Question about Acer Aspire 5600 Series 5630-6951 Laptop
Aspire 5600 gets horizontal lines on lcd
The lines start at any position on the screen and it then works down and up until it fills the screen with these line. This total clears up by applying pressure on the laptop base or giving it a slight twist on the base(the lcd screen is not the problem.) It could work for quite awhile w/o this problem or could do it repetitvely after it has been cleared by base manipulation mentioned above.
  • ldnleaf
    ldnleaf Apr 09, 2008
    Turns out to be only a screw on the heatsink that needed to be snugged up
    Genius:
  • 1,226 Answers
The horizontal line means that there is a loss connection in the horizontal projection of the monitor. This can be resolved by fixing the horizontal panel board that gives error. this require quite expert in the LCD troubleshooting. However, if you believe that you can do it, ok you may proceed.
please donot rate me if this not solve the problem. because i need more higher rating. just notify if you need more solution am here to assist. melnavz
Posted on Apr 09, 2008
  • Emelio Navaja
    Emelio Navaja Apr 09, 2008
    Please do what you think got an error but be carefull because everything maybe sensitive and should be seated accordingly.
How to get rid of the bold black line on the top and botton of screen
I suspect you have your setup in HD and you are getting the widescreen version which fills the screen horizontally but not vertically. Play with the settings menu items until you get the image you like.
Oct 14, 2013 | LG 32LH30 32 in. LCD HDTV
Faulty screen, horizontal lines
Battery is stuffed, replace it. White lines is the early signs or the LCD is damaged and needs to be replaced.
Jan 15, 2013 | Tomtom ONE 3rd Edition GPS
Horizontal Lines Across LCD of Acer Advent 5431
sounds like a poor connection if computer is still under warranty send back to the manufacturer ... that should be covered as a defect...
Nov 19, 2012 | Acer Aspire 4720 Notebook
My Dell 1521 was working perfectly until this morning. When I tried starting it later today, the LCD screen no longer worked. The top third of the screen is fine. The bottom two thirds are covered by lines...
Your LCD has either gone bad or the ribbon needs to be reseated.
Carefully pry the plastic cover that runs parallel with your LCD. You will see the ribbon to the monitor. Press the connector down and make sure it didn't come loose.
Restart Windows.
If that doesn't work, then you will need to replace the LCD screen. You will not have to replace your lid...just the LCD. That should save you some money.
Hope this helps.
Feb 23, 2010 | Computers & Internet
Screen freezes and shows crazy purple colors in the screen or pink horizontal lines. The one time it shuts itself down, the other i have to use the on/off button to shut it down. When restarting it gives...
Incedible in one web page I found this solution and its work for me, the problem is the batery, just remove and no more frezee screnss and horizontal lines in color purple, Hope this helpt to you.
Oct 26, 2009 | Acer Aspire 5520-5908 Notebook
Inverter wires
Normally, LCD plugs are non-reversible. just follow he guide groove on the sides of the plug.
Sep 24, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Horizontal screen lines on acer aspire 5600 (5602WLMi)
Hi Cola;
How long have you been using your acer? is that a laptop or a desktop? is its a desktop, are you using a video card? if you are, remove it and use the on board video instead,to check if you have the lines.
May 19, 2008 | Acer Computers & Internet
Acer aspire 5600 lines on lcd
Good for you. you may still or telling me about the problem, i will keep on answering, what is your problem anyway? notify me always don't forget to give good rating. have a nice day.
Apr 10, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Aser 5600 horizontal line problem
Hello again,
since that the Laptop LCD is directly connected to the BOard. you have to check the board in lcd and connecting to the board of the motherboard. verify also the video card. of the laptop.
mlenavz
Apr 09, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer 5100, Lines throughout screen!!
connect to an external monitor, if it works fine then it is the monitor, if not its the video card.
Dec 11, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5600 Series 5630-6951 Laptop Logo
472 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
