Question about Apple iPod nano
Frozen ipod my ipod is stuck on the menu screen and it won't turn off, play music and do anyhing that i tell it to do
  • 236 Answers
You could try to reset it by doing the following:
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If the above step did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on
Posted on Apr 09, 2008
My ipod is frozen it is stuck it will not turn on or off will not play music
Try this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal, and you can now ty re-syncing your ipod in itunes. Hope this helps you!
Mar 07, 2010 | Apple iPod nano
My screen is on language selection and does not let me scroll or anything i think its frozen.
If your iPod is frozen or won't turn on, the steps to reset it vary by model.
  1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
  2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
  3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer does not sleep, standby, or hibernate during the 20-minute charging period.
  4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
  5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
  6. Try putting the iPod into disk mode.
    • While in disk mode, connect the iPod to iTunes and try to restore.
    • If the iPod is still not recognized by iTunes, the iPod should be serviced.
    Hope i helped you.
Thanks.
Aug 06, 2009 | Apple Ipod Nano Second Gen. Green (4 GB)...
My ipod nano is stuck on language selection and is frozen can you help me?
    Hope i helped you.
Thanks.
Screen is frozen
How to reset iPod Nano if it is not responding or frozen.
Hold down the Center and Menu buttons simultaneously. The screen will start to melt away. Then you will see the Apple appear on the screen.
The iPod has been reset sucessfully.
Music files should still be saved, but some customized settings may be lost.
If that doesn’t fix your problem, try a hard reset by holding down Menu and Play/Pause simultaneously for about 10 seconds. A hard reset will clean all data off the unit.
Jul 25, 2009 | Apple iPod nano MP3 Player
Screen on iPod Nano went blank (white)
press the play and pause button then on the bottom of the ipod theres a orange swich and make it turn orange...
Jan 27, 2009 | Apple iPod nano
Frozen Screen I have a frozen screen which says "Disk Mode", then there is a large "tick" in the centre of the screen, and another message saying "OK to disconnect". Nothing I try unfreezes this - I have...
I do not know which ipod you have, but here are instructions on how to get a nano in and out of DISK MODE:
To turn iPod Disk mode off:
  1. Toggle the hold switch on and off
  2. Press and Hold the Select and the Menu button for more than ten seconds
  3. The normal selection screen should appear, your iPod is out of Disk mode.
To turn iPod Disk mode on:
  2. Press and Hold the Select and the Menu button for six+ seconds
  3. Release both buttons when the Apple logo appears
  4. Press and Hold the Select and Play button until the Disk Mode text appears.
If it does not work, you may need to reset your ipod. The following link has extensive instructions on that procedure for many types of ipods.
Good luck my friend!
Dec 28, 2008 | Apple iPod nano
Ipod nano 8GB 3rd generation FROZEN!
You need to reset your ipod. Flip the hold switch on then off, then press select button and menu button at same time. Hold for 10 seconds or so. Ipod should shut off and reboot to apple screen. If this doesn't work first time try again. This should solve any stuck screen problems. Mine was stuck on pioneer screen and this operation fixed it.
Aug 09, 2008 | Apple IPod nano Second Generation MP3...
Error screen and frozen screen
http://ipod.about.com/od/troubleshootingyouripod/ht/reset_ipod_vid.htm
Jan 08, 2008 | Apple Ipod Nano Second Gen. Green (4 GB)...
Frozen screen
my ipod wont turn off or nothing i tried downloading music like i always do and my ipod shows that picture of the plug and it says under it "ok to disconnect" it wont turn off or nothing
Dec 27, 2007 | Audio Players & Recorders
My Ipod is stuck on the menu screen and will not play any music. It won't turn off, None of the buttons respond. Any Ideas
Try pressing the MENU and the Center button together for a couple of seconds. This restarts the ipod.
Hope it works.
Nov 25, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
