Question about HP OfficeJet 6210 All-In-One InkJet Printer
Printer won't feed paper. - HP OfficeJet 6210 All-In-One InkJet Printer
  • 503 Answers
If you can see the rubber rollers that move the paper, you might try cleaning them with alcohol and a lint free cloth or swab. But as was mentioned, a good inspection is the best thing to do. Make sure you
doesn't stick your finger in the rollers while they are moving.
Also make sure you hasn't moved a control for the paper thickness. If it was to be set on envelopes, it might not grab normal letter size paper.
OR
Note if the paper is picked up at all, and if so, how far in it goes. Could it merely be a paper jam? We have no way to know her experience with printers. Does it seem like the printer thinks the paper went through? Did it continue trying to print on *nothing*? Did it prompt to insert paper? What kind of feedback does this model provide on it's operating state?
If the cover flips open, an inspection of the paper path
would be useful. If not (or either way) a flashlight or
strong light might help. If the top doesn't open it could
be necessary to take it apart a bit to see the paper feed mechanism, whether there are any stripped gears or broken/loose belts, if the motor is running (Or motor shaft is spinning within the attached gear), if any microswitches aren't making contact... something that might be visually obvious or might require a multimeter to check continuity.
Basically if she has no mechanical or electrical experience *in general*, the best you might do is to describe that it's using motor(s), gears, and rollers to pick up the paper and guide it, and you needs to see where/why it isn't moving the paper along.
There are other various things less easily seen, like a
loose tensioning spring (allows varying paper thickness) or perhaps an entire plastic piece (holding a spring or even unrelated to springs) could have broken off or bent. This isn't necessarily pertaining to that specific model of printer but the general operation of it is probably similar to many from a mechanical standpoint... if it's nothing
obvious then you (or someone nearby) will have to understand a bit about how it mechanically works in order to find what's wrong.
They're essentially throwaway printers though, repair can be unworthwhile in many cases. It looks like a replacement could be had for about $70, if you had enough toner refills already to make choosing same thing again worthwhile, but in the interim if these are standard format files, a local Kinkos or other copy center can probably get the rest of the print job done "right now".
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Jun 01, 2010
My canon pixma mx320 won't feed paper properly it seems to grab one side of paper and feeds it crooked then stops
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Jul 26, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
My hp officejet pro k8600 won't print straight.
Jul 20, 2011 | HP OfficeJet Pro K8600 Printer
Lexmark X85 won't feed paper. When trying to
There could be something in the paper feeder that's blocking the paper path. Please follow steps below to identify and fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside for any debris.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
6. If cartridge area is clear, close the cover.
7. Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
ns Serif"'>6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Jul 11, 2011 | Lexmark X85 All-In-One InkJet Printer
There is NO paper jam- and the paper won't feed. We have taken the printer apart- NOTHING hung up- gears are okay- still won' feed paper.
hi...
Most of our printers pull the paper down on one side slightly faster than the other. The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
try it out....
Apr 05, 2009 | Lexmark P4350 All-In-One InkJet Printer
Brother laser printer wont print on cardstock My brother printer won't feed teh card stock paper. It used to work but now it won't feed it, normal paper works fine. Even if i nudge the card stock paper,...
If there printer is not able to print on card stock then check the recommend
card stock paper thickness, if the printer works with normal paper but not card stock then there is problem in the card stock and by using this paper may also damage the rollers on the printer and make the printer useless ...
Good luck...
Feb 09, 2009 | Brother MFC-5840CN All-In-One InkJet...
Print head alignment +won't feed paper
Best solution is to clean the head with it in place,here's
the manual for your printer
Oct 09, 2008 | Epson Stylus Photo R2400 InkJet Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
139 people viewed this question
Seeker5211
Seeker5211
