Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE PFS22MISBBB is not cooling. Is there a reset switch on the frig
4 Suggested Answers
aquatom
  • 108 Answers
SOURCE: ge frig not cooling
Is there anything getting cold at all?
Posted on Oct 22, 2011
Sea Breeze
  • 4655 Answers
SOURCE: The freezer on our GE PFS22MISBBB will not cool
When you say your freezer is not cool then there is nothing cool in the refrigerator is that correct? My concern is the main control board or defrost is not taking place. Could you tell me if after unpluging the refrigerator and touching the top of compressor if it is hot or cold or too hot to touch. On models like yours the control board controls most functions and that includes defrost and starting and stopping of the compressor. If there are visible burns on either side of the control board or signs of heat on the plastic relays or melted solder connections would indicate the problem. Let me know this and I will walk you through the steps of diagnosing the problems. Thanks for having your model number available, this is rare, Thank You, Sea Breeze
Posted on Jul 08, 2009
Sea Breeze
  • 4655 Answers
SOURCE: my frig is running but not cooling - frig is 50
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Posted on Jan 23, 2010
Testimonial: "Thanks for the quick help - yes frost on back wall. Once I unload and defrost should I then take out defrost thermostat? "
My frig is running but not cooling - frig is 50 degrees,freezer 40 degrees, cleaned the coils,etc GE side by side coils in bottom if frig side feel cool, "box" between freezer and frig side is not blowing...
Jan 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Jul 08, 2009 | GE Profile 22.2 Cu. Ft. Side-by-Side...
Not cooling,lower part of the frig and freezer gets cold
You may need to set the Fridge side thermostat cooler or there may be a slide switch that allows ou to set the "bias" more toward the fridge side.
Jun 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Side by Side GE Frig not cooling
Check the superheating of the evaporator.
Mar 22, 2009 | GE Refrigerators
Frig side is not cooling.
Check if there is frost on the back wall of the freezer, if so it is not defrosting. Many GE fridges need a new defrost heater every couple of years. If it's not defrosting, you can get by for a while by unplugging the fridge and leaving the freezer door open for 24 hrs, then plugging back in.
Jun 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE PFS22MISBBB freezer not cold enough. Temp won't reset.
replace the fan as quickly as possible it may be shorting and causing damage to your control board,
Mar 30, 2008 | GE PFS22SBSSS Stainless Steel French Door...
GE ADORA Refrgerator :
The water line from the house to the frig works, however the water in the frig just stop working one day. Any suggestions?
Feb 09, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
136 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
