Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Evap fan not running changed and still not running
Evap fan not running and changed to a new one and still not running
    President:
  • 1,218 Answers
Good day,
On some Amana models the evap fan motor runs thru the defrost thermostat. The purpose was to delay the fan restarting after a defrost cycle so it wouldn't blow warm air. If you can jump the defrost thermostat and the an runs, then changing the thermostat will solve your problem.
Other causes on Amana could be on older models the fan was run thru the fan/light switch. If it's a rocker type switch, it could be the problem.
Call the supply house where you bought the motor. Ask if the light switches are 2 or 4 terminal. Both the freezer and fresh food switches. If they are 4 terminal, then they could be the problem, or they are not depressing far enough when the door closes.
Lastly, I have come across a few Amana's where they actually had a broken wire to the motor. In all my cases it was the white wire. The area where they broke, was not at the motor but further back in the harness. You would need a VOM meter to trace the wiring.
Posted on Jun 01, 2010
  • John Hall Jun 01, 2010
    Here's a picture of the defrost thermostat I mentioned. It's clipped to the top of the cooling coil, in the freezer compartment.
My BM23 turns on when I turn the thermostat up but the evap fan does not turn on. Should the evap fan run all the time or only when the thermostat turns the compressor on?
The evap fan runs continuously if the thermostat is not in the off position. If the fan is not running you need to find out if it is getting power and replace it if necessary.
May 01, 2014 | Beverage-Air BM23
Why would evap fan running slow
If u turn the fan by hand and it turn then u need a new fan, and i think u are mixing up the fans, the fan inside the refrigerator would be the evaporator fan if that was broken then your compressor would be cold, the fan inside the compressor section would be the condenser fan, if that was defective then your compressor would be hot causing the compressor to short cycle. change the fan and clean your condenser coil and your problem should be gone,
Jan 17, 2013 | True TSSU-27-12M-B Commercial Refrigerator
Evap fan runs constantly
The fan should run when the compressor runs.
Nov 23, 2012 | KitchenAid Refrigerators
Compessor is running hot, fan is not running
need to know brand and model. which fan was replaced ( evap or cond ) . if evap fan it may be the door sw as some model only run fan wth door closed. if it's the cond (fan) motor then ck wiring at compressor . or borken wire. in or about the compresser area .. hope thes help . mm
Jul 05, 2010 | Refrigerators
Refrigerator has a clicking sound and does not run
Replace the motherboard (part # WR55X10942) but be careful to check that the evaporator fan (inside the freezer) turns on when you power up the refrig again. A bad evaporator fan motor can take out the motherboard. If compressor starts with new board but not evap fan, unplug immeadiatelly and replace the evap fan motor to save new board.
Sep 11, 2009 | Refrigerators
Evap fan does not run
please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
May 14, 2009 | GE GTS22KBP Top Freezer Refrigerator
Fridgidaire 18 cu new defrost timer and evap fan stil freezes
Did you replace the timer with the correct one for your refrigerator? If so you may need to check the defrost thermostat out.
Mar 26, 2009 | Frigidaire FRS3R5EMB Side by Side...
My U-line under counter refigerator ice maker evap fan failed
Depends, for the newer models, you can change the evap fan motor thru the front, but if you have the older model, then you have to remove the freezer housing, ice maker assy then the cover to change the evap fan motor.
Nov 13, 2008 | U-Line COMBO29FF Origin Series...
Freezer cold/Not Cold in Frig KITCHENAID Model KBLC36MHS01
I couldnt find a diagram of this frig.
Some of the evap. fans run thu the defrost thermost ..u could try by-passing thermost and see if fan comes on...  have you checked with volt meter if there was power at the fan motor?
Oct 31, 2007 | Refrigerators
Frigerator not cooling not cooling at all
make and model # was there frost on the evap.?
Sep 12, 2007 | Daewoo FR-147RV
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
103 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
