Question about Kirby G5 Bagged Upright Vacuum
No foam/water is coming out of my Kirby shampooer. I think it may be clogged, but don't know how to take it apart to see.
5 Suggested Answers
SOURCE: kirby diamond edition - shampooer
1. Raise the vacuum head all of the way up. 2. Remove the vacuum head by removing the belt and releasing it. 3. Place the shampooer head on the vacuum by securing the clamp and them put the belt on 4. Take the bag off of the vacuum by twisting at the base just slightly outward and lifting upwards and unclamp it from the handle 5. Put water and cleaner into the water resevoir. 6. Put the reservoir on to the kirby where the bag was by holding it parallel to the vacuum then using both hands, twist it outward slowly until it goes down onto the unit then twist back to parallel position. 7. Put the coil looking piece on the shampooer head on top where the hole is...it will only fit one way successfully. 8. Put the other end on the under side of the water reservoir. 9. Lower the shampooer head all of the way down on the carpet just like you would the vacuum head 10. Turn on the vacuum and reach down and turn the knob at the top of the reservoir, this will begin putting cleaner (tons of foam) onto the carpet. Just work in 3' x 3' sections, turning off the foam intermitently until you are finished. I hope this helps.
Posted on Sep 03, 2007
SOURCE: Kirby Ultimate G carpet shampooer not producing foam anymore
Thank you so much for this. I've been struggling with the same problem. For the price of these vacuums, they should include this information in the trouble shooting chapter.
Posted on Oct 20, 2007
  • 112 Answers
SOURCE: Kirby shampooer
here are instructions with pictures of how to put the kirby shampooer together...
http://www.greatvacs.com/shampoo.shtml
hope this helps!!!
Posted on Mar 28, 2008
b0sslady2001
  • 357 Answers
SOURCE: Foam stopped working on my Kirby shampooer
You need to check that the little round screen is in the hole where the hose attaches to the shampoo tank. My guess is that the little round screen is wedged sideways in the end of the hose.
Marci
Posted on Jun 28, 2009
I am shampooing a berber carpet with my Kirby Ultimate G and no excess water or suds accumulate in tray. Either while suds dial is on or off. Why do suds come out under tray in straight line no matte
SYSTEM:
Will work with:
  • Kirby G3 vacuum cleaner
  • Kirby G4 vacuum cleaner
  • Kirby G5 vacuum cleaner
  • Kirby Gsix vacuum cleaner
  • Kirby Ultimate G vacuum cleaner
  • Kirby Ultimate G Diamond vacuum cleaner
  • Kirby Sentria vacuum cleaner
  • Sentria II (Sentria2)
This is unused shampoo attachment. We buy new parts and assemble this shampoo attachment so you will be the first one to use it.
Set includes:
  1. Tray with shield
  2. Nozzle
  3. Brush roll
  4. Belt
  5. Container with cap
  6. Hose
  7. 12 oz. shampoo
NOTE - pictured Kirby Sentria shampooer box may not be included.
If you have never used this shampoo, we highly recommend reading our ONLINE MANUAL. This is a simple but very effective unit but you have to learn how to use it and "common sense" will not be enough! HOW TO - V I D E O S
Tank with soapy solution is attached in place of the bag. It utilizes the air coming out of the exhaust to blow soapy water on a small screen that turns it into thick foam. The foam is simply laid over the carpet (you must vacuum before you shampoo). Foam allows the spread of a small amount of water over the area so carpet is not soaked all the way through. Foam is left on the carpet for a few minutes so it has just enough time to moisten the fibers of the carpet and loosen the dirt (not too long otherwise foam may dry). Then foam maker is set to "OFF" and you slowly pull Kirby vacuum over the area where you laid the foam. The rotating brush in the shampooer nozzle rubs the moisture off carpet fibers and and throws it into the tray in front of the unit. You will not see gallons of dirty water but that is because you did not put it on the rug in the first place. Carpet should dry within 1-4 hours (depends how many times you laid the foam and what is humidity in the room). After it dries it has to be vacuumed. Solution that did not get picked up with the shampooer brush dries and shampoo additives do not let the dirt stick back to the fibers of the carpet. It is loose when it dries so in order to pick up what is left, you must vacuum again.
Shampoo:
You can use any carpet shampoo sold in your local store but make sure that this is carpet shampoo that makes foam and pay attention how much you have to dilute it with water as various shampoo products come in different concentration. Avoid using "just anything" that makes foam. Some household chemicals (such as dishwasher fluid) will do great job but it will leave carpet unprotected so dirt will stick to it so well that you will have a filthy rug in no time. Kirby Vacuum Shampooer
800-775-6586
GoodVac com
Feb 14, 2015 | Kirby Ultimate G Bagged Upright Vacuum
Shampooer does not distribute foam
It usually means you have no filter or a defective filter in your shampooer hose,or your not using kirby shampoo.
