I have a GE front load washer model number WBVH6240 that powers up but will not come out of the pause mode. When you press the start/pause button, it beeps twice but stays in the pause mode. Any Ideas??
  • Washing Mach... Master
  • 8,220 Answers
Pause mode:
The control is stopped by user during the execution of a cycle. LEDs and 7-segment
display on front panel stay on, all loads are turned off. The door is unlocked. The control
board is ready to take user input to either modify, resume, or cancel the cycle.
Cause: Specific failures associated with the control board can initiate error codes E52, E57, E58, E70, and E71
Service test mode begins on page 51 of this SERVICE MANUAL
Posted on Jun 01, 2010
  • 4 more comments
  • Dan Webster
    Dan Webster Jun 01, 2010
    No exact answer can be assessed without performing the service test mode.
  • randyswise Jun 01, 2010
    Per the instructions on page 51 of the service manual you sent me, I powered the machine down for a few minutes, then powered up and made sure the screen was clear and blank. Then pressed signal, delay, signal, delay and it beeps as though it is dooing something but nothing shows up on the screen and it does not enter into the test mode. It still powers up like normal but when you press the start but it stays in the pause mode and does not lock the door or do anything else
  • Dan Webster
    That must be a stuck button
  • randyswise Jun 02, 2010
    If the button was stuck wouldn't the machine be beeping all the time and not just when I push the button????
  • Dan Webster
    Dan Webster Jun 02, 2010
    You probably gonna need to replace the control
  • Eric Jul 04, 2013
    How do you replace the control?
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
Testing the control panel for damage on a front load washer
How to Diagnose Washing Machine Control and Program ...
? 9:08
https://www.youtube.com/watch?v=QYPqpjLV7s4
Nov 11, 2013 - Uploaded by eSpares
I have a bosch front loading washer that's doesn't have code board. .... there's a clicking behind the front ...
[PDF]GE Front Load Washer - Atech Appliance Repair Service ...
www.atechappliancetechnician.com/GE_Washer_FL_WBVH6240__WC...
Louisville, Kentucky 40225. 31-9135. GE Front Load. Washer. WBVH6240. WCVH6260 ... damage. The man u fac tur er or seller cannot be responsible for the ..... Service Test Mode . .... accessible on the control panel's 7-segment display.
Jan 05, 2016 | Washing Machines
My question is; the washer,model,wbvh6240 has any filter
No , all new front loads have a self cleaning filter. Therefore nothing needs to be emptied or clean. The little trap door in front of the washer is to drain it in case of a power failure when the washer is full of water. .
Mar 15, 2011 | GE WBVH6240F Front Load Washer
Have a new ge WCVH6800 front load washer. Power was interrupted during washing cycle. Machine now stays in drain mode, stops after 3 minutes, door unlocks and start/ pause button flashes. How do you...
Hello there and welcome to fixya
You may want to try unplugging the machine for a minimum of 2 hours to let the internal cpu to reset itself then plug it back in then press the mode button then try to lock the door and it should be ok after that ok please inform me how this goes there is more we can do for this ok
Best regards Michael
Feb 28, 2010 | General Electric WCVH6800J Front Load...
GE WBVH6240 Front load washer. Pump running while empty
you would need to go into the fault codes and read them. the tech sheet should be under the lid or in the kick panel
Feb 07, 2010 | GE WBVH6240F Front Load Washer
My washer will not start. I press the start/pause button and it just beeps twice and does not lock door or start wash. ge adora model wcvh6260
clean the drain filter located behind the front lower panell, its prob. holding excess h2o and wont let the water fill cycle activate. this happened to mine.
Aug 11, 2009 | GE Energy Star WCVH6260F Front Load Washer
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
Control Lock is on my front loader.
ok, you are in the model selection part of the service mode. for 6240 I believe the model code is 3 select this and press start. normally to release control lock press and hold small I button by start button.
if model selection in incorrect it can still be corrected. only difference in models is cycles matching the labels. you can tell by the time indication for each cycle if it doesnt look right then check book inside top cover
Mar 29, 2009 | GE WBVH6240F Front Load Washer
Ge profile front load washing machine demo mode
I called General Electric and this is the solution:
unplug the machine for 2 to 3 minutes.
Plug it back in the wall
Do not put the power back on.
Open the door
Press the start/pause button 5-6 times
The display will say demo exiting...
This works. Also don't forget to remove the shipping bolts before starting your washing machine!!
Good washing!!
Jan 04, 2009 | Zanussi IZ141W Front Load Washer
GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
Apr 23, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
174 people viewed this question
Top Washing Machines Experts
