Question about Kenmore 15762 Dishwasher
How do i remove the filter assembly-kenmore whirlpool dishwasher
Hi Community- I am stumped at how to remove what i call the lower filter assembly (that is under the lower spray arm).  it has an "inner" metal nut and a larger plastic nut surrounding it.    I have put wrenches on these but they seem stuck so i do not want to force it.  Our dishwasher makes a noise like the motor or pump is stuck/ jammed.   The last 1/2 inch of water does not drain and it makes a loud noise.
Can anyone help?
James v Burlington  VT
  • 523 Answers
The outer nut will twist off may take some force
Posted on Jun 01, 2010
How do I remove spin arm assembly from my kitchenaid dishwasher
About 56,200 results (0.83 seconds) Search Results
    How To Repair Dishwashers/KitchenAid Repair/Chopper ...
    https://en.wikibooks.org/...Dishwashers/KitchenAid.../Choppe...
    WikibooksDisassembly guide to access the chopper assembly in: KitchenAid K seriesdishwasher (similar to Whirlpool and Kenmore models) ... If the door safety interlock fails, the dishwasher could return to an active mode where these blades spin and ...place and carefully work around it to remove the upper spray arm water conduit.
    How to: remove and clean your dishwasher spray arms ...
    ? 3:13
    https://www.youtube.com/watch?v=MCWvxGmK3eM
    Feb 1, 2013 - Uploaded by Indesit Service UK
    Watch our easy to follow guide on how to remove and clean your Indesit dishw... ... KitchenAid & Whirlpool Dishwasher - Not Cleaning ,pump wash arm impeller chopper ... Why am I getting poor results from my dishwasher?
    Dishwasher Not Cleaning-How to Remove Spray Arms ...
    ? 3:47
    https://www.youtube.com/watch?v=BIru-ieAK54
Feb 03, 2016 | KitchenAid Dishwashers
Kenmore Dishwasher is not draining... checked drain line at disposal..not it. Have diassembled much of the housing at bottom of tub but still can't get to drain. Any suggestions?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 31, 2011 | Kenmore Dishwashers
My dishwasher isn't draining after it's cycles.
Hi
Daniel
Aug 30, 2011 | Whirlpool DU912 Dishwasher
Dishwasher wont drain!
Hi
Daniel
Aug 22, 2011 | Kenmore Dishwashers
Our dishwasher isn't draining
Hi
Daniel
Aug 04, 2011 | Kenmore Dishwashers
Water left in dishwasher after cycle is finished
Hi
Daniel
Aug 03, 2011 | Whirlpool Dishwashers
Water left in bottom after running dishwasher
Hi
Daniel
Aug 01, 2011 | Whirlpool Dishwashers
My Whirlpool Quiet Partner II will not drain at the end of the final cycle.
Hi
Daniel
Jun 16, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Top tray of Kenmore Quietguard3 dishwasher not cleaning!
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm and lower feed tube to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
Apr 03, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Lower arm and filter assem kenmore 587.16152400
The filter needs to go back on first, then the arm has notches so that it'll tight down, you need to rotate the arm till it falls in place, then the white handle is used (Goes around base of arm) to tighten it into place.
Oct 19, 2008 | Kenmore 24 in. 16352 / 16354 / 16359...
Kenmore 15762 Dishwasher Logo
324 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