Dec 09, 2011 | Kirby G6 Bagged Upright Vacuum
What parts go to a Kirby Shampooer?
There is a shampooer head with shampooer brushroll, water tank, small hose that hooks to the tank, collection tray
Need to use the Kirby shampoo. It goes down as wet suds but you pick up the suds with the vacuum when it drys. Fill tank adding 1 cap full of soap (kirby soap only) per level on the side, this attaches on the side where the bag is attached
After using the shampooer you need to reattach the vacuum bag and main brushroll nozzle as though you were just vacuuming up dirt.
Instructions:
Lift the front of your kirby up (front part with light) open the handle on the dail in the front (if epquipt), remove the power head, put on height adjustment on highest level, turn dial on front of power head until you see 2 red arrows facing each other, unlock by turning knob, power head should come right off, get shampooer out the power head for shampooer with collection tray, make sure dial is set red on red, put on front of Kirby and lock in, turn dial to green on green arrows, fill tank adding 1 cap full of soap (Kirby soap only) per level on the side, this attaches on the side where the bag is attached, line up arrow and notch and turn, to hook up hose put Kirby down to lowest level, notched end of hose hooks in on tray other end on the tank,on/off switch refers to the foam, Turn machine on to lay the foam & scrub carpet, take shampooer back off to extract the foam once it's dry.
Good luck.
Aug 20, 2009 | Kirby G5 Bagged Upright Vacuum
There is no foam in the hose as I run the kirby shampooer. What could the problem be?
Check out the manual HERE.
It may be clogged valve on the solution tank.
Very dirty or clogged sponge (shampooer tank)
Very dirty or clogged screen(shampooer tank where hose is connected)
It is pretty common that that small screen comes out and stays in the hose elbow.
Rocky
Aug 15, 2009 | Kirby Ultimate G Bagged Upright Vacuum
It's been awhile since I have used my shampoo system on my Ultimate G series Kirby. Well, as instructed I took it apart and cleaned it. Now I can?t figure out where to put the ?screen cap? and ?sponge...
The littlew round screen goes in the hole where the hose attaches to the tank. The round foam filter goes up in the hole underneath the on/off valve for the foam. Here is a guide if you need any more help...
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Marci
Jun 15, 2009 | Kirby G6 Bagged Upright Vacuum
I have a Kirby vacuum with the shampooing attachment. The shampoo/liquid comes out of the shampooer in a drizzle of liquid. There is no foam.
You need to check that the little round screen is in the hole where the hose attaches to the shampoo tank. My guess is that the little round screen is wedged sideways in the end of the hose. Here is a guide to help you further... http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Marci
Jun 01, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Shampooer won't pick up water
look on the vacuum where the suction is to pick up and you will see its clogged ,clean out the suction ports
Apr 13, 2009 | Kirby G6 Bagged Upright Vacuum
My G series kirby carpet cleaner will not **** up the water or foam very well
The Kirby shampooer deposits the foam onto carpet,and works it into the carpet with the shampooer brushroll.After the carpet is dry,use the vacuum itself to pick up the dry foam and dirt.The Kirby Shampooer is not an extraction shampooer
Nov 14, 2008 | Kirby Vacuums
Kirby Sentria
Your shampooer is not broken. (sorry Fanny)
You are missing a wee screen that fits on the hole where the little hose plugs into the tank. Check inside the hose end or down inside your shampooer box. Here's a link to my online Kirby shampooer instructions...
Hope I helped!
Marci
Nov 05, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Vacuum Shampoo Attachment
If your trying to shampoo your carpets but the water flow is to weak and it trickles through the spout to the carpet leaving small puddles
This problem often occurs when the foam filter is not replaced after rinsing or ends up in the shampoo hose at an angle preventing foaming. If you take the small shampoo hose of the shampoo tank the filter should be on the tank, if not, it may have come off and be in the hose. If it’s not there locate it, likely in the area where you last cleaned the shampooer or in the box, and put it back on the tank. While this should be cleaned after each use, care should be taken to replace it and not lose it.
The problem may also occur if you don’t actually add the Kirby Dry Foam Shampoo to the water or if you use some thin else.
Take care to also clean and replace the air filter after rinsing. It is located under the shampoo tank where the tank fits onto the vacuum.
Phil-T
Sep 07, 2007 | Vacuums
Kirby G5 Bagged Upright Vacuum Logo
214 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
