Question about Yamaha RX-V661 Receiver
Bad Speaker A/B switch on RX-V661?
I have two pair of external speakers for my yard that are connected to a speaker switch box, which I connected to my RX-V661. Up until very recently, when I would press the "Speaker A/B" button on the receiver, the surround sound speakers in my family room would go on in "A" mode and then go off in "B" mode (and my speaker switch box would go on in "B" mode which allowed me to listen on the yard speakers). Lately, though, when I switch to "B", some of the family room speakers remain on and the power output to the exterior speakers is diminished. I made no changes to my setup when this happened. Why won't the "A" speakers turn completely off when I switch to "B?"
    President:
  • 1,851 Answers
I think I know where your problem is. But first of all, in order to avoid misunderstanding let me clarify something. Do you use an external speaker switch box? If it's possible could you tell me the brand - model.
Waiting clarification, don't hesitate to post.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Jun 01, 2010
No sound from zone 2 speakers on yamaha rx-v661
Have you gone into the speaker configuration menu and turned on zone 2?
Oct 18, 2013 | Yamaha RX-V661 Receiver
Yamaha rx v473 cuts off
disconnect all speakers, turn it on. If it stays on, connect one pair of speakers at a time and when it shuts off, that speaker is the problem. There may be a short in the wire or the speaker may be bad. If you get that far, try connecting the bad speaker with another speakers wires.
Jan 14, 2013 | Yamaha RX-V473 A/V Receiver Black
Will not power up
Many receivers are built with relay protection on all speaker outputs. Very handy if there happens to be a questionable speaker or maybe a short circuit in the speaker wiring. What happens is the receiver checks each load on the speaker outputs and if it senses a problems it won't activate the relay to switch audio to the outputs.
Pull you system to pieces, speakerwise, and check if there is a broken or shorted connection. Repair the cable and switch the receiver back on to see if you've solved the problem. If it hasn't then a trip to your friendly repairman may be in order. An interal problem can cause similar clicking noises. But I wouldn't recommend poking around the innards if you are unsure of your abilities.
Apr 06, 2010 | Yamaha RX-V661 Receiver
Look at inside at capacitor and fuse but they seem ok. again once i turn it on, it would automatically shuts off after a second.
When a system shuts down after a few seconds it is the self protect circuit shutting down power to the outputs to prevent (further) damage. It may be caused by frayed speaker wires, bad speaker voice coils, or blown output transistors. First, turn off power and remove all speaker wires from the receiver. Turn it back on and see if the problem remains. If it works OK, inspect each speaker wire at both ends for loose strands and correct these. Then, hook up your speakers one at a time until the problem reappears. That speaker or its' wiring is your problem. For safety's sake. turn the receiver off before connecting each speaker. An accidental short of the output terminals can be disastrous (and expensive).
Right speaker dead on zone 2 on my RX-V 1600 receiver
must be the right speaker wire, sounds to easy I know but maybe your wiring is grounding out the audio to that channel.
Jul 15, 2009 | Yamaha RX-V661 Receiver
Multiple speakers on zone 2 0r 3 speaker output terminals
I wouldn't hook anything up except what Yamaha recommends to the speaker output terminals. That's pretty much asking for trouble!
barneyluc
Oct 10, 2008 | Yamaha RX-V3800 Receiver
I have a new RX V661 7.1, shuts down when I turn it up.
How much loudness are you trying for. Also, the program material and bass/treble settings factor in when asking a system for increased power...accordianman
Jun 19, 2008 | Yamaha RX-V661 Receiver
Zone 2 connections
go into your amp settings menu then to speaker settings,set zone 2 on and main on, turn up the volume for zone 2 about half way then connect phono cables from zone 2 pre out to a input on the external amp (eg cd input )
never use the phono input this is for turntables,connect this amp to your speaker switch/selector then to speakers.
hope this helps
cable guy.
Jun 04, 2008 | Yamaha RX-V2500 Receiver
Setting up Cable with HDMI
Yes, the firmware on your hdtv box has an old firmware, I switched my old hdtv box with a newer one box and the problem was solved. It seems that it can't work if your hooking up with DVI to HDMI cable to your receiver to tv. Your hd box must have an HDMI out otherwise it causes problems. I also have rx-v661 and i finally hooked up everything HDMI to the receiver and then to the tv and it was having the problem you speak of. After I switched out the hd box for a newer one everthing worked fine.
May 13, 2008 | Yamaha RX-V661 Receiver
Cannot figure all of the setup instructions
is your problem setting up? connecting the speakers and sources or you have made the speaker connections but to make it sound is your problem... pleased let me know.
Mar 31, 2008 | Yamaha RX-V661 Receiver
Yamaha RX-V661 Receiver Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
