Question about Black & Decker 3.8 AMP 22-Inch Electric Hedge Trimmer #HT512
Can black and decker electric hedge clippers be replaced?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 183 Answers
Simple answer NO
Posted on Jul 27, 2010
My Black & Decker trimmer starts and stops whenever I move the trimmer in any direction -- any advise as to how to solve this problem?
I'm not familiar with your machine, BUT... that description of symptom sounds suspiciously like a bad/poor electrical connection.
The problem could be in many places:
  • plug
  • cord
  • switch
  • brushes
  • internal electrical wiring
The "solution" to this problem is for someone who knows what s/he is doing, to troubleshoot the defective machine, determine the defect, and properly repair or replace the defective part.
Jun 10, 2014 | Black & Decker Hedge Hog 20-Inch 2.8-AMP...
My Mod. 2400, type One is dull--7yrs. old. How do I sharpen it? Thank You
Hey i found this for you i might help. Click on the link at the bottom!!
How to Sharpen a Black and Decker Hedge Hog sharpen-black-decker-hedge-hog-800x800.jpg Maintaining the sharpness of electric timmers can made landscape trimming easier with beautiful results.
Electric hedge trimmers make trimming hedges and bushes easier and quicker than using manual hand-powered trimmers. Electric trimmers, the most popular type in the U.S., cost less and require less maintenance than gasoline-powered models. Electric trimmers are used most often by homeowners with the Black and Decker Hedge Hog series being very popular. While they are not premium products, electric trimmers like the Black and Decker Hedge Hog trimmer can keep trimming reliably for years with proper maintenance, including sharpening the blade's teeth.
Difficulty: Moderately Easy Instructions Things You'll Need
  • Work table
  • Two medium size clamps
  • Dremel tool or similar hand-held multi-purpose tool
  • Grinding wheel attachment for hand-held tool.
  • Dremel 971 (or similar) aluminum oxide grinding sharpening stone with a tip small enough to cover the flat facet of a Hedge Hog blade tooth
    • 1 Unplug the electric trimmer before trying to sharpen the teeth.
    • 2 Clamp the electric trimmer to the work table using two clamps if necessary so the Hedge Hog is firmly held down with the blade teeth accessible over the edge of the work table.
    • 3 Insert and secure grinding tip in hand-held multi-purpose tool.
    • 4 Maneuver the grinding tip so it is perpendicular to the facet of the Hedge Hog tooth.
    • 5 Sharpen teeth in one direction, being careful to try and maintain the same cutting edge angle on the sharpened tooth of no less than 35 degrees.
    • 6 Make same number of grinding passes/grind the same length of time a few seconds on each tooth.
Tips & Warnings
  • This task should take about 15 minutes.
  • Keep a light touch; too much force can break the grinding surface.
  • For best results, insert the sharpening bit slightly less than all the way into the tool.
Read more: How to Sharpen a Black and Decker Hedge Hog ' eHow.com http://www.ehow.com/how_7163131_sharpen-black-decker-hedge-hog.html#ixzz1XsAosvvl
Sep 13, 2011 | Black & Decker Hedge Hog 24-Inch 3.0-AMP...
I need to clean and sharpen a model hh2450 hedge clipper blade. How do I remove/replace it?
You do not have to remove the blades to sharpen. There is a good instructional video on sharpening hedge trimmer blades on youtube. The guy that did it is ereplacementparts i think.
I hope this is helpful for you.
Aug 30, 2011 | Black & Decker Garden
When i was trimming the motor stopped. I was told an electric trimmer cannot be fixed. true or false.
False, almost everything can be fixed unless it is so old you can find replacement parts. However, seeing that you are talking about a $40 hedge trimmer it would probably be cheaper to buy another unit. Black and Decker parts are available online, search by the model number or product number, not the name.
Aug 09, 2011 | Black & Decker 22" Electric Hedge Trimmer
Black and Decker 22" electric
I do not know of a reset. Most likely you damaged the wire and have to repair that section, or replace the wire.
If really helpful, please rate.
Jul 12, 2011 | Black & Decker Electric Hedge Trimmer
I have a Black and Decker 17" Hedge Trimmer
id check the electric motor first, was it whining when it was going? like maby the brushes in the motor are worn out. if so u can maby get replacements
Mar 22, 2011 | Black & Decker 17 in Hedge Trimmer
Do I ever need to sharpen? If I do, how?
How to Sharpen a Black and Decker Hedge Hog sharpen-black-decker-hedge-hog-800x800.jpg Maintaining the sharpness of electric timmers can made landscape trimming easier with beautiful results. Electric hedge trimmers make trimming hedges and bushes easier and quicker than using manual hand-powered trimmers. Electric trimmers, the most popular type in the U.S., cost less and require less maintenance than gasoline-powered models. Electric trimmers are used most often by homeowners with the Black and Decker Hedge Hog series being very popular. While they are not premium products, electric trimmers like the Black and Decker Hedge Hog trimmer can keep trimming reliably for years with proper maintenance, including sharpening the blade's teeth.
  • Work table
Tips & Warnings
Oct 17, 2009 | Black & Decker Hedge Hog 24-Inch 3.0-AMP...
I have a black and decker hedge trimmer g25?
just take it to a electronics service shop that can resolder it for you
Aug 05, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker 3.8 AMP 22-Inch Electric Hedge Trimmer #HT512 Logo
154 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
