Question about Hitachi 65TWX20B 65" Rear Projection Television
Screen that covers speakers has a stain on it. How do I replace the screen I want to purchase a screen and change it out.
  • 505 Answers
You local service center can usually get you a part, as long as its available. you can try to pop off the grille and clean with water, maybe take outside and blast it with a hose, not a perfect fix but might improve your situation.
Posted on Jun 01, 2010
Just bought the Ace 2 gal poly deck sprayer but it will not spray just puts out a stream of stain..is there something extra I should have purchased to get this to spray ??
I had the same problem. The deck sprayers are meant for thin liquids, not the heavy stains. Some stains have a thin consistency, others are thick. You can go back and buy a thinner agent for your particular stain, but , in my experience doing that, it thinned it too much, the color was off and didnt cover right. I ended up using a roller and brush to do the job right.
Sep 19, 2011 | Ace Hardware Ace 2Gal Home and Garden Poly...
32" ILO
That is probably liquid inside the LCD, only way to fix it is by replacing LCD display.
Sep 11, 2008 | iLO 3200 32 in. LCD Television
We just turned on our Aspire 5332 and the screen is blue with a pink and black ink stain river running through the screen. What could this mean?
This would indicate a damaged/failed LCD screen. If the systems is new or covered under warranty return it to the store from which you purchased it. Otherwise you will want to go to Acer Customer Support to get additional help.
Feb 28, 2011 | Acer Aspire 5241 5251 5332 5334 5338 5516...
Where can I purchase a replacement seat for Maclaren xt? I tried washing it, but stains didn't come out. Thanks.
Hiya,
You can try eBay.
Also I use soda crystals it marvellous for removing stains from buggy seat covers, it just loves it!
Try it and let me know how you get on.
Regards,
Liz.
Sep 30, 2010 | Maclaren Techno XT Wisteria Umbrella...
I am looking for a replacement part for my Toshiba TV (model # 57H94), the bottom speaker cover.
What is the problem with the speaker cover? Is just the mesh damaged? If so you would have better luck replacing the mesh fabric yourself. You can purchase good replacement mesh fabric and adhesive at www.parts-express.com under speaker building supplies.
Oct 13, 2009 | Toshiba PSS421S TV Speakers
I want to remove the screen of my 42" Toshiba TheaterWide to clean the bulbs of dust and the inside. How do I remove the screen to get inside?
there are screws behind the speaker cover-remove them-take out screws along back edges-carefully remove screen(its plexiglass) clean all 3 tubes with a soft cloth -be carefull cleaning screen most liquids will stain it-also clean mirror-reassembly unit
Sep 03, 2009 | Toshiba 42H81 42" Rear Projection...
Replacement Screen
As far as I can tell, the part you need is called the speaker grille and is the entire piece, not just the cover. The part number is: 23527269 and costs: $152.29. It is available from tritronicsinc.com
Dan
Jun 06, 2008 | Toshiba 57H83 TV
Replacing LCD screens
ok just fixed one screen. the outside one. GET YOUR SOLDER GUN READY!, your gonna have to de-solder the speakers. to get the phone open theres 4 screws phillips head on the inside. Use a razor blade to pry the black tabs up and take the screws out. the 2 silver tabs have to come off completely. then take your razor between the top and bottom covers. theres 4 big clips on each middle section of the 4 sides. i first start on the edge that opens up. U put the razor in and very very carefully pry the top half out towards yourself it should then POP up separating the 2 sections. then i move to the top and bottom of the phone then the back side. after u got all 4 edges poped u slowly work your way around prying the top part OUT from the edge not up. Ull see what im saying when u start working on it. once the top cover starts to come off be careful that u dont pull the wires off the ear piece speaker. just take it off the top cover.
Next: theres a silver bracket that has to come off next. it holds the buttons and light on. theres a ribbon cable that i dont see any way of getting off that conects to be buttons so be careful. then u have to pry the plate that holds both LCDs in place. I only had to replace the smaller lcd so my job was faster. But if u have to replace both screens, the next step you'll have to do is.
Take the speakers out of there places buy prying them out but be very careful again. they are glued in and u can ripp the speaker covers off. but they come out easy. You also will notice that the speakers are soldered on. after that then i think both lcds will come out and u can just solder on the speakers to the new lcds. The +- are labeled. S is for speaker R-is for the mic and ear piece. took my about an hour just to replace the small lcd but i take my time and dont rush. Hope you guys have patience and a steady hand and good eyes. Good luck
Dec 03, 2007 | LG enV VX9900 Cellular Phone
How can I clean the gray fabric covering speakers?
the cover should be held on by 1/4" hex head screws, you can use a 1/4" nut driver to remove them, I dont know if they are 2 on the bottom or 6 from behind on the sides. then the fun of trying to clean the stains? maybe some hydrogen peroxide?
Jul 07, 2007 | Sony KP-51HW40 51" Rear Projection...
Rusty Drum!
you can extend the life for a little, by painting with a rustolum paint, but not for to long, better buy a good new one, use your experience when select the new one...good luck
Aug 07, 2006 | Zanussi TC7114W Electric Dryer
Hitachi 65TWX20B 65" Rear Projection Television Logo
23 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
