Question about Toshiba Satellite P105-S6104 Notebook
Microphone trying to use my microphone and get this message: this computer does not support the required audio compression format Please help!
  • Jimmy31102
    Jimmy31102 Apr 09, 2008
    the problem is for the Toshiba Satellite P205D-S7802
  • STEPH513 Jun 07, 2008
  • 55 Answers
Try to find the latest updates for your hardware and software you are using
Posted on Apr 15, 2008
The guide fro properly connecting your microphone is here
GarageBand 11 Connect microphone
The problem is with OSX and its usb bus and not your settings or your usb device.
The solution to your problem is to use a firewire soundcard. That way it will use the firewire bus and all should be fine.
Feb 15, 2014 | Computers & Internet
No sound
Webcam Audio Getting sound to broadcast with streaming video using a webcam requires a few components to work in unison. Because most webcams do not have a microphone built in, you will need to buy a microphone for your computer or locate your microphone input if you have one built in (some laptops have these). The audio and video are two separate functions and must be diagnosed as such. b> Webcam Software b> If you have a webcam set up correctly and you are streaming video, then you are already halfway there. This details only how to make the sound work, so please refer to an article related to webcam video if you do not have that working already. The webcam audio and video both communicate with your computer via your webcam's software application. Due to this, you will find that there are settings specific to your webcam software for sound. Because there are various software applications that can act as an interface for your webcam, you will want to do a product-specific search on the Internet for your application's settings. Most often you will find the settings for sounds under Tools or Settings, then choosing Options or Preferences. Regardless of the application that you are using to broadcast your webcam video, you will need to ensure that your microphone is plugged into the "Microphone In" jack on your computer or laptop. The microphone input jack is commonly colored pink. b> Microphone Connection b> With your microphone plugged into the "Microphone In" audio jack, test the audio inside your webcam's software application. Most webcam applications allow you test your microphone by reading a sentence and watching a graph move as you speak. If you see this happening, then you have correctly hooked up your microphone. If you have a Windows PC you should also see if your computer recognizes your microphone by clicking on "Start" > "Settings" > "Control Panel" > "Sounds and Audio Devices." Under the "Audio" tab you will find a section for "Sound Recording." From there you can select or change your "Default Device." b> Hardware Troubleshooting b> In the event that your microphone is not recognized by your computer, continue hardware troubleshooting by contacting your computer's support staff. With a properly connected microphone and some minor adjustments in your webcam's software application, you should be broadcasting audio with your video in no time. Hope this helps.
Jan 22, 2013 | Gear Head Gearhead quick webcampro...
I just bought an audio technica at2020 cardioid condenser mic its the 20 series and i cant figure out how to get it to work on my toshiba laptop
Unlike 'Dynamic' microphones all condenser microphones require some sort of power supply to make them work. Sometimes this can be by way of an internal battery but many of them work on an external 'phantom' power supply.
I am not familiar with the exact model number you quote but AT make 2 types of AT2020 condenser microphone.
1) If your AT microphone is fitted with a USB plug then you can connect it directly to the USB socket on your computer, which will provide it with the power that it needs to make it work. The USB bus should automatically recognise the microphone and allocate an audio channel to it but you may still have to select this device as your input source in your recording program. How you do this will differ from one program to another.
2) However if the microphone is fitted with a standard jack-plug then it will not work by you just plugging it into your computer microphone input socket as this is not powered. You will need a separate 48volt DC power supply to power the microphone.
You will almost certainly also need some sort of microphone pre-amplifier to match the output voltage and impedance (electrical resistance) of the microphone to the levels required by your audio input socket on your computer.
Probably the best way to achieve both of these requirements at lowest cost would be to purchase a small audio mixer with a phantom power option such as the Phonic AM220
WARNING - most audio mixers only have one on/off switch for phantom, power - thus the power is either on or off for ALL channels. Some other devices - like radio microphones, keyboards and electric guitars may be damaged by having 48v dc current supplied to them
Here is a link to the technical specs sheet for the AT2020
More information is available here
Jan 28, 2011 | Audio Technica Audio-Technica AT2020 -...
Sony vaio vgn-cs215j not work microphone let me help please.
This will happen if the Microphone in the Computer is not enabled or if the Audio Driver is not installed correctly.
To make sure that you have enabled the Microphone in the computer, please right click on the Sound icon on the System Tray (right corner of the taskbar). Then, select the "Recording Devices" option. This will open the Sound Properties window. In the Speaker/Headphones Properties window, click on the Levels tab. Then, on the Levels tab, next to Microphone , click on the speaker button to enable the microphone.After that click the OK button and close the open windows. This will enable the Microphone in the Computer.
If the issue still persists, you may need to re-install the Audio Driver in the computer to fix it.
To download the Audio Driver for the Computer, click here
Please download the file to a temporary folder in the Computer. After that, please open the folder where the file is downloaded and double click on it to begin the installation. Please follow the onscreen instructions to complete the installation process. After that, restart the Computer for the settings to take the effect. Re-installing the Audio Driver also fixes the issue with the Microphone. Hope this helps..
Good luck..!
Sep 12, 2010 | Sony VAIO VGN-CS215J/W Notebook
Microphone not detected
Follow these steps...
1. Make sure the microphone is plugged in to your computer. Make sure its in the right jack.
2. Install the necessary drivers, if you have received the cd.
3. Right Click My Computer > Properties > Device Manager. See if there are issues with any of the hardware devices. If yes, then try to update the driver.
This should help.
May 21, 2010 | Logitech QuickCam for Notebooks Pro...
I cant make on microphone go thru my amp mixer
It's obvious that there is a misunderstanding. Your FCA202 is designed to get line level inputs (not microphone level) and convert the signal to digital format for the computer to "undestand", it's working like an audio card. So in your case all you need is a microphone preamplifier to pass the signal from your mic to FCA202, or an audio mixer to do that.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"????????? ???????"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Nov 23, 2009 | Behringer F-CONTROL AUDIO FCA202 External...
Microphone doesn't work
check DEVICE MANAGER and see if there are any conflicts-check if the sound card is recognized-check configuration in CONTRO PANEL> Sounds and Audio Devices
Sep 12, 2009 | Creative Labs Creative Sound Blaster...
Dell inspiron 6400 Soundcard Microphone
sorry for the delay in responding:
for Vista system ... use the following picks:
Start ....Control Panel,...... Hardware and Sound, .... Manage audio devices....Recording......Line in ...try the advanced features to control the computers auto adjustment etc.
Hope this helps
Apr 05, 2009 | Dell Inspiron 6400 Notebook
Dimension E310 Microphone
its on the back on mine but if you dont have one you could get a usb mic
Jun 12, 2008 | Logitech USB Desktop Consumer Microphone
Microphone on aspire 3680 not working
First u activate ur microphone connection.Click on Start - Settings - Control Panel - Sound and audio device Propeties - Advanced - Options - Properties - Select Mic in volume and check it.
Feb 28, 2008 | HP Compaq Presario V5000T Notebook
Toshiba Satellite P105-S6104 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
