Question about Dishwashers
Part identification help?
I was having the "dishwasher fills, makes a humming noise and then does nothing" problem that several others have had. Following the excellent instructions found here, I disassembled the mechanism to get to the chopper assy. I presume this is the problem:
So I need to get and install a new chopper assy.
However, when I was disassembling to get to this point, I found two other "bits" of a part that I can't identify. The "bottom" bit was down where the broken chopper bits were, but the "top" bit was on top of the "Protector, Foreign"(Part 9) The only thing I can guess it might be is "Check Valve, Sump" (Part 5) on the same page. But if that's the case, where does it go and where's the "loop" thing?
These are pics of the two bits of the part:
The top obviously snaps into the bottom but other than that, I have no idea. There's no part # (of course), just a "1" on the bottom, and a 2 on the top.
Thanks in advance
  • 2,651 Answers
Part number for the chopper. 8268383
the other picture is of clips that hold down different tines on the upper rack look you should seee others up there giveng you an idea as to where they should go. not real important to the operation,
Posted on Apr 09, 2008
Dishwasher making humming noise fills with water but it doesn't seem to be moving anything
The pump probably has bones or food stuck in it. Take out the racks and see if you use a flashlight, whether you can spot anything in the area of the pump drain.
Jan 31, 2014 | Whirlpool GU2300XTVB Dishwashers : Built...
Dishwasher hums intermitantly and after the wash cycle is completed
Sounds like you have a bearing going out. It could be in the system pump or the rotating washing arms. I would suggest getting ahold of Kitchenaid's customer support and relay when during which cycle the noise occurs and they should be able to identify whats going wrong.
Jan 22, 2014 | KitchenAid KUDE70FXPA Builtin Dishwasher
Dishwasher wont wash! just makes a humming noise
Without knowing the brand and model it makes it a little hard to anser but I can tell you thats the typical sign that there is something wrong with in some machines, the pump/motor assemble, in others the recirulating pump, but a technician should be called.
Apr 29, 2012 | Dishwashers
Dishwasher starts then pauses and drains.
Fixed! I had the issue where the cycle would start, the KUDS30IXBL8 would hum 4-5 times and then drain. Plastic folk pieces jammed in the disposer. These instructions took a few minutes (only 5 screws and a couple clips) to figure out how to take it apart, and it only took 60 seconds to put back together. How To Repair Dishwashers KitchenAid Repair Chopper Replacement
Apr 25, 2012 | KitchenAid Dishwashers
Dishwasher fills with hot water then does nothing
Do you get any humming noise when you turn it ON?
How long its been you used the dishwasher last time...?
If you are getting an humming noise then Sounds like the water circulator pump is stuck. The motor tries to turn it (humming noise), but cannot. So a breaker trips (self reset). Not claiming this is actually the problem, but this is what the motor turns.
Aug 30, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
No water running through cycle once filled....making humming noise once clicks into cycle
pump should be checked for restriction of movement,is there something blocking it?does the capacitor smell?if it does its blown(or meter check-more accurate),hope this helps
May 27, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Washer fills with water then makes a humming
More likely the brushes on the drum motor. Check them first.
Feb 23, 2018 | Kenmore 24 in. 15953 Built-in Dishwasher
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Dishwasher does not fill up with water
could be a couple things, can you hear a humming noise? check your float switch make sure nothing is stuck under it.
Nov 04, 2008 | Dishwashers
Dishwashers Logo
128 people viewed this question
Top Dishwashers Experts
