Question about GE GSL25JFPBS Side by Side Refrigerator
Ice maker not working on GE side by side
I have a GE GSL25JFTABS side by side fridge and the ice maker quit working, but the water dispenser works just fine. I have even turned the freezer off, and let it get to room temp, then, turned it back on and it still does not produce cubes-AND the green light on the cube maker next to its switch is not continuous, it is blinking now. Any ideas on what I should do next?
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iyooyi76
Posted on Sep 30, 2010
Samsung refrig, side by side, won't eject ice. How do I turn off the left hand light to quit ice?
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
If your ice maker doesn't make ice, check out these expert do-it-yourself ice maker repair ... W. Branner Side by side GE fridge, stopped dispensing ice both cubed and crushed. ... But now that it's cleared the motor won't run to dispense any ice (water .... Our Samsung French door ice maker is not working & is making noise.
Jan 01, 2016 | Samsung Refrigerators
Ice maker not making ice
Sounds like either your condenser is blocked or you have a refrigerant leak
Jan 05, 2014 | GE HSM25GFTSA Side by Side Refrigerator
GE Fridge water dispenser working but not the ice
Yes you most likely have a defective dual water control valve. Look around the inside of the refrigerator for a model number.
Click here=> For most locationsSide-By-Side
  • Top Freezer
  • Bottom Freezer
    Once you find the model number I will be able to tell you what part number the dual dual water control valve is or if your ice maker assist you in testing ice maker. If ice Maker is empty try filling with tap water to top edges of ice maker, allow water to freeze and if the ice drops into the ice bin but does not refill with water automatically I would say that the dual water control valve will need replaced. If your ice maker has old shrinking ice from a few days ago it will point to an ice maker problem.
    Thanks, Sea Breeze
  • Feb 10, 2012 | GE Refrigerators
    My GE side by side fridge/freezer is working, water dispensing ok, but not making ice. I switch off the fridge, than ice maker but still not making ice. I try all the hints from Manual but no luck. Water...
    fill the ice maker with water manually, if you have ice in the bucket you know that the ice maker is working , after check the water valve if is opening , if it is replace main board
    Jun 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
    There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
    Apr 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
    I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
    Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
    GE Profile TFT25 PR. Ice maker quit producing
    Had the same problem. Replace the water filter and is should begin making ice again.
    Mar 05, 2009 | GE Profile PSW26P Stainless Steel Side by...
    No water flow
    turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
    Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
    GE GSL25JFPBS Side by Side Refrigerator Logo
    911 people viewed this question
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    Gene Tuck
