Cars & Trucks Logo
Posted on Jun 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the filter located on a 2001 dodge ram
Where is the fuel filter located on a 2001 dodge ram 5.9L
ZJ Limited
Level 3:
  • Dodge Master 17,989 Answers
  • Posted on Jun 01, 2010
ZJ Limited
Dodge Master
Level 3:
Answers
17989
Questions
0
Helped
14458126
Points
60858
2001 Dodge Truck RAM 2500 3/4 ton 4WD 5.9L Turbo Diesel 6cyl the Fuel Filter is located under hood, passenger side, lower engine area, mounted above starter.
2001 Dodge Truck RAM 2500 3/4 ton 4WD 5.9L SFI 8cyl the Fuel Filter is located under vehicle, center, below seating area, mounted on top of fuel tank, in fuel pump module.
Hope helps with this (remember rated the help).
Where is fuel filter on 2001 dodge ram picku
It is located in side the gas tank u have to puck up the trucks bed to get to it .the fuel filter and fuel pump are all one.
Where is the fuel filter located on a dodge ram 2001 1500 5.9 4X 4
It is located in the fuel tank. Dodge decided to place the fuel pump, filter, regulator, and sending unit into one module.
Where is fuel filter located for a 02 dodge ram 4.7l
im not really sure were but usually there on the fuel line drivers side or near gas tank usually pretty visible
1helpful
Where is the fuel filter on a 2001 dodge ram 1500, 5.2 liter engine?
fuel filter is located on bottom of module (module = fuel pump,fuel filter, and fuel gage indicator) located inside of fuel tank.
Where is the fuel filter located on a 2001 ram 1500 4x4 p/u?
The 2001 Dodge Ram does not have a fuel filter only a fuel strainer in the fuel tank.
Hope this tip helps.
r/
David
Mass air sensor on a 2000 Dodge Ram 2500
inline of air duct (plenum) after air filter
1helpful
Your truck is not equipped with a "fuel filter". The only filtering device is a sock on the fuel pick-up in the tank.
1helpful
2answers
Where is the Fuel Filter located on 1988 Dodge Ram 50
1988 Dodge Ram 50 fuel filter is located adjacent to fuel tank. More specifically, the fuel filter is directly above frame rail at front end of fuel tank. The fuel filter and retaining clip can be seen between the two bed mounts on the driver side.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
