Question about eMachines E620-5885 Notebook
My e-machine e627 Laptop requires password to access setup configuration, or to boot windows vista , also it shows that hard drive requires password too , how to unlock or reset this password.
My laptop takes an age to boot up sometimes over 10 mins. I would like to wipe the hard drive and re install windows vista. The laptop came with vista pee installed so I do not have a boot disc. HELP,
You didn't say the make/model of your laptop so this answer may not work for your specific laptop but then there is nothing to lose in trying it. Usually if the laptop comes with pre-installed windows and you have never loaded it with anything else, there will be a factory image in a hidden partition on the system's hard drive. On powering up the laptop, usually while the manufacturer's logo is showing on the screen, you would press the Alt-key and hold it down while pressing the F10 key repeatedly. This should access the laptop's recovery or restore to factory image procedure. Wait for it to load completely and then follow the on-screen instructions to do the restore. Note that the restore will erase all user data from the hard drive including any malware or viruses that might be on it. Once restore is complete, you will have to re-enter your initial system configuration again such as the windows user ids and passwords. Also, if you were accessing wireless, you would need to reselect the SSID of the access point, and re-enter the WEP/WPA key if encryption is being used.
May 26, 2011 | Computers & Internet
How do i reset the bios password for my lenovo a310?
User passwords:
Power on
BIOS execution can be controlled by a Power On Password. This password is set in the BIOS Configuration screen, accessed by pressing the F1 key after pressing the power on switch to turn on the PC. If the person at the keyboard does not know the Power On Password, then BIOS execution halts.
Hard drive
The hard drive is controlled by the Hard Drive Password. After the Power On Password is entered, the person at the keyboard must be able to enter the Hard Drive Password, otherwise the disk drive will not spin up for use. Like the Power On Password, the Hard Drive Password is set in the BIOS configuration screen.
Administrative passwords:
Each of the two user passwords can be controlled by a Master or administrative password. If the administrative password is not set, then anyone who knows the user password can change it in the BIOS configuration screen. If the administration password is set, then it is impossible to reset the user password unless you know the administrative password. The Supervisor Password is the administrative password for the Power On Password. The Master Hard Drive Password controls the Hard Drive Password.
Password Recovery is a feature of Client Security Solution 6.0. This makes it possible for an end user to recover from the problem of "I forgot my Power On Password or Hard Drive Password."
c.gif fw.gif Client Security Solution
Mar 13, 2011 | Lenovo IdeaCentre A310 Laptop
Dont have password
There are two sections (that come to mind) when a password is requested in starting a computer. BIOS or Windows Passwords.
WINDOWS PASSWORD This will be after the windows logo as come up. Depending on which version of windows you have, you will need to find a windows password reset tool.
A lot of these will require you to boot from a CD that you have created from an ISO image. If this is is confusing, head into a computer shop and ask them to do it.  Alternatively, reformatting the machine by reinstalling windows over the top should eliminate the problem (and all of the data that is still on the machine.)
BIOS PASSWORD This will usually be during the 'black screen' phase of booting.
An IBM ThinkPad laptop can have three BIOS hardware passwords set
  • Power-On Password
  • Hard Disk Password
  • Supervisor Password
Power-On Password
RT/CMOS RAM has 8 bytes reserved for the power-on password and the check character. The 8 bytes are initialized to hex 00. The microprocessor can access these bytes only during POST. After POST is completed, if a power-on password is installed, the password bytes are locked and cannot be accessed by any program. During power-on password installation, the password (1 to 7 characters) is stored in the security space. Installing the password is a function of the built-in system program Easy-Setup. The power-on password does not appear on the screen when it is installed, changed, or removed. After the power-on password has been installed, it can be changed or removed only during POST.
Hard Disk Password
The hard-disk password (HDP) protects the data on your removable hard disk drive from being accessed by unauthorized persons.
Supervisor Password
The supervisor password protects the system information in Easy-Setup from being changed by unauthorized persons.
How to Reset an IBM ThinkPad Power On Password using Software If you can boot the IBM ThinkPad, KeyMaker will recover the BIOS password.
How to Reset an IBM ThinkPad Power On Password Using Hardware If you cannot boot the ThinkPad, you will have to reset the IBM ThinkPad password via hardware. If only the power-on password is set, do the following to remove the power-on password. Power off the computer Remove the DIMM (Memory) cover on the bottom side of the computer. Short-circuit the two password pads or put a jumper on the contacts to short the circuit. Under the short-circuit condition, power on the computer and wait until the POST ends. After the POST ends, the password prompt does not appear. The power-on password is removed. Reinstall the DIMM cover.
If both the power-on password and the supervisor password are set, do the following to remove the passwords: Power on the computer by pressing and holding F1. Enter the supervisor password. The Easy-Setup menu appears. Click on the Password icon. Click on the Power on icon. Enter the supervisor password and press the Space bar. Press Enter twice. Click on Exit; then click on Restart.
May 21, 2009 | IBM ThinkPad Z60T Notebook
My brother just gave me his hp pavilion dv4-1313dx laptop and i want to reinstall windows vista. how do i remove windows xp? i just want to clean all of his garbage out of my laptop then reinstall vista,...
First check the System requirements The following list describes the recommended minimum hardware requirements for basic functionality of the different editions of Windows Vista. Actual hardware requirements vary, depending on system configuration and on the programs and the features that you install. If you install Windows Vista over a network, additional hard disk space may be required.
