Question about White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit
The thermostat is a White-Rodgers 1F82-261. We have the very same thermostat on both the upstairs and downstairs systems. Both thermostats have all settings set exactly alike. The upstairs system has failed to cool three times and each failure has occurred on CONSECUTIVE Saturday evenings. During the first failure, we checked to make certain the outside unit was running, and it was. Both inside and outside units were running constantly as the temperature continued to rise. All we did was turn the upstairs system off and the next morning turn it back on and the system worked until the following Saturday. What's going here? Six days a week things seem to operate properly.
  • 99 Answers
Steps that you need to do.
First is to reset the unit by pressing the reset button for two seconds right below the fan switch.
Second is to re- program the thermostat correctly, make sure that the unit work fine when the thermostat has been bypass.
Then monitor the thermostat operation, I think this will resolved the problem. If you need further assistance call this number 18002842925.
I have attached the link of the MANUAL
Posted on Jun 02, 2010
The display on my thermostat is locked on 72 degrees. When I turn the switch from a/c to the off position, it appears that the heat comes on.
Posted on Jul 27, 2010
My upstairs temperature is 80 degrees and the downstairs is 69 Honeywell focus pro th6000 is set at 69. Why is the upstairs so drastically hot?unit is located upstairs& thermostat is downstairs
if there is no control of air movement between floors and you have it on cooling then any cold air will go down to the lower floor
or alternately if you have it set on heating all the hot air will rise to the upper floor
where is the system located (upstairs or down stairs ) and where is the thermostat located
to get control close any upstairs to down stairs doors or erect a heavy curtain across the stair well
Dec 17, 2016 | Honeywell Heating & Cooling
I have a white Rodgers 1f88 300 thermostat (both upstairs and downstairs). The downstairs unit now shows a blank display. Is there a reset? I checked for a battery and it does not have one. Can you help?
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. To reset the thermostat by removing the wires from terminals R and C and removing batteries for 2 minutes. After resetting the thermostat,
replace the wires and batteries. If the thermostat has been reset and still does not function correctly contact your heating/
cooling service person or place of purchase.
Let us know if you need anything else.
Jan 13, 2013 | Home Security
Model 1f90w-51 the up down buttons stopped working this is a white-rodgers
Electronic Digital Multi-Stage Thermostat 1F83-261
  • 1F83-51 - White Rodgers Installation and Operating Instructions Thermostat 1F83-51
  • 1F86-344 - White Rodgers owners manual Thermostat 1F86-344
  • 1F86-444 - White Rodgers Installation and Operating Instructions Thermostat 1F86-444
  • 1F87-251 - White Rodgers Thermostat 1F87-251 OPERATION INSTRUCTIONS
  • 1F87-51 - White Rodgers Installation and Operating Instructions Thermostat 1F87-51
  • 1F89-11 - White Rodgers Installation and Operating Instructions Thermostat 1F89-11
  • 1F90-51 - White Rodgers OPERATION GUIDE Thermostat 1F90-51
  • Hi, This is a good stat and I have used it alot in the past as it is a older model. If you have 24 volt control voltage at the stat, and the battires are good, then you have a malfuntion in the ciruitry and will need to replace it. I have sent you a ton of manuals on there products I thiught they may be helpful. Please dont forget to rate this post as I know you will be kind. I hope I have been of help to you.
  • Sincerely,
  • Shastalaker7
  • A/C, Heating Contractor
Sep 22, 2010 | Heating & Cooling
Two zone heat /ac upstairs thermostat appears to be on but no air is being forced through vents. downstairs zone works fine.
Sounds like a problem with your furnace or blockage in your duct work, not a problem with the thermostat. You are not missing a cat are you? The Operating Manuals for many White-Rodgers thermostats can be found in PDF form HERE, however they are not indexed by model number so you will have to download each file in turn until you find the one you want. All of the file names beginning with "0037-" seem to be W-R products.*Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera "The problem can always be solved with the materials in the room." -My college Physics Lab Professor
Aug 20, 2010 | White Rodgers White-Rodgers 1F85RF-275...
I have 2 Thermostat's in my home. My heat works well upstairs but not downstairs. My thermostat downstairs won't come on but I unhooked the thermostat from downstairs and tried it upstairs and it worked...
Hi, sounds like you determined the problem is not with the thermostat. That leaves the furnace that serves downstairs. What type heating system do you have?
Jan 13, 2010 | Honeywell Programmable Thermostat Heater
No Heat with new White Rodgers 1f85rf-275 Thermostat
My name is Tim Burke from White-Rodgers. If you hear the "click" the thermostat is calling. It would appear that their is a wiring issue to the funace. Please contact our customer service toll free hot line and they will be happy to walk you thru it and assist you. 877-978-7828
Regards,
Tim
tim.burke@emerson.com
Tim
Oct 19, 2009 | White Rodgers White-Rodgers 1F85RF-275...
Heating blowing coo air downstairs and warm upstairs?
Some of this depends on where the air handler/furnace is located. Most often in two story houses, it's in the attic upstairs, or in a closet upstairs. A duct routes air from the furnace to the downstairs supply duct, so it is a distance from the air handler.
When the unit first initiates a heating cycle, that duct is going to be full of cool air, and the duct itself will be cool. So the furnace has to run long enough to push the cool air out, as well as warm the duct up, before your going to feel warm air at the registers downstairs.
Keep in mind, heat rises. And, your thermostat only monitors the immediate area where it's located. In your case, upstairs.
Two story houses are problematic because of this. And one way around it is to have a damper system installed that distributes the air upstairs or downstairs based on a thermostat located in those spaces. There would be 2 dampers, and 2 thermostats (one upstairs, one downstairs). Each stat would control a damper, and the call for heat or cooling.
Let me know if you would like to consider a system like this, and I can point you to components to use. I've put several system like this in.
Jan 26, 2009 | Kitchen Appliances - Others
High Electrical bill - Appears to be heatpump problem.
Sound like there are running on emergency heat which is elrctric.Have the system checked out buy a local heating and cooling company. Have they checked the filter and changed them.
Jan 14, 2009 | Honeywell Electronic Programmable...
Honeywell T8000C Thermostat Problem
If you have a volt meter, remove the thermostat off from the mounting plate and check for 24 volts AC across red (R) and White (W). Then check across Red and Yellow (Y). If you do not find any voltage, follow wire as much as you can all the way back to the air handler that is connected to it. Look inside and see if there is a small Auto (car) type of fuse in the wiring harness. Test and replace if necessary. Jump out the Red and Green terminals on the air handler and replace the door. See if the blower turns on. If so, you have narrowed it to the wiring to the thermostat. If not, you have a power problem and will need a technician.
Sep 28, 2007 | Heating & Cooling
White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit Logo
2,805 people viewed this question
Top White Rodgers Home Security Experts
Tom Chichester
Heatmeister99
Level 1 Expert
A Hoffman
A Hoffman
Are you a White Rodgers Home Security Expert? Answer questions, earn points and help others
