Question about GE WJSR2070B Top Load Washer
Disconnecting lid switch
How difficult is it to disconnect the lid switch and how is the easiest way to do this? Thank you
Try overriding it by putting a magnet on the base where the lid magnet touches.
Posted on Jul 28, 2010
  • 333 Answers
It should have a schematic behind the control panel. If there is then you can find what color wires go's to the switch and cut them then connect them together with a wire nut.
If not then you will have to remove the top and the switch will be attached to the top. It has a long arm and switch is past the end of the drum. Then do it same way, Cross out wires.
Posted on Jun 02, 2010
WFW9050XW00 WHRILPOOL FRONT LOAD WASHER WILL NOT FILL WITH COLD WATER
First thing I would do is to take the Filler Hoses off (Make sure you turn the water off before disconnecting). There is a Screen in hose connector and it traps water. If the Hose Filter is not clogged, then you have an issue with the Selector Switch, Valve inside the machine, one of the Solenoid's or the Control Board has went bad. Start with the Easiest First, then work your way into the more difficult aspects...
Jul 20, 2014 | Whirlpool Washing Machines
Kenmore 20022011 washer......the lid switch keeps trying to activate but won't latch. Is there a way to make it work without the switch hooked up?
TRy disconnecting the switch and use a jumper wire on the connector if this works you have a bad switch
Feb 04, 2013 | Washing Machines
Washer will not turn on. I think it is the lid switch. How can I get it to work by disconnecting lid switch? Splice wires?
A bad lid switch will make the washer not spin/drain it has no bearing on the fill.
The usual parts that could make it not fill are;
Water inlet valve
pressure switch
Aug 23, 2011 | Frigidaire FWS833A Top Load Washer
P1258 engine metal over temperature protection-\ is it the thermostat ,and if where is it located?? Thank-you.
Some Cadillac motors use a sensor called an engine metal temperature switch. This switch is usually located on one of the cylinder heads and normally has a one wire connector. It is small and can be difficult to locate. When you find it , try disconnecting it. If the problem goes away then the switch is bad. Be aware that the check engine light will probably come on if it isn't already and that this procedure may not work because it may need to be in the circuit for the system to operate. Good luck!
May 15, 2011 | Cadillac DeVille Cars & Trucks
Cant connect diagnostic computer in port and get accurate reading on check engine and where is eic fuse located
eic located in main fuse box is under the hood in main fuse box,lift lid off and location will be diagram on inside of lid.you can reset that light by disconnecting positive cable from battery for 10mins. that will reset your whole computer. thank you for choosing fixya.com
Dec 30, 2010 | 2005 Ford F-150
I am remove heater core from nissan xterra 2000 do i need to remove the evaporator
2000-02 Frontier And Xterra
  1. Disconnect both the negative (1st) and positive (2nd) battery cables.
  2. Remove the steering wheel by performing the following procedure:
    1. Turn the ignition switch to the OFF position.
CAUTION Wait 3 minutes after disconnecting the battery cables and turning the ignition switch to the OFF position before servicing the air bag system.
  1. Remove the lower lid and disconnect the driver-s air bag module connector.
  2. Remove both side lids.
  3. Using the Tamper Resistant Torx® Wrench size T50, remove the special bolts from both sides of the steering wheel and discard them.
  4. Remove the SRS module from the steering wheel.
CAUTION Always store the SRS module face up.
  1. Position the steering wheel in the straight-ahead position.
  2. Disconnect the horn connector and remove the steering wheel nut.
  3. Using a steering wheel puller, press the steering wheel from the steering column.
  1. Remove the passenger-s side air bag by disconnecting or removing the following items:
  1. Open the glove box door.
  2. Working inside the glove box, open the lower instrument panel lid.
  3. Remove the passenger-s air bag module connector clip from the lid.
  4. Disconnect the passenger-s SRS module connector.
  5. Remove the glove box and the lower passenger-s side instrument panel.
  6. Using the Tamper Resistant Torx® Wrench size T50, remove the SRS module-to-instrument panel special bolts and discard them.
