Question about Sony Grand WEGA KDP-57XBR2 57" Rear Projection Television
Yellow screen My scrren needs more cleaning than just wiping off the front. Yes I am a smoker. I have cleaned the bulb area but am nervous about trying to go further blindly. Can you help.
  • Anonymous Jan 09, 2009
    can the bulbs be cleaned on my WEGA
    Sergeant:
  • 395 Answers
Use a foaming glass cleaner on the screen such as plast-n- glass you can get it at www.mcminone.com . make sure the set is off, use a lint free absorbant cloth to wipe it dry. don't use paper towels they will scratch the screen. do not use on the inside screen, smoke tends to go to exposed surfaces. you can also clean the mirror but leave no streaks or they will show up in the picture.
Posted on Apr 09, 2008
SOURCE:
Had tv fot about 7 years, at top center of screen an area has appeared that is yellow in color. How can I fix problem?
If it's a 3 tube projector, the front of some of the tubes are cooled by an oily substance. this oil is replaceable. If it uses a light bulb, the bulb can be dimming, the color wheel may need to be cleaned as well as the lenses in front of the light. The DLP chip can also be going bad.
Oct 25, 2016 | Televison & Video
What's the best way to clean an oil painting. It looks as if this painting might have hung in a smokers home and is dingy and a bit 'yellowed'. I'm an artist and have access to quite a number of produ
Look at the back of it to see if it has yellowed. If there are yellow stains on the frame and the back, then it is not the varnish in the oil paint that has yellowed. You can then use something like 409 cleaner to get the stains off. You should blot the painting and not scrub or wipe it. If the varnish is yellowing you can get a product called conservationists liquid and apply that as per the directions to help with the varnish problem.
Mar 15, 2013 | Computers & Internet
Purchased front-load Frigidaire washer LTF530FS November '07 at Lowe's. It has a restricted water supply line caused from some construction in another area of the house. Now the washer takes...
Yes it very well could be that, when thet were building the near by house did you at some points get dirty/muddy water out of your kitchen/bathroom/shower? if you did the mud and grit is blocked in the filter scrrens on the back of washer were inlet hoses connect to,by removing the hoses and cleaning those screens that may fix it,if not the water inlet valve would need to be replaced
Aug 07, 2011 | Washing Machines
Whats the solution when tv dont display clear scrren?
yes it will work.first put 2 to 3 drops of water on screen and clean using a soft dry cloth and clean the screen from middle to the outer edges.wipe it clearly don't leave any water on surface.after that you screen just as looks as a new screen
Feb 13, 2011 | Televison & Video
All areas that should project white are yellow could this mean bulb is getting old or maybe the settings of the compoter its hooked upto need to be chnaged please advise
If the screen is getting more yellow, that is due to either an old bulb, not producing so much high frequency light, or the blue LCD imager is dirty/burnt or the mirrors require specialist cleaning.
Cleaning the LCD units and mirrors takes about 2 hours to complete including re converging.
Hope that gives you an idea.
Dec 31, 2010 | InFocus Proxima UltraLight LS2 Multimedia...
How & what do I use to clean the mirror
You can use glass cleaner to clean the mirror once a year (more for heavy smokers). Some models use the glass mirror, some use the Tin Foil like stuff on wood that scratches really easy, on those use a softer paper or cloth and spray it and wipe the spray off in one direction gently so you don't damage the fake mirror.
also do not clean the front screens (lentic and fresnel lens) you will create white/clear spots on them , damp a soft paper or cloth withwater
if you need to wipe the outside screen protector.
hope this helps
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Sep 02, 2009 | Philips Magnavox 51MP392H Rear Projection...
Bugs in my tv
YES!
remove the top back panal screws (be carefull the mirror is connected to the panal! do not drop!) now wipe off and clean the three glass lenses inside..also wile your in there clean the inside of screen and the back panal mirror You will see a big improvment in picture!!
Please rate this response and help keep this area free!
Jan 22, 2009 | Mitsubishi VS-50111 50" Rear Projection...
YELLOW SPOT ON SCREEN
There may be a dust fleck on one of the LCD screens inside your projector. I had a similar problem and managed to clean it. But it requires you to dissassemble the entire projector !!!. If you are not technical, don't do this yourself. !!!
Feb 16, 2008 | Sony VPL CS5 Multimedia Projector
Dull picture
Yes you can take the back bottom of the tv off.You will see 3 bulbs 5or6" in diameter.take a very soft clean cloth spray cloth not bulbs.windex persoal cleaner for your glasses ect.wipe bulbs gently removing dust.Above thes lights are the mirror maybe 10"by12" clean that to spray cloth not mirror than wipe clean"Now get limber and try to reach the inside of the big screen and wipe completely.
Dec 29, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Hitachi 50vs69a
Spanking comes to mind... :) Just kidding..
You can access the inside area od the screen and with some windex and paper towel clean the reverse. There are actually two screens there sandwiched together, a lenticular and frensel screen. If you remove the front panel you should be able to remove the screens from the frame and clean between them also... If any of this makes you nervous calla qualified shop and they can do this in minutes on a house-call..
Have a great day!
Bill
Nov 21, 2007 | Televison & Video
Sony Grand WEGA KDP-57XBR2 57" Rear Projection Television Logo
96 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
