Question about Dynamic MD95 Handheld Blender
Dismantle Dynamic MD25 blender
The shaft is siezed. I would like information on stipping down the shaft and replacing the bearings and seal. Where can i get spares?
regards Dave
    Problem Solver:
  • 13 Answers
Spares from http://www.nisbets.co.uk/
Take out handle screws, pull apart carefully. Take out pins mounting motor to shaft and pull out motor. Take screw from blade and pull off. Pull out shaft.
Posted on Aug 25, 2010
Making a high pitched noise while blending; is motor breaking down?
there are some Breville Blender troubleshooting tips here
http://brevilleusasupport.com/bbl550xl/troubleshooting . Tied in with that, a high pitched noise could come in from a few directions:
Some blenders will use reduction gears to get more torque and power out of a high RPM, lower power motor. If this is the case, the whine could be from the motor, though if you hadn't noticed before, that would not be reassuring.
Per the troubleshooting, check that the blade is firmly attached, and that the coupling from jug to base is firm. If there are gaps or loos spots, there can be buzzing or whining between sort-of-spinning parts and shafts or bolt threads.
Check the motor base for dried spilled-on margarita mix or marinara sauce or what have you. they try to seal this pretty tight in a blender, but it has to spin, so food spills can get in the gap and cause friction and resistance, which can in turn cause whining noises from parts not expecting the load. If you do any cleaning or poking there, make sure you unplug the blender first. Shocks are not fun.
likewise, make sure that blade rotates easily from turning the coupling on the outside of the jug. If not, the bearing may be siezed or contaminated. That you'd likely want to fix by replacement.
Hope this helps!
D
Nov 19, 2015 | Breville Blenders
Burning smell in the container and outside when in use
Seal under blade Assembly, on shaft leaks, allows liquid to enter bearing, which then fails, creates heat and overheats rubber, thus the smell. Bearing and seal must be replaced.
Jul 11, 2012 | Breville BBL600XL. 5-Speed Blender
Blade on MD95 not spinning
The shaft has probably siezed at the bottom near the blade. The seal can fail and let liquid inside the shaft and gunge it up.
Take the orange handle apart, then unscrew the four steel pins, then pull out the motor. From the blade end, take the screw from the blade and prize it off. Then pull the shaft out from the top and clean it. It may be stuck - push a blunt nail or similar in the bottom to free it. Clean the shaft and solidified debris inside the tube. Then reassemble carefully.
Feb 14, 2012 | Dynamic MD95 Handheld Blender
Motor runs but the blade does not spin
Take the orange handle apart, then unscrew the four steel pins, then pull out the motor. From the blade end, take the screw from the blade and prize it off. Then pull the shaft out from the top and clean it. It may be stuck - push a blunt nail or similar in the bottom to free it. Then reassemble carefully
Dec 04, 2009 | Dynamic MD95 Handheld Blender
Cuisinart model # SPB-6 (tx) leaking when unit is together, seal is in place, still leaking. Unit is not damaged, please advise.
Check if leaking at the bearing for the blade.
If the bearing has worn, dis-assemble and coat shaft with food-safe grease and re-assemble. Also coat the seals with the grease.
Sep 09, 2009 | Cuisinart SPB-6 Smartpower 6 Speed Blender
Bamix stick blender Handle vibrates but shaft does not turn
Old food residue and juices will have got into the shaft bearings, and have dried out enough in 9 years to stop it turning. Starting with the simplest solution, try immersing the shaft in hot, or even boiling, water nearly up to the top of the metal shaft. CAUTION - DON'T BURN YOURSELF! Let it stand in the water for a few hours, and then try turning the shaft by hand (with the machine unplugged, of course). This could be repeated a number of times. You may also be able to unscrew the blade guard after this treatment, bear in mind it has a left hand thread, so if you are looking at it from the bottom, turn it clockwise to loosen. Be careful not to lose any seals or springs when it comes off.
If this doesn't work, support the Bamix upside down, and pour a small amount of WD-40 into the blade guard, so that it pools around the end of the shaft. Leave to stand, and the oil should slowly seep into the bearings, dissolving the food residues. Again, try this a few times.
If neither of these work, the Bamix will need to be dismantled to clean the shaft and bearings. This is really beyond the scope of this forum and requires some experience of this type of work.
Mar 13, 2009 | Blenders
Dynamic mx91. noisy.
dynamic mx91, motor runs but blade doesn't spin, how do i disassemble the blade & shaft?
Feb 08, 2009 | Dynamic MX91 Handheld Blender
Dynamic handheld blender
There is a website,just google NOVON and you can download schematics for your dynamic.Then just go to restaurant supply super store and order parts.
Jul 19, 2008 | Dynamic MDH2000 Handheld Blender
Mx91 Dynamic Blender Bearing failure
Since the blender costs over $600, yes.
Dec 05, 2007 | Dynamic MX91 Handheld Blender
Dynamic MD95 Handheld Blender Logo
112 people viewed this question
Top Dynamic Blenders Experts
eyecam
Ross Keen
Are you a Dynamic Blender Expert? Answer questions, earn points and help others