  7. Remove the 4 SRS module-to-instrument panel mounting nuts.
  8. Release the SRS module-to-instrument panel clips and remove the SRS module.
  1. Drain the cooling system into a clean container for reuse.
  2. Working inside the engine compartment, disconnect the 2 heater hoses from the heater core.
  3. Discharge and recover the air conditioning system refrigerant.
  4. Disconnect both refrigerant lines from the evaporator core. Plug the lines to prevent moisture from entering the system.
  5. Remove the glove box and the mating trim.
  6. Disconnect the thermal amp connector.
  7. emove the air conditioning housing assembly from the vehicle.
  8. Remove the instrument panel assembly by performing the following procedure:
    1. Remove the 4 steering column cover screws; then, separate and remove the steering column covers.
    2. Remove the 2 driver-s side lower instrument panel screws and the lower instrument panel.
    3. Remove the 4 cluster cover screws and the cluster cover.
    4. Remove the 6 combination meter screws; then, disconnect the combination meter electrical connector and remove the meter.
    5. Remove the 2 glove box screws and the glove box.
    6. Remove the 2 instrument stay cover screws; then, disconnect the electrical harness connectors and remove the stay cover.
    7. Remove the 2 cluster lid -C- screws; then, disconnect the electrical harness connectors and remove the cluster lid -C-.
    8. Remove the 4 audio and deck pocket screws; then, disconnect the electrical harness connectors and remove the audio and deck pocket.
    9. Disconnect the ASCD main switch connector.
    10. Remove the 2 meter cover screws; then, disconnect the electrical harness connectors and remove the meter cover.
    11. Remove the 4 air conditioning-heater control screws; then, disconnect the control cables and remove the air conditioning-heater control.
    12. Remove the front pillar garnish.
    13. Remove the 3 instrument panel assembly nuts and 2 bolts; then, remove the instrument panel.
  9. Remove the heater housing assembly.
  10. Remove the heater core from the heater housing assembly.
continue...
Jul 16, 2010 | 2000 Nissan Xterra
Steering rack replacement on a 99 cady deville, how difficult ?
Rather difficult. Involves disconnecting the tie rod ends. Steering linkage from steering wheel. Disconnecting the power steering pump lines and unbolting the rack and pinion from the body. Not a lot of room to get at stuff.
Apr 24, 2010 | 1999 Cadillac DeVille
Phillips PET 706 portable DVD player. Won't play DVD's.
1. The pin, right side in the back of the dvd-tray-lid, which triggers the switch on the motherboard of the dvd player is broken.
2. Not impossible, but unlikely: the proper switch on the motherboard is broken, corroded or just full of dust and does not close the circuit.
Solution to 1.: you need a new lid with intact pin, or glue an improvised pin on place of the broken one.
Solution to 2.: take the whole player apart (not difficult at all), while not disconnecting any cables, so you can now test the trigger switch (momentary switch) manually and see if something happens (on screen appears loading)
ATTENTION: BEFORE pressing the SWITCH: cover the laser lens with a piece of paper - do not look into it - it can damage your eyes!!!
If nothing happens by manually triggering, try to spray some electronic cleaner (fat and oil free) into that switch, while pressing it continously. If still nothing happens, disconnect battery, DC, de-solder that switch and look at mouser.com or any other electronic parts dealer to get a MOMENTARY switch with exact identical dimensions, etc.
Solder it in, everything should be perfect now.
Good Luck
Apr 05, 2010 | Philips PET741 Portable DVD Player
1998 chevy tahoe dome light will not shutoff
you have a bad dimmer switch or door jamb switch I would start by disconnecting the door switches 1st for they are the easiest to do. when the light goes off you will know which is a fault
Feb 02, 2010 | 1998 Chevrolet Tahoe
GE WJSR2070B Top Load Washer Logo
78 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
