Question about Vizio L15 Television
Does Vizio TV's have a reset button? - Vizio L15 Television
  • 505 Answers
No reset button.
try unplugging for 2 minutes and try it again.
if this doesn't work, needs internal repair
Posted on Jun 01, 2010
Can I fix my vizio e472vle? Or do I need to purchase a new tv? Any Idea what i would need to repair the problems listed below (flciker of menu and smart functions).
Follow these steps to reset your TV:
  1. Unplug power to your router.
  2. Perform a Clear Memory or Reset to Default on the TV.
A. Using the VIZIO remote, press the Menu button.
B. Use the Arrow buttons on the remote to highlight System and press OK.
C. Highlight Reset & Admin and press OK.
D. Highlight Reset TV to Factory Defaults and press OK.
E. If you have not manually reset the parental code, please input 0 0 0 0 when it asks for the password.
F. Highlight Reset and press OK.
G. Wait for the TV to turn off.
The TV will turn back on and the Setup App process will begin.
  1. Plug power back to router.
  2. Perform the setup process and reconnect to your network.
Jun 02, 2017 | Vizio Televison & Video
How do I fix my Vizio TV model E421VA? Details are below. It has a black screen and no audio.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Nov 01, 2016 | Vizio Televison & Video
Is there a reset button on a vizio lcd 32 in flat screen tv and where would the fuse be located what happen was my husband accidentally touched the usb where it says sevice with a wire and the tv just...
Hi Kaycee.
I suggest you try to reset the power to the TV:
Start off by turning the TV off and unplugging it. Press the power button on the side of the TV for 30 seconds. Let go of the power button and plug the TV back in.
Hopefully this will get it working for you.
If this does not solve the problem, you can go to the online video, "How to Power Cycle a VIZIO TV" - see attached video.
Reference is
https://answers.vizio.com/hc/en-us/articles/200132879-How-to-Power-Cycle-a-VIZIO-TV
Hope this all helps you
Mar 04, 2015 | Vizio Televison & Video
Resetting without going to the menu for a vizio m220nv
Get into the Vizio TV service mode
There are to options to get into Service mode:
Option 1:
Turn the Vizio TV off.
Press and hold the CH + & CH - buttons on the TV.
Then press and release the POWER button on the TV Vizio.
Release the CH+ & CH- buttons.
Now press the MENU button on the remote.
You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This if for factory reset).
Press and hold the MENU button for few seconds.
The Service Menu will be displayed.
Option 2:
Turn off th Vizio TV.
Press and hold the CH+ & CH- buttons on the TV Vizio.
Then press and hold the POWER button on the TV.
Keep all three buttons pressed for few seconds.
Feb 18, 2013 | Vizio M220nv 22-inch Full Hd 1080p Led Lcd...
No power on vizio E371VL
Vizio TV model E371VL turned on ok and had tv show on ch.4.
Turned on the DVD player and put movie dvd in and closed tray.
We have done thhis numerous of times and never had a problem.
This time " HDMI " was showing on top right of black screen,
then " No Signal " came up on screen, then went completely black screen. Called Vizio, they had me power off and unplug set.
Push and Hold power button on TV for 30 sec. to reset.
Replug set and Vizio (lighted) on lower front of set lighted normally dull orange. Pushed power button on remote and when set did not come on, then push main power button on side of TV. Nothing, no White " Vizio " from orange light. Is this a power supply (0500-0412-1020) problem ? Thanks, Sidney (sidneysites@yahoo.com)
Feb 17, 2013 | Vizio E371vl 37 Inch Class Lcd Hdtv
No sound from E371VA Vizio TV
tried first with unplugging and re plugging the tv unit to reset the power supply as will as the any program.
Nov 14, 2012 | Vizio E371va 37-inch Full Hd 1080p 120 Hz...
My Vizio 321 VL TV will not power on. The vizio logo is lit up amber.
I would start by reseting the tv unplug it for 30 min then hold the power button on tv and plug it in at the same time holding the power button for 20 sec.
Apr 14, 2012 | Vizio Televison & Video
Is there a reset button? My son tried to plug the computer into our Vizio tv and now there is no power - it doesn't come on. I think he inserted something into the "service" plug.
We have a 42" LCD, model E421VA that had a problem. I called Vizio and they told me how to reset the TV. Unplug the TV from the power source, press and hold the TV power button (located on the TV) in for 30 seconds, then plug the TV back in and turn it on. Good Luck
Sep 04, 2010 | Vizio Televison & Video
No Picture
I called Vizio, was told I needed a hard reset, and this fixed my problem: I unplugged the TV; held down the on button for one minute, then plugged it back in. It works fine now.
Apr 02, 2010 | Vizio L32 32 in. LCD HDTV
My vizio wont turn on but the vizio organge light comes on please help
I called Vizio, was told I needed a hard reset, and this fixed my problem: I unplugged the TV; held down the on button for one minute, then plugged it back in. Hope this works for you.
Mar 26, 2010 | Vizio L32 32 in. LCD HDTV
Vizio L15 Television Logo
1,763 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
