Question about Equator EZ 3612 CEE Front Load Washer/Dryer
Door handle is broke off
I need to know what to do to fix this problem & how much it will cost
I ordered the part from appliancedesk.com. They had it back ordered, and then cancelled my order. . but eventually it came.
It was about $40 for just the handle replacement and super easy to fix.
Now, if only the click, click, click didn't happen. I think the pump is out, now.
Posted on Jul 05, 2010
Hi there, i broke the handle of the door, the plastic part. Is there any chance to fix it just the door/handle and how much does will cost? ps where to ask for a help someone to fix it? pls help
There is no chance to fix what is broke.
You can go get just the plastic piece and change that out
You can get one from junk yard or dealer
Jun 02, 2016 | Zanussi Washing Machines
2006 Ford Focus outer drivers door plastic handle broke loose from inside where the mechanism is supposed to grab hold of latch & release/open door. Cannot open door from outside. What is the part or...
Cost? Well it depends on the shop labor rate where you take it to get repaired. It should require about 1 hour of labor to replace.
Dorman makes a replacement handle for your vehicle it is Part Number 79354. This same number will fit either the right side or the left side. It costs about $30. (It will probably cost more if the shop supplies the part...They have to mark it up in order to make a profit.)
Feb 23, 2011 | Ford Focus Cars & Trucks
Door is locked, handle is broken, how do I open the door?
YES!!! Samething happened to me!!!
I haven't fixed it yet BUT I know how to get in~You have to take the handle off...completely. May have to break the plastic...
You'll need 2 flat head screwdrivers.
You have to push the metaal part that would have been attached to the plastic handle and then pull the door out where it meets with the machine. Like where the grey inner seal is. Be gentle but firm handed. Think push with one driver~pull out with the other. Be patient as it will be fustrating the first time.
Good luch tho!!!
~yve.
Mar 05, 2010 | Equator EZ 3612 CEE Front Load...
About how much will it cost to fix the outside car door handle
parts & labor about 125.00 depends on what your labor charges are
Feb 09, 2010 | 2006 Dodge Charger
The door handle broke off my GE microwave
Actually the door handle CAN be replaced at a cost much less than pruchasing an entire new microwave oven. And, YOU can repair this yourself and save the cost of a service call. On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
If the model number is correct, the part number is WB15X322. The cost is about $40. Replacements may be purchased at the websites listed in the link I provided.
If you have any questions, or if your model number is different than the one listed, please post back and let me know. I hope this helps you
Dec 31, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Amana Dishwasher Mod. ADB1500AWQ, Door won't open.
HI,
Please check whether the plastic pins are broken.
I removed the inner door panel and found the handle broken. It has integrally molded plastic pins that provide a pivot for the handle to push against the release assembly. These were broken off. Also noticed that there were some small fingers molded on the back of the switch panel that were snapped off. I'm not sure what these are for and I can't see how they are needed for the latch operation. My hunch is that they aid in positioning the handle during factory assembly. I'm NOT going to buy a new switch panel to replace these!
I don't know why the handle broke but it did so in stages. I think one pin broke, and then everything else broke because of added misalignment and stress. The good news: a new handle only costs about $10 and I'll have it in a couple of days. Thanks
Apr 24, 2009 | Amana 24 in. ADB1500AW Built-in Dishwasher
Broken passenger door handle
Same problem. I have a 2000 Suzuki Esteem GL. A year ago the driver's door handle broke. Heard a sound and then it was loose. Could not open it from outside. Had to open front passenger door, open the driver's door from inside and then go out again to enter from the driver's door. FRUSTRATING. My mechanic had to take the door apart to fix it. Just a week ago, my front passenger door died on me. Can't open it from outside nor inside. The door won't open. This is such a stupid problem that costs lots to repair. Never will buy a Suzuki again. Had too many problems with it (had to fix gas tank, doors that won't open, front axle...).
Feb 05, 2009 | 2000 Suzuki Esteem
Outside door handle not working
i have a 94 2dr cutlass and the same thing happend to me, now i can tell u how to fix the problam but the door has to be open to fix, so if your in the same boat i was with both door handles broke then there was only two ways i could think of to get the doors open with both handles broke, ether go threw the trunk and break the seat of break a widow witch is what i did, and once ur window is broke dont replace glass untill handles are fixed. what u do is once the door is open look on the inside behind handle and there is a black cover that has a few screws on it, remove this and u will have a perfect view of the lever assembly, i went to my local junk yard and got me two handles that were that were in good shape, and one u see how it works its a pretty easy fix
Dec 20, 2008 | 1994 Oldsmobile Cutlass Supreme
2001 Nissan Quest - Broken Exterior Sliding Door Handle
you can do this. you have to remove inside trim panel for access. if you still need to do, I will send you repair steps. let me know
Oct 16, 2008 | 2001 Nissan Quest
Broken door handle on GE microwave oven
hi stormy
door handles are usually model specific, but I think your serial # may be JVM140K02. look that up at a partstore web site and see if it matches
Mar 31, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Equator EZ 3612 CEE Front Load Washer/Dryer Logo
75 people viewed this question
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Dan Webster
Dan Webster
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
