Question about Acer Computers & Internet
No good computer stuck no good i say
Won't set on
I turn on the computer but the system won't turn on at goes to command prompt asks me if i want to start in safe mode i do so but there is still a problem it won't turn on
i can't get passed the commend prompt
it goes to windows for .7th of a second then it shot down
what is the problem?
thank you for you prompt responce
Levi
  • 52 Answers
While the pc is powered on, load the windows cd into the cd rom and restart the pc by pressing the CTRL+ALT+DEL keys, when the pc reboots you should see a black screen with white letters asking you to press any key to boot from the cd.
Carefully following the options install Windows and then to repair the operating system. NOT the repair console option.
If you are not asked to do a repair then stop as this solution wont work and you will likely need to reinstall Windows.
At this point windows should repair any damage files and reboot. Following the reboot, do not press any key, instead wait for Windows to boot normally, you can remove the cd after Windows boots.
Posted on Jun 01, 2010
I have an HP notebook. I was on Skype with a friend when suddenly it froze showing green colors on the screen. Nothing would un freeze it so I opted to turn it off through the power button. ...
Step 1:
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer also Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
Feb 11, 2013 | Computers & Internet
I had to launch start up repair and the battery died half way through... The laptop now says "Computer build error. File exception failed to find c:/ (etc)" and it won't turn on, just...
Step 1:
Enable VGA mode
Reboot
Feb 07, 2013 | Computers & Internet
Get out of safe mode
if you cant turn it of try shutting it down from command prompt
press windows key+r t
when the run box apears type CMD and press enter
type the following command without quotes "shutdown -s" then press enter and it should shut the computer down, if your computer goes back into safe mode when rebooting turn it off then back on and keep pressing the F8 key until a dialog with text comes up, use your arrow keys and navigate down to the last known good configuration box and hit enter it should work
Dec 17, 2012 | HP Compaq 6735s Notebook
My HP Pavillion dv7 3112sa won't boot and remains
Hi, at startup try pressing f8, this should give you a menu, select 'start windows with last good configuration', this should restore windows to the state before it started rebooting randomly. Failing that...try starting in 'safemode with command prompt' and then do a 'system restore'- press f8 again at start up and then follow the instructions below. this should restore your system to a previous state when the computer wasn't doing random things.
  1. Restart your computer, and then press and hold F8 during the initial startup to start your computer in safe mode with a Command prompt.
  2. Use the arrow keys to select the Safe mode with a Command prompt option.
  3. If you are prompted to select an operating system, use the arrow keys to select the appropriate operating system for your computer, and then press ENTER.
  4. Log on as an administrator or with an account that has administrator credentials.
  5. At the command prompt, type %systemroot%\system32\restore\rstrui.exe, and then press ENTER.
  6. Follow the instructions that appear on the screen to restore your computer to a functional state.
I hope that this helps you to sort out the problem. Toni
May 27, 2012 | HP Computers & Internet
I have an Emachines EL1200-07w desktop
  7. Set your computer back to the state when it was working fine.
May 06, 2010 | E-Machines eMachines Desktop PC
My toshiba L500 wont boot up when i turn it on it starts to load files then stops and tries to repair the problem but it does not
There are so many reasons boot up; i.e if system files corrupted by virus or hard disk index tables corruption or hdd partions corruption.
So as a initial trouble shooting try to do following things to resolve problem.
Option 1:
1. Power ON your computer and Press F8 key to have Windows boot menu option
2. Select "Safe Mode with Command Prompt" and Press Enter
3. When command prompt loaded then type follwing command and press enter
chkdsk /r c:
(If this command is not working in "safe mode with command prompt" then start computer with Bootable CD and Press "R" key when first time asked. It will open recovery console and type this "chkdsk /r "command again to repair disk.)
This command will scan your hdd and repair disk errors.
Option 2 :
To repair your windows without losing your data.
Start Computer with bootable CD
Press R when it is asked to press.
It will repair windows.
Note : Please read Status Bar and screen messages /nstructions carfully (while Booting computer thru Bootable CD)
Mar 28, 2010 | Toshiba Satellite L505ES5015 NoteBook
My computer can't send information to my x5650 because there supposedly a document being deleted but it's been working on deleting the file for 5 day now. Answers?
If you have a Windows OS, you can delete the items in the queue from the Run command (repeat twice to delete and then restart) or the Command Prompt. From the Start Button, All Programs, Accessories, Command Prompt. Type "net stop spooler" without the quotes then hit enter. When the prompt returns, type "net start spooler" enter (again without the quotes). Once that finishes, restart your computer. (If you only use the stop command, restart and login to the computer. Then go for a coffee break.)
I hope this helps.
(this set of commands has worked from Win2K through Win7; I think it also worked on older Windows systems but don't remember since my printers were parallel port and didn't have items get stuck in the spooler then.)
Mar 09, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
How do u do a system recovery if it wont let u start in safe mode, it tries but goes back to the advance option menu
source: http://support.microsoft.com/kb/304449
To start System Restore using the Command prompt, follow these steps:
  1. Restart your computer, and then press and hold F8 during the initialstartup to start your computer in safe mode with a Command prompt.
  3. If you are prompted to select an operating system, use the arrow keysto select the appropriate operating system for your computer, and thenpress ENTER.
  5. At the command prompt, type %systemroot%system32 estore strui.exe, and then press ENTER.
Oct 29, 2009 | E-Machines T5082 PC Desktop
XP password problem
hey, its better to setup a password for the account vs not haveing one, the limitation for now allowing to login with no password on command prompt was added becouse a hacker could easyly take over a pc which didnt have a administrative password set up.
To set up the password in commant prompt type
net user Administrator *
Net user <username> * command changes the user password.
Apr 19, 2008 | Dell Microsoft Windows XP Home Edition
Start up
try starting the computer normally, this usually happens if you computers power was cut while booting up, its just a small harmless glitch.  As for the returning back to the prompt try running it with command prompt. when you get to the command prompt, type (chkdsk) and let it run this might also fix any other problems that you are not seeing.
Jan 09, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
