Question about Mitsubishi HS-U580 VHS VCR
How change tape speed? - Mitsubishi HS-U580 VHS VCR
  • glbush Jun 02, 2010
    I've already been to the menu looking for a change speed. Thanks for the response. I'll try again.
  • Mitsubishi Master
  • 3,866 Answers
This is done in the recording menu of the system there should be SP/slp/LP you need to access the menu under record it should be there, I tried to find a manual for it but was un-successful due to its age but I hope this give you some idea on how to chang ethe speed,
Thanks and please click the accept button for my efforts.
Posted on Jun 01, 2010
My XHA1s records but won't play back any tapes unless you're in ff or rw. One of the tapes I had just loaded part of on my computer a few days ago with no issues. As far as I know no settings have been...
Sounds like the edge of the tape has been damaged. The edge of the tape has the speed encoded so the playback will know what speed to play the tape. Look at the edge of the tape for wrinkles. If present, throw away the tape so you won't use it for an important recording.
Sep 04, 2013 | Canon XH A1 Mini DV Digital Camcorder
How do you switch tape speeds to LP on a Sony Handy cam TRV 240
You can set tape speed SP or LP in record mode only and can not change it in playback mode.
To set tape speed, turn camcorder in camera mode and go to Menu and set SP or LP in record speed option.
Jan 03, 2010 | Sony Handycam DCR-TRV240 Digital Camcorder
Tape speed button not working on remote, how can I set tape speed now . Have admiral vcr - don't have manual. Should I be able to change speeds by just pressing tape speed button & choose SP or EP or...
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Apr 10, 2017 | RCA RCU300 Remote Control
Cannot change tape speed on my vcr
i had to find a compatible Admiral remote.
Dec 06, 2008 | Televison & Video
I have an admiral vcr. the remote is broken and that was the only way to change the tape speed that I am aware of. There's nothing on the menu screen or the vcr itself to change speed. Is there some king...
i have a vcr similar to this,but unless you can find a universal remote that has a speed change function i think you're stuck with one speed.
Change tape speed from SP to EP
hi!u can download a copy from http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
u will have to make a free and simple registration but its worth!
hope it helps!
Nov 04, 2008 | Mitsubishi HS-HD2000U DVHS VCR
Changing to ep
Hi, Try push (Menu) button on VCR Recorder to see Tape speed. Then follow instructions on TV to change speed of tape........Crazyred94
Jun 28, 2008 | Emerson EWV403 VHS VCR
Changing from sp to ep
it will automatically play at the speed the tape was recorded at. but if you want to change record speeds here's how: you should be able to access menu functions from the front of the vcr, if so, put a tape to be recorded into the unit and then set the timer for a couple of minutes.while you are on the timer menu it will ask you for recording speed. set the timer record speed to ep and let it record for two minutes and let it record for the full time untill it stops recording. the record speed will automatically change settings to whatever you used last on timer record.
May 01, 2008 | Sharp VC-A560U VHS VCR
Changing the Recording Speed without manual or remote
when you are programing the shows and you highlight the tape speed use your channel up and down button to change tape speed.
Jan 28, 2008 | Sharp VC-H812U VCR
Cassette Player
Motor speed needs to be regulated by PWM. Reducing the current (with a resistor) actually lowers the torque - which, with a given load, does result in reduced speed - however, different length tapes (60min vs 90min), as well as different quality, and even current position in the tape, will change the load and hence the speed. You need to regulate the speed via PWM. It's sometimes done on a small board built into the motor, in which case you'd have a round hole into which you could insert an INSULATED screwdriver (tiny flathead wrapped most of the way in electrical tape works). It may be done on the main board, in which case you could find a pot conveniently labeled "motor speed", or perhaps "pulse width" or "pwm" or something to that effect. Find it, mark its current position just in case, and turn it to see if it gets the effect you're after. And there are some tape decks in the world with no speed adjust - they are designed with a specific speed motor and the sizes of the wheels and gears are calculated for that speed. Also there may be a mechanical fault/malfunction causing the speed problem. An initial check and thorough cleaning of the capstan and pinch roller should be done. If there is a buildup of tape oxide or a piece of a broken tape wrapped around the capstan, the tape travel will be too fast (do to the effective increase in capstan shaft diameter). If the pinch roller isn't fully engaging, the tape can be getting pulled onto the takeup spool at a speed faster than the capstan control. A different source of trouble might be a slip clutch (possibly an idler/clutch assembly)which is binding, or otherwise not functioning the way it should. Another type of motor doesn't have it's speed controlled by an internal or external voltage.. instead, the motor has an internal centrifugal speed controller. This type of motor can be found on older tape decks, and might not have been utilized more recently. Good luck
Mar 07, 2006 | GPX HMTU3234 Shelf System
Televison & Video Logo
32 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
