nearest the chassis) and the mower deck belt pulley (farther from the chassis).
Since it's an expensive part, make sure the problem isn't in the switch or wiring first. You could do that by probing the wires to the PTO clutch with an automotive test light - they are inexpensive and handy. Clip the ground wire of the test light to the chassis, and probe the hot wire to the clutch (it's the one that doesn't connect to ground) when the engine is running and the PTO switch is engaged. Obviously a helper has to be in the seat, and you should be careful doing this. If the light glows brightly, and the clutch doesn't engage, you definitely have a bad clutch. Good luck! Please rate my answer if helpful, thanks.
Posted on Jul 07, 2010
Starter motor hds 2165 cub cadet
One post, take a cheap thin wrench. Heat it, bent 90 d to fit in the space.
Apr 03, 2014 | Cub Cadet Riding Lawn Garden Zero Turn...
I need a diagraphm for a Cub Cadet lawn mower to put belt back on
To get correct diagram, will need the model number of the unit. Not the model off the engine, but off the chassie.
Sep 24, 2010 | Cub Cadet Street Sign- tractor lawn riding...
My Cub Cadet i1042 tractor shuts off when the blade is engaged. This happened after I ran over a ***** and/or stump. Every time I try to engage the blade the engine shuts off.
Check for bent blade against deck housing.Possible you bent something on mowing deck,check all spindles and pulleys.You could have something hung on blade and making contact with deck. Rarely will the motor be hurt from hitting object on rider.
Apr 24, 2010 | Cub Cadet Street Sign- tractor lawn riding...
The pto on my cub cadet 1515 cuts off. It will
Mine does the same thing. I've found that normally this is a heat-related problem and by removing all the clippings from the deck the blades will re-engage just fine until (unless) the clippings mount up again. Hope this helps; I make sure the deck is clean top and bottom before I mow.
Sep 01, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet 2165 Mower Shuts Down
did you happen to check the gas cap if the vent is clogged in it ? when it stalls loosen the gas cap and see if it makes a whoosh sound
Aug 31, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Noisey Cub Cadet mower
If the noise is coming from the deck, locate the idle pulley on the deck. there should be 1 or 2 rubber "bumpers" at the opposite end of the pulley arm where it meets the "j" pin. If they are missing, it will make a loud metal to metal sound.
Apr 22, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
221 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
