Fuse burnt Model LAT9400ABW machine only fills water and over fills
    President:
  • Washing Mach... Master
  • 2,651 Answers
Sounds like you have a bad water level switch, or the tubing from tub to the switch has come undone,
Posted on Apr 09, 2008
SOURCE:
I ran out of water, and after filling up with water again it doesn't works.
Either, the element, has burnt out, or the Thermal fuse has... You need to get this unit looked at by a professional.
Apr 09, 2010 | Gaggia Evolution Espresso Machine
Washer stopped working all together
Hi,Check your water solenoid valve, the part where you connect (2) hoses, could be burnt out, sometimes they do, especially if your water pressure home (building) is low, or could be your motor, remove back of machine and check water valve, check valve with ohm tester, or visual check can tell you, if burnt out, replace it, few things could burnt out, motor, capacitor, switches/relay etc, but first check water intake (solenoid) valve, also,check / reset, fuse/circuit breaker, probably went of, when burning smell occurs, ( happened) if it's not your water intake valve, let me know, we can check other possibilities. but i believe it's your valve, good luck.
Aug 13, 2009 | Magic Chef CAV4000AWW Top Load Washer
Why did my LSE7806ACE WASHER STOP FILLING
Hi…
If I get you correct, the hot water is not coming into the machine or it is not working at all.
Let me know
Thanks
Smith
Aug 13, 2009 | Maytag LSE7806A Top Load Stacked...
Beaumark washing machine model 57751h1ww not
hi, check power, make sure you got power, check water solenoid valve at back of machine, check for clogging, or put machine on and listen for hum, on water valve, if there's no hum, possible need new valve, normally they burnt out after a while, especially if you are in an area with low water pressure, or sometimes they get stuck, give it a tap. good luck.
Aug 02, 2009 | GE Washing Machines
Washer only agitates and fills with water at same time.
The contacts in the timer are shorted (fused together). You can try removing the timer, opening it up and releasing the contacts that are fused together with a small flat blade screwdriver (look for burnt contacts). It might work for a while but it likely won't last. Your best bet is to replace the timer.
Mar 03, 2009 | Kenmore 24032\24036 Top Load Washer
Washer stopped filled with water, smells like burnt plastic
REPL/ PUMP BURNT PALSTIC SMELL ,AND RUBBER SMELL, ONCE REPL./ SHOULD FIX
Nov 29, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Automatic temperature control
The cold water valve may be defective - the solenoid (coil) burnt open. Coil may be replaced
Regards
Sep 20, 2008 | Maytag Washing Machines
Burnt rubber smell
the belt is broken. the machine wont spin or agitate with a broken belt. set the timer to spin and the water should still drain. but not spin. belts are very cheap but replacing on could be tricky if you dont know what your doing
Jan 24, 2007 | Maytag Performa PAV2200
Maytag Neptune front load washer (top of the line)
some of the early washers had problems with a weak or faulty motor . take front panel loose and look at motor board it may look burnt on some of the resistors or look at the clear fuse at front of board it may be burnt if so use a motor/board conversion kit p#12002039.
Oct 26, 2006 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
