I have a Zenith E44W 46" lcd projection TV. It is about 3 years old. The picture has become dull and very yellow/greenish. Changing the video settings (brightness, hue, color, etc...) has not fixed the problem.
  • garyscheiner Jun 01, 2010
    Is there a lamp or other part that can be replaced?
    Yes... sounds like I will need to contact Zenith for support. Not something I can do on my own.
  • 19,396 Answers
Hi.
Greenish hue may be caused by one of the three RGB color channel missing (the red one), or by a defective light engine.
Check the video cables at the back, try connecting different devices using different inputs and cables.
If the problem is on all inputs and also when using internal tuner, then it is likely the light engine.
If picture is fine on internal tuner, then it is the terminal board hosting the connector.
If it is only with the tuner, then it is the tuner board.
If the problem is the light engine, then cost will be high (about $600).
Unless the fault is on inputs, testing and fixing the problem may be complicate. RGB signal must be tracked from terminal through controller board to optical group. The best thing to do in that case is contacting Zenith support and asking a quote on repair.
Here all parts for your set: E44W46LCD.
Posted on Jun 01, 2010
  • 11,800 Answers
Old problem on this model of tv: this is due to the heat generated by the lamp going through the optics.  In some sets it may be cleaned and/or polished back to normal, and in others the damage is too much, you will have to replace the whole engine.
  • Azrael SRL Jun 01, 2010
    As i said, most likely you will have to replace the entire optical unit, a very fiddly job for a professional. This part is only available thru authorized dealers/repair shops so you will gonna have to phone them.
Television will not magic focus and picture has a lot of red distortion
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 06, 2010 | Hitachi 46F510 46" Projection HDTV
Mitsubishi 65 in has greenish blue coloring mainly at bottom of screen any idea's?
*Screen Looks 3-D
*Colors wont align
May 06, 2010 | Mitsubishi WS-65907 65" Rear Projection...
54inch Hitachi TV has double figures and colors red, yellow-not normal. Set approximately seven -eight years old. Lost remote control and direction book in moving. Is the set worth getting fixed? Generally...
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 11, 2010 | Hitachi 57F500 57" Rear Projection...
Picture ghosts shows 3 images like it is out of focus colors also ghost in 3
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Your TV may have one or more of the following symptoms....
Mar 01, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Problem with picture on wide sreen TV
You probably need to get a Sony TV Convergence Kit. More information can be found using the link below.
Convergence Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
You can see some examples and find a fix here...
Feb 05, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Video picture is distorted on my toshiba projector tv about year 2000 model
Projection sets have two very common problems.
The first common problem is convergence
*Screen Looks 3-D
*Colors wont align
Dec 28, 2009 | Toshiba TheaterWide 46HM94 46" Rear...
Picture with green and pink outline
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Nov 21, 2009 | Sony KP-46WT500 46" Rear Projection...
I have a 46" (model 46H84) with wavy vertical lines throughout the screen. How can i FIX this myself? Is it possible? I've pushed the touch focus button and nothing. There is a 'convergence' option in the...
*Screen Looks 3-D
*Colors wont align
Sep 13, 2009 | Toshiba 46H84 46" Rear Projection...
Green spot on picture
Greenish yellow spot only means one thing. You have a defective lite engine. The only fix is to replace the engine. This part is very
expensive. Average cost $835.00 Part number A-1606-008-A
Best regards
circuitcity
Dec 08, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Electro Med Services...
