Question about Dishwashers
Is the compartment door that holds the dishwasher soap replaceable? The door is getting stuck and not opening during the wash cycle. Do I need a new dishwasher?
  • 523 Answers
Yes it is replaceable
Posted on Jun 01, 2010
My wirlpool dishwasher tab compartment don't open through the wash cycle
Clean it out with boiling water, soap residue is making it stick. The compartment is opened by heat during the wash cycle.
Dec 23, 2011 | Dishwashers
Soap dispenser will not open during cycle
I have the same dishwasher, have for about 2 years. It took me about a month to figure this out... But, you cannot run it with the flatware rack hanging on the bottom dish rack, you have to move it to hang on the door and you cannot have anything in the compartment under the soap dispenser that is tall enough to block it from opening. Annoying design for sure!
May 12, 2010 | Whirlpool GU2455XTS Built-in Dishwasher
The water isn't getting hot
If the water to your kitchen tap is above 120 to around 145 your machine is getting hot water. If not your need to adjust your hot water heater.
It is fine to open the DW door during the wash cycle. The unit will hold the wash cycle. Open the door during the start of the wash cycle (not rinse) and see it the dispenser door is open. If not it could be the timer is not sending the proper signal to the dispenser on when to open. This would be a timer issue and you would want to replace the timer. I doubt that this is it but it is possible.
Hope this helps.
Mar 22, 2010 | GE Dishwashers
The main wash door doesnt open
switch to pre-measured tablets,and throw the tablet directly into the tank(d/w..)it works better that way anyways...most dispensers are very expensive also
Mar 03, 2010 | Dishwashers
The soap dispenser opens but the soap is not dispensed and the dishes do not get cleaned. Can you help?
Make sure that there is nothing blocking the soap door from opening fully when the dishwasher is shut. This happened to me and I also thought that the soap door was opening during the cycle when it actually only partially opened during the wash and then popped open fully when I opened the dishwasher at the end of the cycle. So some, but not all, of the soap was used.
Dec 28, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwasher
If you are you using a liquid soap or packets that will be the main problem.If your unit fills with water circulates the water and drains the water,and also heaters are working then you probally need to change to cascade powder soap.The film on the dishes is soap.The unit has so much build up in it that when it gets to the rinse cycle it is rinsing dishes with soapy water.You need to get 2 medium bowls fill both 2/3 up with white vinager,place one in upper rack and one in lower rack and run unit on longest cycle letting the vinager splash out during wash.do this with no soap and no dishes.Having soft water will allow you to use less soap.
Apr 23, 2008 | Dishwashers
Soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Mar 01, 2008 | Dishwashers
Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Feb 16, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
IT SEEMS YOU SOAP DOOR HAS A BAD SOLENOID ACUATOR OR RELAY
Jan 17, 2008 | Kenmore 24 in. 16592 Built-in Dishwasher
Dishwashers Logo
44 people viewed this question
Top Dishwashers Experts
Owen Barnes
