Question about Philips 60PP9352 60" Rear Projection Television
Philips 60PP935217 60 in. Rear
My philips 60" rear projection turns itself off after 3-4 seconds of powering up. The picture never actually comes on, it is just a blank screen and then it shuts itself off
  • Robert Dressler Jan 19, 2009
    Hey did you ever find out what actually happened? I have the exact same problem. Though it used to turn on fully after about 3 times of turning the tv on. Now it wont power on at all. it just clicks and turns off. Any suggestions. Thanks guys.
  • Philips Master
  • 8,617 Answers
I would check the regulator transistors and then the horizontal output tarnsistor.
Posted on Apr 09, 2008
Philips 60PP9352 60 in. tv
seems there are some faulty or failed components in your set.
The mainboard or the powerboard might need to be replaced or some convergence ic chips / capasitors / resistors.
Unless you are willing todo that, I think the best solution is to take it in for service. Maybe another expert will have more exact knowledge on this problem?
Apr 15, 2008 | Philips 60PP9352 60" Rear Projection...
When I turn on my Philips rear projection tv, the power comes on but no picture or sound. power light stays lit solid. If i adjust slowly the screen or focus controls, the picture and sound will come on....
could be a number of things....check for bad solder connections on circuit board around Flyback xformer and also check connections on conversion module for colour problems....double images red , blue , green popping in and out.
May 19, 2010 | Philips 60PP9352 60" Rear Projection...
Philips 55PP9352 Rear Projection, no picture or sound
Mine had the same problem, and it turned out to be the power board.
Dec 20, 2008 | Philips 55PW9363 55" Rear Projection...
Go back recheck where you solder and connections.
Nov 09, 2008 | Philips 43PP9202 43" Rear Projection...
Powers up no picture but shows picture on power down
Try unplugging the three convergence plug wire clips on the SSM board and then try to power up your set, let me know what happens.
Jul 25, 2008 | Philips 60P8341 60" Rear Projection...
Picture problem
philips part# 483520988561 actual part# HCNW136 opto coupler datasheet at datasheetcatalog.com can buy many places just enter it on google.
other fixes philips part# 483520987834 actual # MC34065p and philips# 483520987712 actual# SC78104 some change all 3 and never have a problem again.
Nov 22, 2007 | Philips Magnavox 9P6034C 60" Rear...
Philips 43PP8545
You have no high voltage, like many in this forum, this model of Philips has some of the same problems. Look around here you may find the answer to your set. If not check Vertical IC, TDA8177, audio ic on signal board up front on left. check Power supply first for blown fuse, 1000, 2004, 1300, 1900 etc. No sound or pic means something is open. Does set has L E D lights on front of set?
Sep 02, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 55PW9363
Hi! ronogre,
This set has a defective SMALL SIGNAL BOARD.
Toprol
Jul 31, 2007 | Philips 55PW9363 55" Rear Projection...
When tv turned screen is blank and chirping sound comes from back
A chirping sound usually means that one of the secondary supplies has shorted, most likely the horizontal output transistor. The power supply "chirps", which is the sound it makes when it protects itself from drawing too much current. The set should be serviced by someone with experience in Philips projection TV'.
Jun 21, 2007 | Philips 43PP9202 43" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
147 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
