Question about Rival SCVP550 55Quart Slow Cooker
When I plug in my crockpot, power light blinks, crockpot does not heat. when pressing off button, power light keeps on blinking. what can I do to mke it work ? Marie
2 Suggested Answers
SOURCE: All Three Lights Blinking
We have their 6 quart Crock Pot. Same problem cited here!
We have found that, if you press both the (Low/High/Warm) AND the (Off) buttons at the same time, the controls will revert to the proper state. It has worked for us on several occasions so we trust it and have found no "adverse results"!
Hope this is a help to others.......
Posted on Jan 13, 2008
I bought a used little crock pot with no manual. It has only "on" and "off" settings. What temperature would that be?
When it's plugged in, it's "on". All Rival crockpots heat up to simmer, which is about 209 degrees, and then stay there. So whether it's "Low" or High" or somewhere in between, it will heat to the 209. I got this information from the Rival web site when I was researching for information on my 1 qt. and 2 qt. crockpots that I have no manuals for. There's a manual for the 1.5 quart online but after I printed it off, I lost the URL. Go to www.crockpot.com -- maybe that will get to the manual, or at the least, it should give you a Customer Service phone number to call to request one, or directions where to find it online.
Sep 19, 2010 | Rival 3215-WN 1.5-Quart
Tip
West Bend Crockpot EO1 Error Code
<p>Your crockpot is giving you an <b>error code EO1</b>. Now you need to know how to get the code off of your crockpot so that you can use it. <br /> <p><br /> <br /> <p>First, let me explain what the code means. That code tells you that your <b>temperature sensor</b> did not calibrate correctly. Do not worry, this is usually just a temporary situation and the sensor can be reset through a few very simple steps.<br /> <p><br /> <br /> <p>The first thing to do is to unplug your unit from the electric socket. Leave it unplugged for at least ten seconds.<br /> <p><br /> <br /> <p>Then plug it back into the electrical outlet.<br /> <p><br /> <br /> <p>When you have it plugged back in, hit the <b>POWER</b> button once and then within one second hit the <b>COOK</b> button once.<br /> <p><br /> <br /> <p>Now the appliance should be ready to use.<br /> <p><br /> <br /> <p>If you have the problem again just repeat these steps to clear the error code.<br /> <p><br /> <br /> <p>This is how you can easily <b>fix the EO1 error code.</b><br /> <p><br /> <br />
on Feb 08, 2011 | Crock Pots & Slow Cookers
Turned on pot and power light keeps blinking. Cannot set to hours needed to cook.
Purchased a new crockpot from Hamilton Beach to resolve this issue.
Jan 01, 2010 | Rival Crock Pots & Slow Cookers
I just put some precooked, still warm food in my crockpot. I tried to set the control to warm so I could serve later. Can't get warm to turn on. How can I?
To better diagnose your problem I need more information. Does your crockpot have a light that indicates when your heating element is ON? If so, increase the temp of the crock pot knob to find out if the LED light comes on at all. (you may also wish to make sure the unit is plugged in and the outlet is working properly.)
Since all crockpots work using a temp sensor, it could be that the temp of the food is still warm enough that the crockpot thermostat is not calling for additional heat to maintain the temperature. If you can, remove the crockpot liner and let the unit cool somewhat to allow the thermostat to return to room temp and reset.
If this doesnt solve your problem, chances are that the sensor/thermostat may be faulty or one of the circuits to the heating element may have overheated causing a wire to become disconnected or burn out. Appliances can wear out with use or age and even power surges can 'fry' delicate circuitry.
May 18, 2009 | Rival 38601 Smart Pot 6-Quart
How do I get both 8 hours time and high setting on this crockpot?
I got it on high for 1 hour and then reset it to low for 7 more hours and everything appears to be fine. I suspect that this crock pot runs at a little higher temperature. The *low* setting seems as hot as my older crockpot on high...... With this crock pot - set the hours while turned off with the right button and then turn it on. You may have to play with it several times to get the proper heat setting. As I said, I could only keep on it *high* for 1 hour.
Nov 22, 2008 | CorningWare SC60 Slow Cooker
Crock pot lost power
the crock holds heat even after being turned off...so your food was still cooking for the 30 min it was off!
Oct 27, 2008 | Rival 3755 5.5-Quart
All the lights are flashing
My father-in-law just Fonzied this one after a day of us all trying to fix the crock pot.
Press the "High-Low-Warm" button REALLY HARD. It's worked for us twice now.
Oct 12, 2008 | Rival 38651-C 6-Quart
It wont heat up and all the lights just keep blinking
I have the same problem EVERY time I want to use the crock pot. My solution has be patience. I find that if I turn it on, and the light blinks, but when i click it it will blink on 4 hours, then go back to the blinking light. By keeping the crock pot plugged in and off for about 10-15 minutes I was then able to set the crockpot up for cooking. As if the capacitors inside the unit needed power stored in them from the wall.
Dec 21, 2007 | Rival 5865-W 6.5-Quart Slow Cooker
Green light is blinking, but I am unable to trun the power on.
rival smart pot 38651 crock pot all light blinking
to reset this you need to hold both thye right and left button for 30 seconds. the cause of this is from unpluging the unit when it is on also a power failure will cause this. if this does not work hold all four buttons in. they only tell you this if you get the right person at Jarden Consumer Solutions
www.crock-pot.com
Oct 30, 2007 | Rival 38601 Smart Pot 6-Quart
Jan 28, 2007 | Rival 38651-C 6-Quart
Rival SCVP550 55Quart Slow Cooker Logo
2,075 people viewed this question
Top Rival Crock Pots & Slow Cookers Experts
Jerry Greenberg
Jerry Greenberg
tsalagi152
charles
Are you a Rival Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
