Question about Princeton Digital VL1916 19" LCD Monitor
Monitor cycles like circuit breaker cycling. - Princeton Digital VL1916 19" LCD Monitor
  • 11,361 Answers
Check the caps in the power supply with leaking/bulging top.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed PRINCETON monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 01, 2010
Kenmore 110-88752793 washer dryer. Tub filled up for the rinse cycle and then stopped. Tried turning on the dryer and that has no power either. Cycled the circuit breaker. Still nothing. Any ideas?
The circuit that supplies your washer and dryer may also have an in-line GFI outlet which may have tripped. Even though you have cycled the circuit breaker you would also have to reset the GFI outlet as well. Good luck.
Nov 26, 2016 | Kenmore Washing Machines
Bosch diswasher,model Sms68m02AU trips circuit breaker
rcd units trip from the milliamps that are in a short
it trips the rcd to prevent electrocution and acts in nano seconds besides being a circuit breaker for excessive current
the trip can be from moisture allowing a current leakage to ground or some other simple operation
I suggest that you get in a qualified electrician / bosch service technician to find the reason for the problem rcd
Sep 15, 2016 | Bosch Dishwashers
After wash cycle, water is pumped out but circuit breaker is blown when spin cycle starts.
Will the tub spin if you move it by hand? A motor will usually only draw excessive amperage if it cannot move easily... Also, take a look at the terminal block where the power cord attaches to the machine for burnt connections, a bad connection can cause a breaker to trip, same as a 'dead' short. Terminal Block WPW10245259
May 25, 2016 | Washing Machines
What does f01 mean
From the Maytag support website:
Product Symptom:
F01 Error Code
Control displayingF01:
There may be a problem with the Main Control Board, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Start a time dry cycle.
Monitor the dryer for one (1) minute to ensure the error code does not display again.
Jan 24, 2016 | Maytag Dryers
At end of washing machine fast spin the machine trips my electricity circuit and TV switches off along with other appliances. Can you tell me what's wrong with machine?
This tells me that you do not have an overload situation. There is a short, and/or one or more faulty breakers possibly including the main breaker.
Even an experienced DIY'er with electrical knowledge would probably contact an electrician at this point. If there is a potential problem with the main breaker then it is best to get professional help.
Why is my electric circuit breaker tripping
Common Causes for Tripped Circuit Breakers
Why Does My Circuit Breaker Keep Tripping
Jul 02, 2015 | Washing Machines
Dishwasher trips out after running for a while
When you say "trips out" do you mean the circuit breaker trips? If so the breaker in the electrical box may be bad. Also do you have anything on that circuit pulling high amps when the dishwasher is running? Also when does it "trip out" during a pump cycle or when the heating element cycle starts?
If the pump does not work at all then the pump may have went out. If it happens when the heating element cycle starts then it may be the circuit is overloading or the breaker is bad.
Oct 14, 2014 | Smeg Dishwashers
Viking dishwasher VUD040 keeps tripping the circuit breaker during drying cycle
Are you sure the breaker is big enough to carry the Amps needed to start the drying cycle. You know that due to inductance it takes almost twice as many amps to start a motor as it does to run it.Find out how many Watts it uses and divide it by 120VAC and it will give the maximum amps it will draw. See if the breaker is high enough amp for it. A 25 Amp breaker should be efficient. I hope this helps you and if I can help you in anyway in the future let me know.
Mar 12, 2014 | Viking Dishwashers
Washer keeps blowing fuses
Do you mean the houses circuit breaker? If so, WHEN in the cycle does it blow the circuit breaker? WHEN it trips will tell you what to look at. I.E. If the circuit breaker trips during the fill cycle then it would be the walter inlet valve or the timer in the control panel; if it trips as soon as it is in the agitator cycle - then the motor or transmission; if it trips in the spin cycle - then the drain pump or transmission or control panel.
Jul 15, 2011 | Maytag LSG7806A Front Load Stacked Washer...
F2e0 error on stove
"cycle the circuit breakers" is to turn the switch for the stove at the electric switch box at the main feed of the house electric panel. This is equivalent to unplugging the stove and plugging it back in.
In the old days, a circuit breaker was a "fuse" in the "fuse box"...
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
Princeton Digital VL1916 19" LCD Monitor Logo
74 people viewed this question
Top Princeton Digital Computers & Internet Experts
Josh Whitehead
Josh Whitehead
William Ward
Level 1 Expert
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
