Two or three faint colored lines side to side at angle about third way from top looks like lines at top of older zenith ptv when 110k resistors change falue
  • 8,617 Answers
Whats the model number of your set? Cant even begin to help you without knowing the model number.
Posted on Apr 09, 2008
Diagonal lines at 45 degree angle from left top to right bottom of screen
db:: 4.31::Diagonal lines on tm2 screen? fz - Hivmr
There are faint 45 degree diagonal lines covering my brand new tm2 LCD ... with some static looking diagonal lines going from bottom left to top right. .... DB:3.01:Dv6113 Us - Computer Freezes Showing Diagonal Lines On Screen aj ... Also there arediagonal lines that run across the screen at about a 30 degree angle.
3M Privacy Filter for Laptop diagonal-14.1" viewing screen ..., Inc.
Rating: 3.8 - ‎1,617 reviews 3M Privacy Filter for Laptop diagonal-14.1" viewing screen ... Premium 14.0 Inch Privacy Screen for Widescreen Laptop or Computer Monitor .... 3M™ Privacy Filters create a 30-degree cone of vision so on-screen data is .... You'll also notice a large "3M PF14.1W" printed in the top right hand corner of the filter.
FZ190: Faint Diagonal lines on screen? ' NotebookReview > ... > VAIO / Sony
Jan 27, 2016 | Computers & Internet
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
Zenith R57W46 57 in Rear Projection Television colors don't align
you will need to replace the convergence ICs and possibly the feed resistors. You can get the convergence repair kit at the following link and they send instructions that show how to replace the Convergence Ics. Heres the link look under the convergence repair kits category for your model.
Feb 06, 2009 | Zenith R57W46 57" Rear Projection...
Zenith R60v26 has burnt resistor at RK5 on convergence board
Hello, I have the exact same issue with my R49W36, I replaced the convergence chips but there are also two 1 ohm resistors with the same color pattern as yours that are bad. I have looked all over and cannot find a 1 ohm resistor anywhere. Where did you find it?
Dec 31, 2008 | Zenith R60V26 60" Rear Projection...
Mitsubishi - cannot converge red
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic2_bing.gif,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya
Dec 13, 2008 | Zenith R49W36 49" Rear Projection HDTV
Three colors line up on some spots but not others
Jan 06, 2008 | Zenith IQB50M90W 50" Rear Projection...
Red and blue light ajust but green one will not
believe you would have a open resistor on the green crt board, was either a 120k or 110k resistor
Oct 28, 2007 | Zenith IQB50M90W 50" Rear Projection...
Zenith 46" with a "hour-glass" picture.
If the hour glass figure is a seperation of colors that appear to be convegence mis aligned, then, the convergence ICs would be the problem. If the picture is clear and you have a bending on the sides then the pincusion circuit in the horizontal circuit is where to look. Be careful of this circuit, it does control the high voltage. The only way to have a board checked is to have an Authorized Service Center look at it. It does, however, sound like there is a cold solder joint in the power supply that has gradually opened up and now is permanantly open. Call Zenith (LG) to see who they recommend.
Mar 25, 2007 | Zenith Z46Z83D 46" Rear Projection...
If the menu does not work, your problem is most likely a defective R3243 (110k 1/2watt) located near horizontal yoke connectors. Otherwise check the convergence module 9-1690, for open 1 ohm resistors. Located near large heat sink.
Jan 17, 2006 | Zenith IQ5299DT 52 in. Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
