Question about GE Profile DPXH46EAWW Gas Dryer
GE Profile gas dryer won't ignite
Model inside door = 4DPXH46GA6CC. Drum turns; controls appear to be working.
Clicking noise when started; never stops until I kill the cycle/power.
I've rebuilt line and dryer gas connections. I have gas pressure to the dryer.
  • GE Master
  • 43,501 Answers
Hi, If you have a gas dryerGE Profile gas dryer won't ignite - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check ouGE Profile gas dryer won't ignite - 2_bing.gif that I wrote about this problem...
Dryer2_bing.gif TrouGE Profile gas dryer won't ignite - 2_bing.gifg2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jun 04, 2010
Start button starts dryer and dryer stops when button is released.
Ge dryers have a belt sensing switch inside that won't let the dryer run (just as you describe) when the belt breaks or comes off. My guess is you broke a belt. With door open---hold in button door switch and hit the start switch to get it too run a few seconds. Watch the drum and see if it turns. My guess it will not. Belt is a long skinny band that goes all around the drum outer area and then down around the motor.
Jul 09, 2015 | GE GTDP180GDWW Gas Dryers
Where is the igniter located on a ge profile dryer
You need to take the front off the dryer and it will be alongside the gas tube going inside the combustion chamber. The igniter is one of those curly wand types and has a quick disconnect connector on it and is secured with a couple of screws.
Here are some diagrams that might help you:
GE Gas Dryer Parts Model DPSR513GA
Good luck.
Oct 17, 2014 | GE Profile Prodigy DPSR513GA Dryer
How do I Disassemble a GE Profile Dryer to replace Drum Bearings? Model: DPSQ475ETOWW?
remove 4 torx screws from the top of control panel,then slide control panel sideways till you can lift it up off the top cover,then open the dryer door on the upper door land area there are 2 screws going up into the top cover remove them then you can remove the top cover,then on each side at the top there is a screw holding the front panel in place,remove these then you can remove door switch wires from the door switch and lift up on this panel to remove it off the gussets on the bottom of the door,then you can install the top door bearing and 4 drum slides
Nov 29, 2012 | Dryers
Kenmore 80 series electric dryer Model - 110-60882990 The dryer won't turn on. Once the start button is pushed it makes a single clicking noise. If I open/shut the door and push the start button...
check the actual door switch,, you can jumper it to see if this is the problem, Just connect the 2 wires together , if this cures the problem replace the switch
May 25, 2011 | Dryers
My ge he gas dryer is not igniting
your dryer may have a spark igniter or a hot wire igniter .. those go bad after so many hours .. if you look in where the flame usually is .. as your start the dryer, you should see a small glowing wire if its a hot wire igniter .. or you should hear clicking and see sparks if its a spark igniter .. if you dont see/hear either then thats likely your problem .... both of those parts are available from washer/dryer parts distributors or GE parts on the internet .. but you have to know the make and model number of your dryer .. you should find that on a tag inside the door or on the back. .. if it actually ignites but quickly shuts off then you probably have a clogged exhaust hose or lint filter chamber .. it reqires a large unrestricted air flow thru the machine. if that is blocked then a sensor shuts off the gas in just a few seconds . . i am assuming that the drum is turning .. if not then thats a whole different problem ..
Oct 07, 2009 | Dryers
GE Dryer DWSR473GV0WW periodically just hums when turning on switch
if it hums when you start it means switch is ok. problem may be the motor capacitor. to check, take off the top and give the drum a push in the normal direction of rotation. if it goes then motor capacitor is faulty - cheap part
Mar 28, 2007 | GE Profile DPSB619ED Electric Dryer
GE Profile DPXH46EAWW Gas Dryer Logo
270 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
