Question about Brother Sewing Machines
Innoxvie Brother Computerized Sewing Machine
The power switch turns the lights on, but the LCD screen will not display. It beeps every 10 - 15 seconds, but will not display.
I am taking it to the Brother repair shop.
Posted on Apr 09, 2008
SOURCE:
Brother innovis 4000D. Start stop buttons stuck in red, Machine beeping and screen light but blqnk
If your machine was serviced before purchase and now doesn't work, return it to be re-serviced and made functional.
Jul 05, 2016 | Brother InnovIs 4000D Computerized Sewing...
MY lights come on but the LCD screen is blank and it is beeping. Please help
Check that the LCD screen adjustment has not been dimmed or darkened. If that is not the case, then a component is or has most likely failed.
Dec 30, 2015 | Brother Sewing Machines
Touchpad will not work
Brother Project Runway Computerized PC210PRW Limited ...
www.overstock.com > ... > Sewing Machines
Overstock.com
Rating: 4.7 - β€Ž16 votes - β€Ž$359.97 - β€ŽIn stock
With a touch pad operational panel and LED screen controls, the Brother Project Runway ..... How to Troubleshoot Your Sewing Machine from Overstock.com.
Nov 01, 2015 | Brother SE400 Computerized Embroidery and...
Brother 4000D innovis machine....when I turn it on, it will not start up..the lcd screen is faintly lit, and the machine just beeps
I had the same problem Machine off! I took off the rectangular cover on the right side (had to pry it carefully} GENTLY Pushed in connections of wires to board and then plugged in and it worked!! I happened a couple of times They must vibrate loose. All I has to take apart was that rectangle cover
Jan 18, 2013 | Brother InnovIs 4000D Computerized Sewing...
Hello, I have a Brother NX200-Innovis computerized sewing machine. It was sewing like a dream when all of a sudden it slowed down and beeped and flashed "E6" . The balance wheel has completely...
turn the sewing machine completely off
rethread the machine the top thread & bobbin, if possible use a different spool of thread for top & bobbin
then turn the sewing machine on again & see if you still get the same message, if the same message still displays,,then it needs to be serviced
Aug 10, 2011 | Brother NX-400
Have a euro-pro 9110 lcd screen lights up cant see the lettering ?
There should be a small round button on the front of the machine just big enough for your finger tip with lines around the outside like the rays of the sun or an eyelet.It should turn with the tip of your finger.Turn it back and forth for the desired light.If this dosent work you have a a bad display screen.
www.sewvac.com
Feb 01, 2011 | Euro-Pro 9120 Computerized Sewing Machine
Black line down middle of LCD screen Brother
the screen will have to be replaced is it under warranty?
Aug 27, 2010 | Brother InnovIs 4000D Computerized Sewing...
Sewing Machines Logo
173 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
