Question about LG WM2277H Front Load Washer
Where can I buy bearing balls k121 k125 and k122 to LG WM 2277H?
4 Suggested Answers
  • 278 Answers
SOURCE: leaking under Washing machine LG serie WM
First check all hoses. The hoses inside the unit, sometimes leak and looks like a water pump problem. Does it leak all the time or only when running. If only running , most likely it's the pump. If you and a friend can lift up the front of the unit "tilt" and block it. Use a flash light and look for water around the pump. The pump will be white plastic with 2 hoses running to it. It has to be a hose or pump (90%). I hope this is a start.
Posted on Nov 03, 2009
  • 901 Answers
SOURCE: how do you change drum bearing on lg wm-1290fhb
It is a difficult job in terms of handling! You require spanners and bearing puller. You require one extra assistance to hold the drum and pull from the front.
You have to change the full set of Bearings with same type and design. Check the bearing housing and the shaft before fixing new ones! Replace the water seals if any
Posted on Apr 06, 2010
MNTECH
  • 1543 Answers
SOURCE: How to Replace Bearing Ball on a LG Front Load
The rear half of the outer wash drum (which contains the rear bearing and tub shaft seal) needs to be replaced. On a 1 - 10 scale, this rates a difficulty rating of about an 8. An experienced appliance tech can do it in about 2 hours, and hit you up for about $500. I do not suggest this as a do it yourself repair. Did you know that the new LG machines use a balance ring to make them much smoother running? (Hint: It may be wiser to replace the machine.)
Posted on Jul 04, 2010
How to locate a ball sensor in my lg washer
The Ball Sensor has nothing to do with a "LE" error.
A faulty Hall Effect Sensor or faulty Stator or faulty Main PCB are
suspects..You must remove the Rotor and then the Stator to get to
the Hall Sensor..
Aug 18, 2014 | LG WM-2277HW Front Load Washer
I get a message le or ue error and machine stops
Where in the cycle is the machine stopping?
A 1E error would be a fill problem. Either the water supply is inadequate (low pressure coming in due to a problem with your water supply), the water supply taps aren't fully open (make sure to open the valves fully), the inlet hose is bent (straighten the hose) or the inlet filter is clogged (clean the filter).
An UE error happens during the spin cycle. Either the load is too small or the load is uneven. Add some items that can tolerate the spin cycle speed or redistribute the load.
A LE error indicates that the motor has overloaded. Wait 30 minutes and then try to restart the machine. If the error persists, the unit needs service.
The manual for the WM-2277H* is available from LG as a DjVu file here: http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=WM2277HB&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WM2277HB&initialTab=documents&targetPage=support-product-profile# .
I hope this helps.
May 30, 2011 | LG WM-2277HW Front Load Washer
How to Replace Bearing Ball on a LG Front Load Washer??? The bearing ball is leaking water and makes loud noise. need to fix problem please help.
Jul 04, 2010 | LG WM-0532HW Front Load Washer
How to replace the Bearing Ball on A front load LG Washer? The Bearing Ball on My Front Load LG Washer is Leaking Water and also the tank makes a loud noise while its running. I would like to know how to...
main drum bearing is pressed into the rear outer drum 1/2. you will need to replace that part. hopefully, the motor isn't damaged by the leaking water.
How do you change drum bearing on lg wm-1290fhb washing machine
Apr 05, 2010 | LG WM-1290FHB Front Load Washer
My lg wm 14225fd is making a banging popping
this sonde like the drum needs to be rebalenced this needs to be done once a yr. you well need to call a repair person its covered under your warrenty.
Dec 22, 2009 | Washing Machines
Leaking under Washing machine LG serie WM 2277H.What causes and how to fix it? Thanks!
Nov 03, 2009 | LG WM-2277HW Front Load Washer
Lg 1832cw
Mike, you don't need to yse any glue cause it is a press fit bearing. I had to do the same thing. I was able to go to my local bearing supply for replacements. And it was much cheaper that going to an online place to buy them. It pay s to search.
Jim
Nov 16, 2008 | LG WM-1832C Front Load Washer
Lg 2277h won't spin
More than likely, you have a problem with the balance ball sensor in the back of the unit if it so equipped.  It is located in the back of the unit and will require an LG qualified tech to see what's going on.
Apr 24, 2008 | LG WM-2277HW Front Load Washer
Suspect drum bearings
most lg front loaders have the plastic outer drums which have about 16 h/duty screws holding the two halves together. extreemly tricky to strip to gain access to inner bearing and seal. Th/stat, motor, piping and other items have to be removed and dissassembled to enable drum to be removed. that repair i suggest for a service repair.
Aug 14, 2007 | LG WM-1480FHD Front Load Washer
LG WM2277H Front Load Washer Logo
384 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
