Question about RCA Universal Remote Control
Rca rcr4258 universal remote code for symphonic st4819
I need the 4 digit code to get the rcr4258 to work with my symphonic st4819 tv. I tried all the codes below, and all the other 3 programming method (including auto search), but it still doesn't work.
1003 1022 1023 1028 1035 1045 1131 1164 1206
Thanks
  • Anonymous Apr 09, 2008
    Thanks for the advice freetek. But I tried that already, the codes are actually the same. Any other advice?
  • RCA Master
  • 5,569 Answers
Try the code settings for Funai; they build a lot of store-brand items.
You may not have all functions but normally you can find a code that will give you control of Power on/off, channels and volume.
Posted on Apr 09, 2008
  • Steve Allison
    Steve Allison Apr 09, 2008
    Since you have tried the scanning method (autosearch) and not found a set that works, that means that the Symphony is using a set different than those provided from the factory.
    I have exactly the same problem with two newly purchased flat panel TVs. We have enough remotes now to use for target practice.
    'Universal' Remotes have become inexpensive enough that you may be better off replacing it.
    That does not guarantee that one you buy will have the codes you need but I'm never bashful about returning something that isn't as 'universal' as claimed.
  • cdiamonds1 Feb 18, 2011
    There are no codes for this TV. I have the ST4819 and went through all of this. Unfortunately you have to order another remote according to Symphonic when I called them. You can order the replacement remote by calling 1-800-REMOTES or visit their website at www.remotes.com. You have to go through this company versus directly through Symphonic because the remote has been discontinued by Symphonic. They referred me to remotes.com who only sells discontinued remotes. It costs about $34 plus shipping. You will get it in about a week.
SOURCE:
I HAVE A SYMPHONIC 19 IN B-19WM AND I DONT HAVE THE ORIG. REMOTE..I HAVE TRIED TO PROGRAM IT WITH RCA RCU704 SERIES UNIVERSIAL REMOTE AS WELL AS A ATLAS OCAP 5 DEVICE UNIVERSAL REMOTE AND NONE OF THE CODES...
Hello
You just buy one Philips Universal Remote control [MODEL NUMBER CL 034]. Symphonic is listed in its codes. Codes are: 0906 0520
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
OK.
Feb 17, 2011 | Symphonic ST419B 19" TV
I have a GE universal remote control for my symphonic tv and I need to know the code to program it,can you help me . the numbers inside are rc24912-e, below that number 1818.
If it takes a 4 digit code try these ones: 0053, 0189, 0227, 0456, 0024
If it takes a 3 digit code try these: 024, 033, 053, 189, 198, 227, 456
You can find the full instructions and manuals at the following link:
Good luck and please post back if this helps.
http://www.jascoproducts.com/support/universal-remote-codes.asp
Jan 25, 2011 | Televison & Video
What is the code for DISH Network remote on a Symphonic SC313E 13 in. TV/VCR Combo?
I hope that after all this time, you were able to find that code. But if you weren't, or you still have some questions, here are some steps and codes.
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
733
632
694
Becki Barned
DISH Network Customer Service
Sep 03, 2010 | Symphonic SC313D 13 in. TV/VCR Combo
I got a symphonic 13 inch tv from my mom and she no longer has the manual. apparantly there is a code that has to be put in the remote to get it to work and it is in the lost manual. i have bought 3...
try one of these..
RCA 0 0 4 7 ,0 7 4 7 ,1 0 4 7 ,1 1 4 7 ,1 2 4 7 ,1 3 4 7 ,
1 4 4 7 ,0 0 9 0 ,0 0 5 1 ,0 0 9 3 ,0 0 1 9 ,0 6 7 9 ,
0 0 1 8 ,0 1 3 5 ,0 0 3 8
METHOD"
presse TV1 and SET button light on remote is steady enter code ...light goes out.. PRESS SET again and try. Keep trying unhtil unit can be turned on or off, then you know you have the right code. Write it on the back of the TV incase it drops out which can happen.
