Question about RCA R52WH73 Projection Television
Coulour conversion Looks like three D how do I reset
When I turn on my TV set the picture is in three different colours, looks to be the converstion unit that I set up when I first bought the TV. How do I do that again?
  • 505 Answers
If you go into your setup menu, you will find an autoconvergence option. just select this and it will autoalign. this tv is known for a loose solder connection causing a fuse to blow and you will lose all convergence (getting rainbow bowing at all sides of the picture) let me know if you can solder and want to tackle this repair. estimate = 100-200 $
Posted on Jun 01, 2010
There is a Video problem with my Samsung LCD. The sound is clear but Colour Balance Setting is disturb. The Colour is mixing with each other. Can You tell me the procedure for My TV Setting?
Before you set up try a reset
Resetting The Picture And Sound To The Factory Settings
as far as advanced settings are concerned, set the contrast backlight and brightness so you can see the best blacks without it looking too milky, the best whites so you can discern the whites and they aren't clipped, then look at colour balance if it looks wrong when you turn the colour off.
it shouldn't be very far out in factory settings. Operation How To Change The Picture Settings On Your LCD TV LCD TV...
May 12, 2014 | Samsung LN-S2651D 26 in. LCD Television
I find the colour contrast is very dark could you send me ideal colour settings for perfect clarity thanks
Hello
Adjust the contrast to 55 to 70%; brightness to 45 to 55% and colour to your viewing taste. Now the brightness will be very low I thinks. Advance the brightness and contrast after setiing the colour to Zero. Adjust for a well defined B/W picture first. The advance the coulour. Take reference of the face colour of a news reader at studio. The picture will be perfect. OK.
Jul 07, 2011 | LG 42LB1D 42 in. HD-Ready LCD TV
Im not too sure on the serial number of my sony trinitron but iv gone off what looks most like mine! the problem i have is that the four corners of my tv set have changed colour when i turned it on at...
Hello
Your TV has degaussing problem I thinks. There is a coil fitted around the screen, through which an AC supply is fed each time when you switch on the set, and it will last only for about 3 microseconds or so, to demagnatize your picture tube. In specific timing is accieved by the help of a "Posistor" usually called as degassing posistor. If it fails to work, the fault you have mentioned will occur. If you turn your TV in an other direction, say if it is paced east-west, turn it to south-north, the colour change now you see will be in an other state.
You just open your TV. The said posistor can be located on the power section of your TV. It will be normally black in color, looks very like a small chocolate. There are two types of posistors are used by Sony. One type has only two connections, and the other have three. You just replace it, it is very easy job. Just desolder it out, and go for a same type of posistor. It is quite normal fault in all TVs. OK.
Nov 12, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Color is terrible. don't know what to adjust the settings to to make it better
turn the coulour off completely and you should see a perfect balck and white picture, this is made up by mixing red green and blue,, if it is not balck and white you may have lost a primary colour, if this is the case you will obviously never have a watchable colour picture, loss of a primary colour will need a visit from a techie.
Nov 03, 2010 | Televison & Video
Do not have copy of owners manuals and user guides
Problem is likely with a setting at the picture source. Make sure you only have enabled the setting your TV is capable of (480i, 480p, 1080i, etc)
Apr 07, 2010 | RCA HD52W56 52" Rear Projection HDTV
I have a iol tv and i dont no how to fix the picture so it looks right with my xbox
when on your xbox go to settings--------display-------------and in their check different settings until it looks ok now if the colour is wrong you might want to try changing your tv settings like gamma brightness etc... by going into menu on your tv best bet would be click menu on the remote
Mar 30, 2010 | Video Game Consoles & Games
Audiosonic km1412d no colour in tv / dvd just black&white
Check in menu for video options, Select pal, NTSC or whatever your country is transmitting. If auto option is available best to set it there. Check also sound options like I, BG, or DK and set again to your transmission,If you have a settop box make sure on other tv it is displaying coulour. saom also have sound and video options. Try to connect dvd with av cables and see if coulour is there. if still B&w get repair technician
Aug 11, 2009 | Televison & Video
Bluish green tint to television picture
Find out what board and circuit is responsible for the color and you have your answer.
Mar 12, 2017 | Panasonic PT-52LCX66 Projection Television
Color problem green and pink
I had a very similar problem - the picture would get garbled, the black colour would turn into dark or bright blue tones, and i would get wiggly/jaggy outlines on the picture wherever contrasting coulours' edges met. After 2 service calls (replaced video boards both times), i gave up and popped the back cover on the TV. I wiggled a cable that connects the video board (it is on the top left quarter of the TV if you are looking straight at the front of it), and noticed that the picture improved right away.
I found that there is a bad solder on the cable connector, and simply keep the cover off now, as the connection will get flaky once in a while (especially in warmer temperatures).
Dec 05, 2007 | Televison & Video
My tv is picture is blue and green
Hi there my t.v has a similar problem, I turned it on and the colours arn't right, there the colours go out in three circles mainly mainly blue, green, red yellow, but depends whats showing on the t.v? Please help.
Apr 17, 2007 | Bush 5693D 24" TV
RCA R52WH73 Projection Television Logo
501 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
