When I try to sign on to my aol screen,I get a message that says an error has occurred.if you receive this message repeatedly,please exit and close aol,then restart the aol program
  • 78 Answers
Exit and close aol, then restart the program.
If the error continues, try reinstalling the AOL software.
Posted on Apr 09, 2008
Chat disconnected
AOL's IM, AIM which AOL's IM for all users, Skype, Yahoo Messenger, Google.. the list of IM programs goes on and on. Please post what program is "disconnected". Any error messages you receive could help too.. please post them as well.
Nov 26, 2013 | Computers & Internet
Cannot sign in, continually get the following message..Something went wrong and we can't sign you in right now. Please try again later.
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
Sep 12, 2013 | Computers & Internet
When I logon to my computer, 2 little error messages come up with the same message: Runtime error 21 025D49D2. I can exit out of one of them, but if I try to exit out of the second one my screen loses...
Having Problems With Error 21?
Cause: Error 21 takes place when the system is misconfigured or its essential files are missing. Such problems occur when a PC is not maintained properly and has accumulated many critical issues that require immediate repair.
Solution: To repair Error 21 correctly, download and install the repair tool below. This tool was design to successfully diagnose, find and fix the problems on your computer.
http://www.restoreguard.com/p/error-21.html?keyword=Error%2021&gclid=CKXWrq7il6UCFS9e7AodYkPWHw
I found this by google.com searched "run time error 21 025D49D2"
it came up with run time error 21....
click on this link above...
good luck...
Nov 11, 2010 | HP Computers & Internet
Error # 13
What "Messenger" are you trying to use? I'm not familiar with "SweetIM".
Strongly RECOMMEND:
Use MSN Messenger, Yahoo Messenger, Google Messenger, AOL Messenger, OR a well Known and Used Instant Messenger with Better Security and SUPPORT!
Jun 12, 2009 | Computers & Internet
I CANNOT INSTALL ADOBE READER 9.1 ERROR MESSAGE 1402 APPEARS
Do the following solutions first of all please remove all previous versions of Acrobat, and then reinstall.
1. Choose Start > Control Panel (Windows XP)
2. Double-click Add Or Remove Programs.
3. Select Adobe Acrobat [version] and click Remove.
4. When prompted, confirm that you want to remove Acrobat.
5. Repeat the above procedure for all installed versions of Acrobat.
6. Restart the computer, and then reinstall Acrobat.
Now, perform the steps below during Acrobat Reader installation. The Administrators group listed below is the default local administrative group for Windows XP.
  1. Write down the path to the key referred to in the error message and leave the installation running. For example: HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.pdf\PersistentHandler.
  2. Choose Start > Run, type regedit in the Open text field of the Run dialog box, and then click OK.
  3. Navigate to the parent of the key referenced in the error message. For example, for the key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.pdf\PersistentHandler, open (double-click) HKEY_LOCAL_MACHINE >SOFTWARE > Classes > .pdf.
    Note: These steps may vary slightly depending on the path in the error message
  4. Right-click on the parent key and select Permissions (HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.pdf).
  5. Verify that the Administrators and SYSTEM is present and that Full Control is selected under the Allow column.
  6. In the Permissions dialog box, click Advanced.
    cid:1f55f5d78f3846839533f8a85e395973@joanne
  7. Select the Administrators group (1) and "Replace owner on subcontainers and objects" (2). Note: Select the current administrator account if the Administrators group is unavailable.
    cid:3ce74f38956e4dfcae487444ce8f86c9@joanne
  8. Select both "Allow inheritable permissions from parent to propagate to this object" and "Reset permissions on all child objects and enable propagation of inheritable permissions," (1) and then click the Owner tab (2).
    cid:be8ff9254ad94f29bec91706f67dc76b@joanne
  9. Click OK (3) in the "Advanced Security Settings" dialog box. Windows will now reset the permissions for each child object to correspond with its parent.
  10. Minimize the Registry Editor and click Retry.
    • If the error reoccurs with the same key proceed to Solution 4.
    • If the error occurs with another registry key repeat Steps 1-10 using the new registry key.
    • If the error does not occur finish the installation following the on screen instructions and exit the Registry Editor.
Please let us know how it goes.
May 06, 2009 | Computers & Internet
Forgot my passord and can't seem to get it work need to re-set my aol password
If you can't remember your AOL® Password, you can easily create a new one by verifying information about your AOL® membership. Only authorized users can change passwords. You can use your AOL® screen name and password on the AIM® service as well. You no longer need a separate password to sign in to AIM®. You can also change the password for your AOL screen name when you are on AIM. If you do so, you'll need to use your new password to sign on to the AOL® service.
How Do I Reset My Password? If you can't sign on to the AOL® software because you don't remember your password, you can reset your password from the sign on screen. This procedure will work only if you are using AOL® Desktop™ for Mac®, AOL® 8.0 Plus and higher, only for those screen names that show up on the sign on screen, or if you connect with a dial-up modem.
To create a new password by using your AOL® software:
1. On the sign on screen, select the screen name whose password you wish to reset, and then click the Forgot Password? link. The software will dial out to connect to the Online Password Reset facility.
2. In the Word in Image: box, type the letters and numbers that are displayed in the image, and then click Next.
3. In the Your Answer: box, type the answer for your Account Security Question (ASQ) or provide other information required to confirm authorization, and then click Next.
4. Type your new password in both the boxes, and then click OK.
5. Click OK to close the confirmation window.
Aug 05, 2008 | Computers & Internet
My name is Barbara G. Scire and recently I had to change my aol billing info. Then when I tried to log on after the change I received a message as follows: Pleas sign on to the Master Screen Name or...
Hi scires3, what you can do is to call AOL since this is a billing information issue, and the AOL website needs to verify more things into your account for security purposes. You need to call AOL and ask them for the Master Screen Name or you can even ask them to change your billing info for you.
Thanks!
I know it will work. Be Positive!
Your good rating will be very much appreciated.
Good luck and thank you!
- claudus_07™
romaragregado@gmail.com
www.romaragregado.tk
Jul 27, 2008 | Computers & Internet
AOL e-Mail error reads: An error occured while loading a file. AOL will attempt to restore the file. My New, Old, Send shows only Icons with no text or seder information. Can not download, send reply...
1) Reinstall the AOL software, available here
2) If that doesn't help, you need to check your hard drive for errors:
Close any open programs.
Open My Computer, right click on your hard drive (probably C:)
Click Properties. Choose Tools, then Error Check, Check now. Select both checkboxes and press Start.
The computer may prompt you to reboot, let it do that.
This should resolve the issue.
Jul 15, 2008 | Computers & Internet
Computers & Internet Logo
145 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