Please rate my help++++Thanks for using FIXYA
May 12, 2010 | Symphonic ST413C 13" TV
I have a silver and black ge universal remote with blue and grey buttons and need codes for a symphonic tv
If your remote uses a 4 digit code then you will need to try these: 0024,0053,0189,0227,0456
If your remote uses 3 digit codes then try these: 024,033,038,053,189,198,227 and 456
These are all the codes available from GE for Symphonic TV codes.
Jan 13, 2010 | GE Televison & Video
My remote for for my Symphonic TV (ST4819) does not work. Is there a Universal remote that I can get?
Definitely there is a universal remote for your tv. That's why it is called universal.
Jan 06, 2010 | Symphonic ST4819 19" TV
Sanyo TV I need a code for my optimum cable remote control to turn on and off the TV with their remote control.
Here's the instructions and codes plus an alternative method if one of the codes below do not work.
Three-Digit Code Programming Method:
  1. Turn on the TV.
  2. Press and hold the TV and DONE buttons simultaneously for 3 seconds. The iO button will light.
  3. With the iO button lit, point the remote at the TV and enter the TV's three-digit code (see code table below). The TV will shut off when the correct code is entered.
  4. Verify by pressing the SEL button. This should turn the TV on and off.
  5. Press the TV button to store the three-digit code. The iO button will blink twice to confirm that the code is stored.
Codes: 007, 053, 057, 082, 020, 239
Auto Search Programming Method Use this method if the three-digit code method does not successfully program your remote control:
  1. Turn on the TV.
  2. Press the CBL and DONE buttons simultaneously for 3 seconds. The iO button will light.
  3. Hold down CH+ and release it as soon as the TV powers off.
  4. Press CH- five times (the television may or may not turn on again as you do this). If the television does not power, turn it on manually before proceeding.
  5. Press CH+ one at a time until the television shuts off.
  6. Press TV to save the code.
To save time, the Auto-Scan function is trying codes as fast as possible while CH+ is being held down. It scans so fast that you may pass the desired code while holding down the CH+ button. Steps 4-5 allow you fine tune the auto-scan so you reach the correct code.
Nov 26, 2009 | Sanyo Televison & Video
Where can i find the method and codes to program my insignia digital converter remote for my symphonic tv
http://insigniaproducts.com/cms/documents/NS-DXA1-APT%20UM%20EN.pdf
Here are the Symphonic TV codes. These are for a universal remote OK
SYMPHONIC
520 904 906
Hope this helps. As for the insignia, if you can not click the link copy and paste. What you need is on page 18, instruction on how to program your converter. Download if you lost it and print if needed. You will need Acrobat to view this. Good luck
Sep 12, 2009 | Insignia Digital-to-Analog Converter for...
Reprogramming to my symphonic tv
What is the brand name of the Remote? You might be able to download or print off a manual from the manufacture's website, if they have one. but try this first, turn the TV on and push the code search button (If there is one) and press the TV button and aim it towards your TV, this should make the remote begin searching for the codes. If that doesn't work, try this, push and hold the code search button, usually the light above or below the button flashes 3-4 times then stays on, then push the TV button, it should flash once and then also stay steady, next input the code for symphonic, they are:
0906, 0520, 0324,0247, and 0004. Enter each 4 digit code and wait for a response. Usually the TV will trun off after the correct code is pushed. Sometimes you have to push the TV button again to complete the programming.
May 01, 2009 | Televison & Video
Rcr4258
Press and hold the code search button until light comes on then press the device you wish to program (tv-dvd-cable-sate-vcr) then enter the three digit code and release the code search button. You also try holding down the device your wanting to program then enter the code then release the device button (tv-dvd-sat-vcr) to check your tv . If that fails google the rcr4258 remotecodes and it will send you to sites that offers different ways. Good luck
Jan 18, 2008 | Proscan 19LA25Q 19 in. LCD Television
Televison & Video Logo
385 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
