Question about Kenmore Washing Machines
Washer model 44052 will not drain bleach/softner during cycles. dispensor tray is cleam and open
    President:
  • 1,554 Answers
Verify first if the bleach/fabric softener compartment in the dispenser drawer is full of water. If water is present, pull the dispenser drawer out then release the clip to pull it out completely. Remove the fabric softener compartment cover and clean the tubes both in the dispenser cavity and the compartment cover. The tubes fit together but the tube in the cover does not touch the bottom of the cavity to allow siphoning action when an overflow situation is created in the compartment to dispense the fabric softener. No dispensing action will occur if the tubes are clogged
The fabric softener compartment is filled only with water during the rinse fill as the right-hand side dispenser valve is activated only during this time. Allow the washer to advance to the rinse cycle before checking the fabric softener compartment for water. If the issue is water not being fed to the fabric softener, either the dispenser valve is not working or not activated or the holes where the water is being fed to the compartment is clogged. Check the holes on the dispenser housing directly above the bleach and softener compartment and clear it from clogs.
Swap the dispenser valve wires to check the condition of the dispenser valve if the holes are clear. Put bleach, detergent, and fabric softener in their respective compartments then run the washer and allow it to advance to the rinse cycle. Check which compartment is not flooded or dispensed after the cycle is completed.
Posted on Jun 01, 2010
Cabrio wtw7600xw2 when water enters the bleach or softner dispensers it runs over and leaks on floor. I've cleaned the outlets their clear. Seems too much water comes in to dispenser areas.
If the lines to the drum are clear and draining properly then you will need to replace the water inlet valve since it is allowing to much water to pass through to the dispenser. Here is that part to order. Whirlpool W10326913 Valve AppliancePartsPros com
Mar 03, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
The fabric softner isn't draining during cycle but the bleach and detergent do just fine. I took out drawer and cleaned the dispenser but still won't empty. Help!
When cleaning the softener chamber, make sure you remove and clean the syphon tube thoroughly. This is the only chamber designed to handle liquid. Otherwise, check that you have sufficient water pressure and that the cold valve opens fully. If you dont hear a decent gush of water during the rinse cycle, it's either pressure or the valve.
Dec 11, 2009 | Frigidaire Affinity ATF7000E Front Load...
Fabric softner compartment won't dispense during wash cycle
Fabric softener is to slow mix with rinse water in the rinse cycle... check the cold water supply line for a clogged screen or a clogged dispenser box cover... hope it helps
Sep 20, 2009 | Frigidaire ATF6000ES Front Load Washer
Bleach & Softner not dispensing correctly
I finally figured mine out! Remove the dispensing tray then take a small brush, or maybe a q-tip and clean out the small hole right above the softener tray. Mine had mold in it and wouldn't let the water fill the tray, which is what causes the softener to dispense!
Jul 21, 2009 | Whirlpool Washing Machines
Takes almost 2 hours to complete a wash cycle
Have you ever cleaned it out? Its likely due to a plugged drain, not allowing the system to drain fast enough for the normal cycle. Check out my solution on
http://www.fixya.com/support/t114322-kenmore_elite_h3t_washer
-Todd
Mar 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
NEPTUNE WASHER
"downy ball" is designed to open at the end of first spin that is the way to go without stopping machine. works very well and costs just a few dollars
Feb 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
Bleach and softener dispensers filled with water at end of cycle
Yes, remove the dispenser tray by pressing on the button on the softner and pulling out tray completely. Now lift the flap over the softner compartment and clean thourougly with hot water, making sure all tubes and holes are free from residue softner/detergents. Replace flap by making sure the bigger tube fits OVER the smaller tube and click into place. Replace tray. Water is present due to the "syphon effect" of the dispenser not working, caused by residue detergents blocking the tubes/holes. Oshie
Oct 28, 2006 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
693 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
