Samsung sp42w4hb rear projector tv
Hi, my tv has the red, blue, green colours over lapping. and are curved mainly at the top and mainly the red followed by the green then the blue wich is not to bad. I had some one say they think it's the IC- Part no STK 392 could you please 1st tell me what you think it could be and 2nd what would it cost for the part and can you get 1, and finnaly is the tv worth repairing. thanks,Dave.
  • gnlward Oct 29, 2008
    same problem only im in australia and my parts numbers dont match any on here
How do i get sky tv link to work on tele
Posted on Nov 08, 2011
Hi, my tv has the red, blue, green colours that are over lapping. and are curved through the middle of the screen and mainly the red followed by the green then the blue . could you please 1st tell me what you think it could be and 2nd what would it cost for the part and can you get 1, and finally is the tv worth repairing?
Posted on Jun 25, 2010
  • 121 Answers
Dave,,yes the tv is worth fixing the ic part you need is STK 392-010 and at this site i will give the link to they are 19.99 each you will need 2 if you get them at the link I posted you will also get free online tech support plus installation instructions with pictures
http://servicemanuals.vstore.ca/
Posted on Apr 12, 2008
The red and blue projectors aren't aligned with the green projector. It is more sever towards the top of the screen. The green projector also has a curve in it at the top of the screen.
this is called convergence.
the set should normally have a function in the menu to adjust/reset this.
it sound like either the mirror in the tv is warped or the green lamp is out of alignment. if the convergence in the menu doent work then its a service job.
Feb 07, 2010 | Hitachi 61SWX10B 61" Rear Projection...
Hello tv has warped bottom and top screen on a rear projector samsung and blurred vision with red,green blue colurs not aligned tried to tune to no avail Samsung rear projector tantus sp42w4/42w5
The colors tell me of a convergence IC issue, warped bottom and top tell of another.
see this page on reparing the convergence problem yourself
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
also compair the before and after pictures to see if this is the other problem your having.
Then you have another fault, which im not completely sure of right now. I will look into it.
Oct 27, 2008 | Televison & Video
Samsung SP47W3HFX tv blue flickering curved line..
If the lines are slightly curved and stationary on about 2/3 of the screen its either the Blue CRT or the Blue CRT drive board which is having the problem.
Dec 19, 2009 | Televison & Video
Picture is OK, but colors are off and there is a blue star background that shows on dark colors.
Hello, With most rear projections there is usually an alignment to do with the set up with your TV. This is so the red, blue and green projectors align together to give the correct colouring. This sounds to me what may be causing the outlining of the blue. This can also make it seem off colour. Look in the set up menu of the tv and see if you can find this alignment feature. Usually a cross will appear and you move a blue, red, and green cross with the arrows on your remote to align over the original white one. If this does not work, it may also mean that one of your projectors, that is the red, blue or green one may be failing causing the off colouring. Hopefully this alignment may fix it for you.
Oct 26, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Problem with a colour display on Hisense tv
If your picures are all purple it means that the green colour is missing. TV colour is made up by mixing Red, Green & Blue. Removing Green leaving Red & Blue makes purple. Study the green colour circuit for a fault and confirm that the green gun inside the tube is working.
Aug 31, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Green out of alignment on samsung rear projection tv
Hi luke I am in the uk and not familiar with this set is it a three tubed crt television or an lcd projector type .. either way what you are descibing is convergence ( three primary colour guns all pointing at the same spot in a nutshell ) in the case of a crt projection tv three tubes one red one green one blue .. there should be a convergence pattern in the menu to re set the convergence via the remote check the manual . If it isn't adjustable you may have a scan coil fault or a tube ie : green with low emission check the green colour gun transistor and associated circuit for leaky caps resistors that have changed value or transistor leakage .. and don't forget the ever popular dry joints on the scan coil plugs .. hope this helps Vortash
May 29, 2009 | Samsung HCL4715W 47" Rear Projection...
My tv has lost its colour, and its green or yellow sometimes.
Okay that means the other GUNS went out when i refer to guns I mean the other blue and red, they need to be replaced pretty costly but if you value that TV I'd do it.
Apr 22, 2009 | Samsung HCN4226W 42" Rear Projection...
Samsung HCL473W 1080i red shadow & words are curved at top/bottom
I believe you have convergence problem on your rear projector TV. It require to replace may be 2 IC output convergence or the convergence drive, after replace those component you need to readjust convergence which mean you move the RED GREEN BLUE to be 1 on top each other you must have the remote control and service manual to get into the service mode, if you thing you can get those part in your country the service manual I may help you with that, ask your husband if he like to challenge it. I hope that is give you some ideas
Cheers
Dec 17, 2008 | Samsung - Projection TV replacement lamp...
Colour split green and red with shadow effect on a Samsung rear projector 42" TV
HELLO. IT SOUND'S LIKE YOUR PROBLEM IS IN YOUR CONVERGCE BOARD.!!! YOU MAY HAVE TO REPLACE YOUR (IC chip's) on the board .!!! they are what control the color for your convergence.!!! set up .!!! that make your (CRT GUN'S) BLUE & RED LINE UP WITH YOUR GREEN (CTR GUN) TO MAKE YOUR PICTURE LINE UP RIGHT.!!! HOPE THIS HELP'S YOU .!!! "GOOD LUCK"
Aug 10, 2008 | Televison & Video
Samsung rear projection tv sp42w4hb
I would check the CRT socket module for Cracked solder joints. If not you may be in the early stages of the CRT shorting, If so you will need a new CRT.
Jan 04, 2008 | Televison & Video
Televison & Video Logo
230 people viewed this question
Top Televison & Video Experts
Electro Med Services...
