Question about Mitsubishi WD-52525 52" Rear Projection HDTV
How to change a bulb WD 52525 - Mitsubishi WD-52525 52" Rear Projection HDTV
  • 505 Answers
The speaker grill pops off and use a philips screwdriver to remove to door slightly left of center. the lamp is held in with 3 screws, might need a flat head driver to get em moving. this tv is known for bad capacitors on the power board causing false lamp errors, and also other caps going bad too. let me know if you need more assistance. fixing all caps = 300-500 $ estimate
Posted on Jun 01, 2010
Can not locate the where the bulb is on model # wd-52525
Pull off the lower speaker cover and then the lamp door is located on the left side of the lower portion after removing the outer speaker cover.
Apr 27, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Timer light blinking on my WD 52525 tv will not turn on
main board or bulb went out it is a diagnostic indicator used on the timer display to let you know its not working.
Mar 27, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Replaced bulb in Mitsubishi WD-52525 and it still does not work
What does not work? Does the green light flash or light at all? Can you "manually" turn on the tv? If the light is RED...the replacement was either installed incorrectly (or is not plugged in correctly to the contacts at the rear) or is the wrong bulb. Be sure the door to the front of the bulb in on as there is a micro-switch at the lower right that MUST be engaged.
Jun 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525
You have a bad DM Board. You need to replace it. Changing the capacitors will not cure the problem. Completely replace the entire board
May 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blue screen on WD-52525
Hi, Standby i'll sent you how.for a while
Apr 10, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Error Message: Did you change the bulb
Good Day, emoo;
You should be able to remove that message by pressing enter on your remote or front panel.
Good Luck, Big Irish.
Jul 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
136 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