Windows Vista Home Basic
  • 800-megahertz (MHz) 32-bit (x86) processor or 800-MHz 64-bit (x64) processor
  • 512 megabytes (MB) of system memory
    Note On system configurations that use system memory as graphics memory, at least 448 MB of system memory must be available to the operating system after some memory is allocated for graphics.
  • DirectX 9-class graphics card
  • 32 MB of graphics memory
  • 20-gigabyte (GB) hard disk that has 15 GB of free hard disk space
  • Internal or external DVD drive
  • Internet access capability
  • Audio output capability
Windows Vista Home Premium, Windows Vista Business, Windows Vista Enterprise, and Windows Vista Ultimate
  • 1-gigahertz (GHz) 32-bit (x86) processor or 1-GHz 64-bit (x64) processor
  • 1 GB of system memory
  • Windows Aero-capable graphics card
    Note This includes a DirectX 9-class graphics card that supports the following:
    • A WDDM driver
    • Pixel Shader 2.0 in hardware
    • 32 bits per pixel
  • 128 MB of graphics memory (minimum)
  • 40-GB hard disk that has 15 GB of free hard disk space (the 15GB of free space provides room for temporary file storage during the install or upgrade.)
Note A Windows Aero-capable graphics card is a graphics card that meets the following requirements:
  • Supports a Windows Display Driver Model (WDDM) driver
  • Has a DirectX 9-class graphics processor unit (GPU) that supports Pixel Shader 2.0
  • Supports 32 bits per pixel
  • Passes the Windows Aero acceptance test in the Windows Driver Kit (WDK
If your computer is compatible follow directions below.
Option 1
loadTOCNode(3, 'summary'); To perform a clean installation of Windows Vista from the current version of Windows on the computer, follow these steps:
  1. Start the computer and make sure that the current version of Windows has started.
  2. Insert the Windows Vista DVD into the DVD drive and then close the drive tray. Wait a moment for the Setup program to start automatically.
  3. If the Setup program does not start automatically, follow these steps:
    1. Click Start and then click Run.
    2. Type Drive:\setup.exe and then click OK.
      Note Drive is the drive letter of the computer’s DVD drive.
  4. When the Setup program starts and the Install now screen appears, click Install now.
  5. When the Which type of installation do you want? screen appears, click Custom (advanced). The follow the instructions to install Windows Vista.
If Windows Vista is now running on your computer, you have completed the installation successfully.
OR
Option 2
Note for the option below The computer must be configured to start from the DVD drive.
To perform a clean installation of Windows Vista by starting the computer from the Windows Vista DVD, follow these steps:
  1. Start the computer.
  3. Restart the computer.
  4. When you receive the "Press any key to boot from CD" message, press a key.
  5. Follow the instructions to install Windows Vista.
Please rate this a fixya
May 18, 2009 | HP Pavilion Notebook
User password lockout - Vissta home premium
you can search for a password boot disk which will disable the administrator password.
There are dozens of these types of programs but one program I recommend is windows password reset 6.0
http://www.resetwindowspassword.com
Download the iso file and burn it to a disk to create the boot disk,
that simple. Configure your pc or laptop to boot in the cd drive,
insert the CD and it would boot then just disable the password and
restart.
Took about 5 minutes for the whole process.
Apr 26, 2009 | Dell Studio 1537 Laptop
I bought a laptop without OS how can i now get vista in it?
You will need to get a windows system disk or install disk and boot up with this in the laptop to load windows whatever into your hard drive and set your laptop up to run on the new drive. Here is Microsoft's tutorial on how to install and set up windows:http://www.microsoft.com/windowsxp/using/setup/winxp/default.mspx
Hope this helps you.
Mar 29, 2009 | Dell Vostro 1510 Notebook
Simpletech external hard drive is showing as write-protected disk
Usually a protected hard drive has been in a laptop and the hard drive password is setup from the laptop's BIOS configuration. This password is embedded on the hard drive's chip.
This password protects the data from unauthorized access and must be removed before reuse in another laptop or as an external hard drive.
There are no backdoor passwords available and needs to be removed using that laptop's BIOS configuration, you need to know the password to enable you remove the password peotection.
Mar 29, 2009 | Sony Computers & Internet
Windows vista will not boot on a toshiba laptop
First try boot options.
On start up press F8, you get different boot options listed.
Select "last known good configuration"
If this doesn't work, try "boot into Safe Mode". Then restart once safe mode loads.
If neither of these work, you may have to attempt a "repair" of windows.
Get a Windows Vista Operating system disk (same version of Vista, Home or Premium).
1. Boot from it (put it in CD drive and restart the laptop).
2. If you still get the same problem start up, you need to set the laptop to boot from CD.
3. Restart laptop, press Delete key or F2, or F12 (it should say one of these on the screen) to enter the Setup. or another key to get "boot options"
4. In Setup (BIOS) Use Right Arrow to find the Boot Options. Use the instructions to move the CD-ROM to first position, above HDD (hard drive). Press Esc, then F10 to save your changes and exit.
5. The Windows Setup CD Rom should now run. It should come to a screen where you are asked to press R to repair windows.
6. When it comes to the command prompt, restart the laptop
Hopefully the laptop should boot OK again.
Jan 25, 2009 | Computers & Internet
eMachines E620-5885 Notebook Logo
497 people viewed this question
Top eMachines Computers & Internet Experts
Michael Vincent Cruz
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
